First Annual USAF Vietnam Group Build
    February 2011
Posted by GreySnake on Monday, November 11, 2013 7:21 PM
Son Of Medicine Man
I would like to wish all of our United States Veterans a big THANK YOU!  Bow Down   for a your service in our United States Military.  And a special THANK YOU! to you Russ.  I think you are the only U.S. Veteran on this build, but if there are others, please don't remain silent and let me know!
Ken
Toast Hear hear! Thanks to all United States Veterans!
Won this guy on evilbay last night really happy.
    November 2010
Posted by Son Of Medicine Man on Monday, November 11, 2013 9:53 PM
GreySnake
Congratulations David!  Nice score!  Yes  Yes
Ken
    April 2012
Posted by Striker8241 on Tuesday, November 12, 2013 6:14 AM
Thanks, Guys, on behalf of veterans everywhere!
David: You got yourself a nice model there! "JV" was the tail code for the 469th TFS based at Korat, Thailand. We had some Ds at Takhli as well. BTW, if you don't already have it, here's a link to a list of F-105 tail codes:  www.burrusspta.org/105tailcodes.html
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Tuesday, November 12, 2013 6:54 PM
Striker8241
Cheers,
Russ
Very cool Russ!  Thank you for that link!  I made special note of the "ZA" tail code for Kadena AFB!
Ken
    February 2011
Posted by GreySnake on Tuesday, November 12, 2013 7:26 PM
Thanks Ken.
Russ, unfortunately the kit doesn't come with the 469th decals. They've been replaced 44th Tactical Fighter Squadron markings for Polish Glider. I'm going to see how the decals look when it comes. If they don't look good I am going to buy a Superscale sheet that does have the JV tail code. And thanks for that link very helpful!
David
    April 2012
Posted by Striker8241 on Tuesday, November 12, 2013 7:42 PM
Son Of Medicine Man
Striker8241
Cheers,
Russ
Ken
You're welcome, Ken! Big Smile  I also came across this list which covers most aircraft types in the AF:  http://www.au.af.mil/au/awc/awcgate/af/tail_markings.pdf
Cheers,
Russ
    April 2012
Posted by Striker8241 on Tuesday, November 12, 2013 7:44 PM
GreySnake
Thanks Ken.
David
You're most welcome, David! Looking forward to seeing that bird on its feet!
Russ
    November 2010
Posted by Son Of Medicine Man on Wednesday, November 13, 2013 5:54 AM
Hi Everyone,
I used a new product, at least it is new to me, from Model Master last night.  It is from a line of Enamel Stains they have put out.  The color I used was "Natural".
Here is the instructions from Testors website:
CreateFX Enamel Natural Stain is easy to apply.  Stir well before applying as stains settle. Apply stain with a fine brush around detail, seams, recessed and standing detail or apply evenly over entire surface.  Stain will naturally concentrate in corners and pull up flat surfaces.   To blend, thin or remove use 79256 Enamel Thinner. Let dry for 15 minutes, remove excess with thinner using either a moistened cloth or fine brush. Leave 24 hours for full cure. Recoating before then may result in blending of colors. Seal with clear coat.   Always test surface compatibility with paint on hidden area or on same type of surface that is not your finished project.
  • Thin paint 3 parts paint to 2 parts thinner
  • Adjust compressor to 20-25 PSI.
Of course you have to use this on a gloss acrylic surface.  I really liked the results and it worked pretty good.
Ken
    April 2012
Posted by Striker8241 on Saturday, November 16, 2013 6:54 PM
Hi, Guys,
I made a little progress, but frankly, I've lost interest in models lately - probably burned out after that Arc Light diorama. I'm sure the urge will come back but meanwhile, here are a couple of pictures.
Cheers,
Russ
This is the bunk area with the navigator's right console in place.
 This picture shows the galley equipment.
    November 2010
Posted by Son Of Medicine Man on Saturday, November 16, 2013 10:25 PM
Striker8241
Hi, Guys,
Cheers,
Russ
Hi Russ,
I am the same way.  I need a break every once in a while. You get so intense in doing these projects that you have to focus on something else for a while.  And that Arc Light project was a monster!  You put a lot of detail into the plane by itself, and then added a bunch more to the diorama!
