First Annual USAF Vietnam Group Build
    November 2010
Posted by Son Of Medicine Man on Saturday, January 11, 2014 10:16 PM
Striker8241
Cool, Ken! Yes
Is this about the evaluation program over in Vietnam?
Russ
10-4 on that Russ.  It proved very successful, but unfortunately, the USAF still didn't consider using it in mass.  They still preferred the big bulky F-4.  We did however provide the VNAF with several F-5s.  When the North Vietnamese captured them, several were sent to the Soviet Union.  They tested it against the MiG-21, which won almost all fights.
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, January 12, 2014 12:33 PM
Son Of Medicine Man
Striker8241
Cool, Ken! Yes
Russ
Ken
I should have stipulated that the F-5 won almost all dogfights with the MiG-21 during the Soviet's tests.  It was a very agile aircraft.  In fact, it is still used as a training and aggressor aircraft by the U.S. military.
Ken
    April 2012
Posted by Striker8241 on Sunday, January 12, 2014 4:45 PM
Another perfect example of US thinking - if it drives like a Ferrari, how can we turn it into a dump truck? Big Smile
    November 2010
Posted by Son Of Medicine Man on Sunday, January 12, 2014 6:08 PM
Striker8241
Way too funny Russ!  Big Smile
Ken
    April 2005
Posted by taxtp on Sunday, January 12, 2014 8:08 PM
I wonder if there are any photos of Russian F-5s ? That would be interesting.
Cheers
Tony
I'm just taking it one GB at a time.
    November 2010
Posted by Son Of Medicine Man on Sunday, January 12, 2014 8:26 PM
taxtp
Cheers
Tony
Hi Tony,
I did find a video showing the Russians testing the F-5.  It is in black and white and the audio is in what I believe is Russian.  Here is a link to the page:
http://www.liveleak.com/view?i=e52_1320882209
Ken
    February 2011
Posted by GreySnake on Monday, January 13, 2014 7:45 PM
Nice score on the decal sheet Ken!
David
    November 2010
Posted by Son Of Medicine Man on Tuesday, January 14, 2014 6:03 AM
GreySnake
David
Thank you David.  The sheet is now out of print, so whatever is left on the shelves is it!  I picked this one up at Sprue Brothers.
Ken
    June 2013
Posted by Kiwi on Friday, January 17, 2014 8:46 PM
Tonight I got a couple of hours to work on my dueling F-102's, some cutting and trimming and a bit of cheeky airbrushing. I painted internal green on one and half of the other before my feet got too cold in the garage. I'll do some more over the weekend. Ken, I also just picked up a 1/48 SR-71, should be fun! :-)
    June 2013
    November 2010
Posted by Son Of Medicine Man on Saturday, January 18, 2014 12:23 AM
Kiwi
Hi Tim,
I don't know if you realize it or not, but one kit is the Case X wing type and the other is the later Case XX wing type.  Kit number 5518 (the one pictured on the right) is the older Case X wing, and kit number 5827 (the one pictured on the left) is the newer Case XX wing.
The Case X wing is flat all the way to the front edge and wing tip.  The newer Case XX wing droops on the front edge and all the way to the wing tip.  Only F-102 with serial number 56-1317 and higher had the Case XX wing.  Aircraft with serial numbers lower than 56-1317 had the Case X wing.
That is really cool that you scored these two kits!  That is also very cool that you scored the 1/48 SR-71!  We can compare notes on building them!
Ken
    June 2013
Posted by Kiwi on Saturday, January 18, 2014 9:17 AM
Wow! How do you know all that? That's awesome! I love learning all those little differences between the variants of the same plane. So interesting! Would the two ever have been seen together? Or did one kind of replace the other? I'm going to examine all the pieces today and see how accurate monogram got it!
    November 2010
Posted by Son Of Medicine Man on Saturday, January 18, 2014 10:17 AM
Kiwi
Researching the aircraft that I am building or are going to build is my passion!  USAF Vietnam era birds are my favorite subject.  Hence the reason I started this group build.
Yes, both variants were in service at the same time.  The Case X winged planes were never retrofitted to the Case XX wings.  And the TF-102 was the same way.  There were ones with each wing type.
The TF-102 was different than most other trainer conversions.  Instead of adding a trainee seat behind the trainer seat, they added the trainee seat beside the trainer seat.  This made the front fuselage wider, and they had to reroute the intakes to the engine.:
Ken
Ken
    January 2011
Posted by Tal Afar Dave on Saturday, January 18, 2014 6:15 PM
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    January 2011
Posted by Tal Afar Dave on Saturday, January 18, 2014 7:47 PM
So.....after I went by Michaels and located some glue, I put together the tail booms and wing in one assembly. Despite being an ancient Hawk kit, the parts went together well with little effort.
    January 2011
Posted by Tal Afar Dave on Saturday, January 18, 2014 8:51 PM
    November 2010
Posted by Son Of Medicine Man on Saturday, January 18, 2014 10:08 PM
Tal Afar Dave
Took many of the Skymaster's parts off the trees to see how the kit fit together with tape. Not too bad.  Next glued the wings and tail booms together and attempted to get them all lined up.
Will try to add a little detail to the sparse cabin; luckily there's lots of pictures on the Internet for ideas and reference shots of the instrument panel, gun sight, and rear radio rack....Put the kit window decals in place along the right fuselage and on the top wing. Will hopefully cut out openings for the clear window parts tomorrow night.  We'll see.....
Very cool Tal Afar Dave.  Yes, I have not seen any aftermarket cockpits or parts for the Testors O-2 kit.  So any improvement will have to be scratch built.
