tigerman
I still haven't started.
So, ....., .... Start!!!
I spent the day doing one of my favorite things...., grinding sprue stubs off of road wheels. Even though it's PzIII, there are 44 wheels in all (including spares) and may have 4 attachments to sand...
To break the monotony, I glued on a few extra parts such as the sand bag armor...
I really like this resin kit, although it probably should be glued prior to adding the lights and klaxon. I couldn't get a snug fit without potentially breaking off those parts, so I ended up cutting a few sand bags off, sanding the edges smooth, and fitting the parts to this build. There is still room to add the accurate tracks between the front sand bags (to be added later).
Even so, there remained a gap between the sand armor and the placed armor plate which I filled with Aves expoxy putty. Hopefully, this will look like the sandbags themselves, but if not, maybe some sand spilling from the bags. The bags on the turret fit fine.
I also added a jerry can rack to the rear from the Dragon PxIII ausfN kit. In addition, the nicely coiled tow cables just looked too orgainized for an active war zone, so I left one cable coiled; the second will be added later in a position as if it was used and hastilly stored.
To be more realistic, I wanted the attached cable to sag in between its attachment points; this took a little CA glue and patience. I like the outcome, don't know if it is really visible in this photo.
The antenna also had a molding error in my kit, so I scratch built a replacement with brass parts from my extra parts box and plastic rod.
I'm pretty much at the point to prime and start painting, if the weather will just warm a bit...
Don