By the way, very nice job there on galley and bunk area.  Great detail work!!  Yes  Yes
Ken
    November 2010
Posted by Son Of Medicine Man on Saturday, November 16, 2013 10:31 PM
Hi Everyone,
I got some work done on my air compressor today.  I should be able to have it back online tomorrow.  I have the valve plate soaking in lacquer thinner tonight to loosen up the burnt oil.  It was the valve plate gasket that caused the problem.  It had blown between the two cylinders.  I am hoping that the new one is made better so that it doesn't happen again.
Ken
    April 2012
Posted by Striker8241 on Sunday, November 17, 2013 8:49 AM
Son Of Medicine Man
Hi Russ,
Ken
Thanks for the good words, Ken! Big Smile
Sorry to hear about your problems with your compressor, but it looks like you have things well in hand. Mine is still in the box. I have to remove a glass sliding door and wall it up before I'll have a place to spray paint. It will probably be after the first of the year before I can do it.
Cheers,
Russ
    June 2013
Posted by Kiwi on Sunday, November 17, 2013 12:09 PM
Ken, this one on eBay looks like it has the part corrected that was faulty on your previous cockpits?
http://bit.ly/1bwymNB
    November 2010
Posted by Son Of Medicine Man on Sunday, November 17, 2013 12:40 PM
Kiwi
Hi Tim,
That looks more filled in, but you can see that it is still open at the top.  Thank you for spotting it though!  It should be all boxed in.  It looks like the mold may have a piece stuck inside and the people making the parts don't realize it.  Here is a couple of links to pictures showing what it is supposed to look like:
http://www.cybermodeler.com/aircraft/sr-71/images/frouch_sr-pit_02.jpg
http://www.cybermodeler.com/aircraft/sr-71/images/frouch_sr-pit_03.jpg
It should be easy enough to make the part myself, as soon as I get enough time to make it!
Ken
    June 2013
Posted by Kiwi on Sunday, November 17, 2013 2:59 PM
Ah I see Ken, that is frustrating eh, like you said, nothing some putty, a scalpel and a few beers ant make short work of!
I've totally lost interest in my skyraider and am thinking about acquiring a Dragonfly having just seen one in the local hobby shop.
I did win this last week after about a year of trying to get one at a reasonable price on evilbay.
I now have a complete flight line of 1/48 tamiya: Lancaster, mosquito, spitfire and hurricane. As soon as I have a typhoon kit I will build the five in tandem. The lanc was expensive but I turn 30 in January so I figured it was my early birthday present to myself, :-) perhaps there will be a Music of the Merlin's group build in our future Ken? ;-)
    January 2011
Posted by Tal Afar Dave on Sunday, November 17, 2013 9:59 PM
I'm an old Army Infantry guy myself; still kicking around in the reserves for a few more months.....then retirement and hopefully, more time building models again!!!  Hope to get started on this GB soon; great work by those showing their works!
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    November 2010
Posted by Son Of Medicine Man on Sunday, November 17, 2013 10:59 PM
Kiwi
Hi Tim
Congratulations on scoring that Lancaster!  Wow!  That thing must be a monster of a kit at 1/48 scale!
Hey, I have a few Spitfires in my stash along with some Mustangs.  You never know, we could have a Merlin build sometime!
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, November 17, 2013 11:02 PM
Tal Afar Dave
Good to hear from you again Dave.  We will still be here when you are ready.
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, November 17, 2013 11:38 PM
Hi Everyone,
Today was a scary day.
First we had tornados rip through the area.  Great job to the U.S. National Weather Service for giving us enough advance warning to take cover.  I grabbed my wife and dog and we drove over to my Mom's house since she has a full basement.  (She only lives 2.5 miles away.)
We got there just minutes before the storms hit.  Then the electricity went out.  Fortunately we were using a battery operated weather radio so we knew when it was safe to come back up out of the basement.  Everything looked okay at my Mom's house, just a few small limbs blown off of the trees, which happens every time we have a lot of wind.
So we drove back home and found one of our trees in the back yard had lost a huge limb and crushed our chain linked fence.  The wind was still blowing pretty hard even though the storms were past.
Then about an hour later a tree in a different neighbor's yard fell into our house.  Nice!  Fortunately it didn't do enough damage to cause immediate attention, but now I have two different claims to deal with.
The storms rolled through around 2:30 PM EST.  We usually have my Mom over for dinner and so I thought I better give her a call to see if her electricity ever came back on.  If not, her garage door was not going to open and she would need my help.  Sure enough the electric was still off so I drove over to help.