Here are some pictures from my collection:
Ken
    February 2011
Posted by GreySnake on Sunday, January 19, 2014 6:37 AM
Tal, Nice work so far.
Ken, Thanks for sharing those pictures.
David
    April 2012
Posted by Striker8241 on Sunday, January 19, 2014 12:23 PM
Great airplane, Guys!
Unsung hero is right! They were right in the thick of it. They flew low, unarmed and with very little protection from small arms fire. The only thing that gave them any advantage was luck. If I remember correctly, the aircraft had a pilot and a communications operator/spotter.
The bird was full of radio gear - note the antenna farm on top. The wire from the left wing to the tail is the HF radio antenna. This was a high-frequency radio used for long distance communications - you can talk to someone on the other side of the world with it if conditions are right.
The big whip antenna in the middle rear and the smaller one to the left rear were for communications on very high frequencies (VHF). The big blade antenna in the middle was also VHF probably for some special comm frequency; the smaller slanted antenna in the right rear could be VHF or UHF. The four smaller blade antennas were ultra high frequency (UHF) radio antennas used for navigation and comms. It looks like there may even be UHF antennas embedded in the tips of the vertical stabilizers.
The "handle bar" above the front windshield looks like some kind of direction finding antenna, possibly for locating targets.
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Sunday, January 19, 2014 12:59 PM
Striker8241
Cheers,
Russ
Thank you for that information Russ!  I always enjoy your personal experience on any subject we are modeling!
Ken
    January 2011
Posted by Tal Afar Dave on Sunday, January 19, 2014 6:16 PM
Got several replies while at work today.  Thanks for all the pictures, Ken!!  I've been studying them in detail since I got home and will definitely reference them during the build.  Thanks David and Russ for the encouragement and additional information. That's what makes the group builds so much fun. Lots of folks with so many ideas and information!!! Thanks!!
    November 2010
Posted by Son Of Medicine Man on Monday, January 20, 2014 9:51 PM
Hi Everyone,
Kitty Hawk is at it again!  They have announced that they are in the beginning stages of producing a 1/32 kit of the OV-10D!  The OV-10D would not qualify for this build but Kitty Hawk has also announced plans on making other versions of the OV-10 Bronco.  The most logical version after the OV-10D in my mind would be the OV-10A which would qualify for this group build.
Ken
    June 2013
Posted by Kiwi on Monday, January 20, 2014 10:28 PM
Detailing the cockpit, wheel and gun bays! Pretty interesting kit with a good amount of detail. I'll probably do the gear and intakes tomorrow. Most of the detail you won't be able to see unless you pick it up for a look which is a shame but it's still a cool kit!
    November 2010
Posted by Son Of Medicine Man on Tuesday, January 21, 2014 5:55 AM
Kiwi
Looking pretty good so far Tim!  Yes  Yes  Are you going to add the grey to the ejection seat?  Here is a shot of what it should look like:
Ken
Ken
    June 2013
Posted by Kiwi on Tuesday, January 21, 2014 1:26 PM
Hi Ken,
Yes I will - I haven't started on the seats yet. I painted the interior cockpit green too like the wheel bays and bomb bay. I'm not sure this is correct but it just seemed appropriate when I still had green paint left in my airbrush cup and I kind of like the color. The pictures I've seen suggest that it should be grey and black so I will likely change it to be accurate. I just like the way the cockpit details and instruments come up against a green background, and it's good practice for my Mig15 and Lancaster builds that will have that green interior. The bombays are really interesting on this kit. I like the scissor action. Must have been cool to watch them in action.
In other news, my SR-71 has shipped and I have ordered a resin cockpit and some other details for it. I think I'm going to go all in on this one and really try and make a good go of it. I look forward to building them together! :)
    November 2010
Posted by Son Of Medicine Man on Tuesday, January 21, 2014 10:04 PM
Kiwi
Hi Ken,
Very cool Tim!  That will be fun building the SR-71 together.  We can trade notes as we go!
Ken
    June 2013
Posted by Kiwi on Wednesday, January 22, 2014 9:17 PM
Ken, is there a Skunkworks Group build? That would be fun. Then I might get around to building my F22 as well, :)
    November 2010
Posted by Son Of Medicine Man on Thursday, January 23, 2014 5:20 AM
Kiwi
Hi Tim,
I am also sponsoring another group build called the Third Annual Berny Memorial Group Build.  There you can build anything!  It doesn't start for another month but you can sign up now.  If you are in a hurry, the Second Berny Memorial Group Build is going on now and you can carry over to the third if you don't finish by the end of it.
Here is a link to the third:
http://cs.finescale.com/fsm/modeling_subjects/f/29/p/158130/1711714.aspx#1711714
And here is a link to the second:
http://cs.finescale.com/fsm/modeling_subjects/f/29/t/151972.aspx?sort=ASC&pi240=1
Ken
    June 2013
Posted by Kiwi on Thursday, January 23, 2014 10:22 AM
Sounds perfect! I probably won't even touch the SR for a few months so that will work great.
That F102 ejection seat isn't in your basement is it Ken? It looks suspiciously like a basement! That would be pretty cool... What a great reading chair! :)
    April 2012
Posted by Striker8241 on Thursday, January 23, 2014 6:56 PM
Hey, Guys,
I need a source of 1/72 wheels about 9-10 mm tire diameter. I've been looking all over the internet but can't seem to find any - only specialty wheel sets for specific aircraft. Do any of you know of someone that makes custom wheels?
Thanks,
Russ
