Ju 87 Stuka GB
    December 2004
Posted by panzerpilot on Monday, March 31, 2014 5:44 AM
Thanks, Mustang. I'm hoping the Stuka goes as well as the Tony did!
I read where the Jericho Trumpets created a lot of drag. 15-20 knots of it! Yikes. Which, on the already slow Stuka caused them to be removed in favor of whistles attached to the bombs.
-Tom
    December 2013
Posted by schmidty on Monday, March 31, 2014 11:13 AM
panzerpilot
Do you remember where you read that, PanzerPilot?  I've read that as well, although I can't find anything definite...just passing remarks.  According to the German Wikipedia article, they only used them in the first half of the war.  But there is no attribution for that claim.
If this is true, my -G would almost certainly not have them.  Does anyone have any well documented information about this?  Is this more of a pilot preference thing, or were there actual "orders" to remove the Jericho Trumpets at some point?  Maybe at some point they just quit coming with them from the factory?
--Mike
On the Bench: 1:72 Academy P-51B
On Deck: 1:72 Hobby Craft DHC-3 (U-1A) & 1:72 Academy Ju 87G-1
    December 2004
Posted by panzerpilot on Monday, March 31, 2014 11:54 AM
schmidty
panzerpilot
The only reference I found was from Wikipedia, under the Ju87B paragraph. It actually says a loss of 10-20mph, (about 15 knots) The reference there points to this book:
Griehl, Manfred. Junker Ju 87 Stuka. London/Stuttgart: Airlife Publishing/Motorbuch, 2001
I especially like the paragraph on "diving procedure". Very interesting. Here is a link to that site, in case it's harder to find in Europe, etc.
http://en.wikipedia.org/wiki/Junkers_Ju_87
-Tom
Posted by Bish on Monday, March 31, 2014 12:02 PM
Mike, the G's definatly did not have them. The last model to be fitted with them was the D-1. And as the G's don't dive in the same way the bomber's would, there would be no point. The dive brakes were also removed.
I hadn't heard that about slowing the aircraft down, interesting one.
6 hours till kick off.
Posted by Bish on Monday, March 31, 2014 12:03 PM
Pilot, I think that must be the book I got recently, that I think Nathan mentioned. I will have a look later.
    December 2013
Posted by schmidty on Monday, March 31, 2014 12:05 PM
panzerpilot
Hmmm...I read that page too.  Or at least thought I did.  I guess I skipped right over that part! Embarrassed  Thanks Panzer!
--Mike
    December 2013
Posted by schmidty on Monday, March 31, 2014 12:10 PM
Bish
Thanks Bish.  The thing confusing me (other than my own poor reading skills, apparently Stick out tongue ) was that the Academy G kit seems to have them.  I didn't look super close to see if the propellers were in there, but the legs do have "posts" on them that I assumed were the trumpets.  I'll have to take a closer look.  Maybe they are just some sprue from the production process.
--Mike
    December 2004
Posted by panzerpilot on Monday, March 31, 2014 12:30 PM
No problem, Schmidty
Bish. If that is the book, the wikipedia reference lists pgs 64-65, about the jerichos.
Oh, so you are using UK time (GMT) as the startoff? That means I can start work tonight, Houston time! Cowboy Or, is that cheating? Confused
-Tom
    April 2013
Posted by SchattenSpartan on Monday, March 31, 2014 12:40 PM
I just had another look at the sprues of my Kanonenvogel and noticed that Hasegawa molded the siren mounts in place on the gear legs. Were they still in place on the real Birds after the sirens were removed or were they removed as well?
Posted by Bish on Monday, March 31, 2014 12:48 PM
Yep, it is that book. In full he says
''Once the enemy had become used to dive bombing attacks, the noise makers were removed, not least because of the speed loss of 20-25kph which they caused''.
he then mentions the noise makers put onto the fins of bombs. I think I have seen these, they may have been used from early in the war on bombs carried by standard level bombers. I don't have a pic to hand, but if I remember right, they look like a tube on the fin of the bomb.