After we had dinner, I figured there was no sense in having my Mom go back home to a dark house, so we waited until 9:30 PM before it came back on.  During that time we started learning about all the damage that was done to places just north and south of us.  That indicated there was at least two different tornados since the storms were traveling in a west to east direction.
So we were sandwiched between two!  That was too close.
Anyway, I was determined to get my air compressor fixed today so when I got back home I went straight to work on it.
Here is a picture of the beast:
 Here is looking down from the top at the cylinders with the head removed, all cleaned up and ready for reassembly:
 Here is the side view:
 Here is the top of the valve plate, cleaned up (you should have seen it before I cleaned it!):
 Here is the bottom of the cylinder head, also cleaned up:
 Here is the bottom of the valve plate:
 Here is the new valve plate gasket:
 And here is the cylinder head gasket:
 Here is the culprit.  The blown valve plate gasket:
 And here is the pump all fully reassembled:
 I flipped the switch and she pumped right up!  Just like brand new!  So I am back in business!
Ken
    June 2013
Posted by Kiwi on Monday, November 18, 2013 12:24 AM
Wow, Ken, glad that you and yours are okay. That is pretty close to home eh. Are you near Illinois where they touched down? My in-laws are west of Detroit and I know they were watching it closely. Seems late in the year for this to be happening? Like you said, good job by the forecasters, hope everyone had somewhere to go.
    November 2010
Posted by Son Of Medicine Man on Monday, November 18, 2013 12:50 AM
Kiwi
I live in Lafayette, IN, pretty close to the Illinois border.
Ken
    April 2012
Posted by Striker8241 on Monday, November 18, 2013 6:09 AM
Ken,
Glad your house was not seriously damaged by those twisters and your family's ok. I've lived in Texas and Oklahoma so I know what it's like hunkering down during a tornado. Not a pleasant experience!
Take care,
Russ
    January 2011
Posted by Tal Afar Dave on Monday, November 18, 2013 5:55 PM
Scary stuff that Midwestern tornado scare; glad to hear that you weren't in the immediate path.  Seeing so much damage on the news.  You all will be in our thoughts and prayers.....
    November 2010
Posted by Son Of Medicine Man on Tuesday, November 19, 2013 4:48 PM
Well it is official.  Our county had two tornados Sunday.  The one in the north was a category EF-1, and the one in the southern part (the closest to where I live) was a category EF-3.  I am so glad it missed my house and my Mom's house.  I feel so sorry for those people it did hit.  There are a lot of people still without power.
I will most likely be cutting down both the tree against my house and the tree limb in the back this weekend.  I have a $1,000.00 deductible insurance so I don't have that kind of money to just hand over to someone else with a chain saw.  I will also have to take a look at the fence once I get the tree limb off of it.
Ken
    June 2013
Posted by Kiwi on Wednesday, November 20, 2013 9:27 AM
Again, not really relevant but wanted to show you guys why I'm not working on my skyraider:
    November 2010
Posted by Son Of Medicine Man on Saturday, November 23, 2013 9:01 AM
Kiwi
Nice work there Tim!  You are doing great detail work on the instruments!
Ken
    June 2013
Posted by Kiwi on Saturday, November 23, 2013 9:39 AM
Thanks Ken,
Any chance I could swap out my Franken-skyraider navy to USAF conversion and do this instead?
I picked this up this week and pretty excited about it whereas the skyraider has been very frustrating and needs some time out...
    November 2010
Posted by Son Of Medicine Man on Saturday, November 23, 2013 5:05 PM
Kiwi
Thanks Ken,
No problem Tim!  What version are you going to build it as?
Ken
    June 2013
Posted by Kiwi on Saturday, November 23, 2013 5:13 PM
Ummm... The one on the box cover? Haha I have no idea. I'll have a look at the options when it arrives and see if I can tear myself away from my Music of the Merlin's and F-14 projects. I only discovered the dragonfly a few days ago and then saw it was on your list. Neat little plane and I've always wanted to build a small side by side cockpit. Should be fun.
    February 2011
Posted by GreySnake on Tuesday, November 26, 2013 11:06 AM
Ken, I'm glad you came out OK from the storm. I lived in Ohio for two years and hated it whenever the sirens would start blaring. Glad you got the compressor up and running also.
Kiwi, nice work on that cockpit. Like Ken said those instruments look great!
As for me I've finally bought something I've been wanting for awhile.
No idea where I'll put a 1/32 PhantomAngry I'll wait till my skills improve before tackling it since its the most expensive model I've ever bought.
David
