Great pics of Scat XXVII! Thank you for sharing:
On to my progress: I was able to complete most of the cockpit tub this weekend to include the tubs, seat, Eduard ad-ons and the side panels. I've complete the front instrument panel, but I am still working the rear instrument panel.
I tried a different technique for highlighting the dark panels by using a dry brushing method that build up the color gradually while keeping the edges sharp. The seats were painted with a combination of acrylics and oils to build highlights and shadows, and make the seats and parachute feel like they are made of a fabric. The overall tub, panels and seats still need to sealed with a flat coat.
The front instrument panel was also drybrushed. I also used decal fragments and left over instrument panel decals punched out with a Waldron punch for instrument faces. The radar of the front panel was simply a disck punched out from a sheet of bare metal foil, then colored with Tamiya Clear Orange. I still need to seal the front panel with a flat coat. Rear panel needs more work, and I will also build up the reat of the panel with punched disks for the cableing and plastivard for more detail. I could use some help figuring out the color of the rear panels radar. Any takers?
Even thought the Academy kits has great instrument and side panel details, the panel walls were completely barren. I could not let this go. Now, aftermarket would have been a great solution, but I'm tired of dealing with fit issues and the crazy sanding and cutting that has to be done to make them look right (I'm looking at your Aries!) So, for the first time, I decided to scratchbuild the sidepanels. This actually turned out to be more fun than I thought!
Drew and outline of the panel of a very thin sheet of Evergreen card stock. For references, I used an older kits, and some online resources to build up the details of all the panels.
Rear panel complete.
Sorry about the poor photography! Panels complete...painting is next. However, I really enjoyed doing this, so I went ahead an began to add some other details to the cockpit.
I added this document...thingee over the right panel/pilot seat. This was based on my references, and looked easy enough to replicate. Well, that is all I have for now...I hope you like what you see so far.
