I've been working on a couple of other GB, trying to finish before the deadlines run out, but I've managed to do a little work on USS New Orleans.
I thought I'd start with the PE replacements. That way, if anything fails, I'll know ahead of time, and I can still replace the bumbles with the kit parts.
Here's the PE sheet, from WEM. Lot of stuff here, but much of it is for NO class cruisers later in the war, and won't be used.
![](http://i28.photobucket.com/albums/c244/wishbone99/PearlHarbor2013/01_zps796b01f7.jpg)
Above and to the left of the penny are the parts for the searchlight tower, which is where I started.
It took several attempts to get it done. I tried superglue first, but the stuff sets up too quickly, and I didn't get the parts aligned properly, so I soaked the whole thing in fingernail polish remover till the superglue dissolved, then I reassembled the tower frame using white glue (plain old Elmers, thinned). It turned out remarkably durable.
I formed the circular rails around the end of a drill bit, and tacked all the rails with white glue.
Vertical surfaces are painted with Colourcoats 5-N Navy Blue, and I painted the horizontal surfaces with 20-B Deck Blue, also Colourcoats. I overcoated everything with Floquil Flat.
I painted the searchlight lenses silver, then covered that with whiteglue after it cured. Then I painted the body of the searchlight 5-N, and overcoated with Flat. When that was dry, I poked a hole in the white glue "masks" on each light, soaked them in water till the white glue gave way. That left the silver "lens" intact. I put a drop of white glue over the "lens", and when dry, coated it with Future. I put some lightened highlights on the searchlights, and ran a black acrylic wash over them to bring out details.
I think our cats don't like the NO boat. Not only did one of them destroy the first kit I built, one of them dumped the water container overnight where I was soaking the searchlights. I could only find three lights, so I scavenged the fourth from the remains of the previous built.
From now on, I've been locking the pieces away in snap-lid containers.
Anyway, here's the finished searchlight tower.
![](http://i28.photobucket.com/albums/c244/wishbone99/PearlHarbor2013/02_zpsb0ae6445.jpg)
![](http://i28.photobucket.com/albums/c244/wishbone99/PearlHarbor2013/03_zpsae79896f.jpg)
![](http://i28.photobucket.com/albums/c244/wishbone99/PearlHarbor2013/04_zpsfc373276.jpg)
![](http://i28.photobucket.com/albums/c244/wishbone99/PearlHarbor2013/05_zpseed11e9b.jpg)
For comparison, below is a photo of the kit parts, from my previous, now-extinct NO boat.
![](http://i28.photobucket.com/albums/c244/wishbone99/USSNewOrleans/CS05.jpg)
Presently, I'm working on the seaplane cranes.