Mike, you have to remove the stubs, if I remember right, the instructions do say that. Though I did just have to look at mine. Its odd as Academy never did a D-3 as far as I know, and early D-3 did have the stub but not the propeller.
Posted by Bish on Monday, March 31, 2014 12:50 PM
Clemens, I am guessing that Hasegawa's kit is also based on their D kit. You will have to remove the stubs as the G-1 was built using later model D-3's. But I know your doing a G-2, and no D-5's had them.
Posted by Bish on Monday, March 31, 2014 12:58 PM
Pilot, sorry, forgot the other bit.Yes, GMT it is (well, its BST now, 19.00 as I post this)
    December 2013
Posted by schmidty on Monday, March 31, 2014 1:03 PM
Bish
Thanks Bish.  I guess I should have taken a little closer look at the kit and the instructions.  Well, now I will just have to build an earlier variant so I can include the trumpet!
Regarding the bomb getting the whistle; the German Jericho-Trompete Wikipedia page links to a picture of the bomb on this page.  You can see the tube on the fin that Bish is talking about.  At least, I assume that is it.
--Mike
Posted by Bish on Monday, March 31, 2014 1:14 PM
Good find Mike, ye, that's it. I think I have seen some cases of two or even 4 being fitted to each bomb. If you look at the other fin, there are two loops attached for another siren. I am not how these work, I think they may have been a whistle rather than a siren as on the 87's fitted ones.
    July 2012
Posted by Tom68 on Monday, March 31, 2014 4:33 PM
Been following this thread since the beginning and wanting to jump in.  I’ve never done a group build; I’m recently back in the hobby after 30 years.
At that time, the last model I built was the Monogram Ju-87D.  Back then it was strictly OOB; no seam filling, no air brush; decals directly on top of the flat paint; no mods whatsoever.  I’ve still have that model (along with several others built that same way).
I’ve come a long way since then; still not anywhere near the great work I see other’s doing, but much better than I used to be.
So here’s my plan.  I’ve grabbed another Monogram kit and plan to build it OOB except using my better skills and techniques. The only difference in the two will be the technique.
It’ll be interesting to set the two side by side for a comparison.
I’ll probably start slow as I’d really like to finish the B-17 I’m currently working on.  Should finish the fort in a month or so.  In the meantime, I’ll be following along closely.
Posted by Bish on Monday, March 31, 2014 5:10 PM
Glad to have you on board Tom. Is that a 48th scale kit, I am not to familiar with Monogram. Feel free to post some pics of your older build if you wish, and while your following along, feel free to make any comments you wish, as you can see, the guys here do like to chat, 33 pages and its not started yet, well not quite. I will add you to the roster.
    July 2012
Posted by Tom68 on Monday, March 31, 2014 5:50 PM
Yes, 1/48.  I think I read a few pages back, that others are doing it as well.
I think I'll wait to post pics of my older build until I can also show something a little, shall we say, "nicer?"
Thanks.
Posted by Bish on Monday, March 31, 2014 5:55 PM
I was just checking the roster, and ye, we have 2 others building that one as well. No worries, add pics when ever you happy to.
GAF
    June 2012
Posted by GAF on Monday, March 31, 2014 5:59 PM
ALRIGHT!  STUKA VOR!
"Wir stürzen vom Himmel der Erde zu
An Wolkenbergen vorbei
Wir lassen dem Feinde keine Ruh'
Wir sprengen das Herz ihm entzwei
Wir schlagen die Gegner mit Mut und mit Kraft
Wir öffnen dem Sieger das Tor
Wir tragen das letzte Schicksal der Schlacht
Stuka, Stuka vor! Stuka, Stuka vor!"
(For inspiration only.)
Posted by Bish on Monday, March 31, 2014 6:00 PM
Ok guys, you may begin. And a nice way to start, thanks GAF.
Mustang, it was damn close, 499.
    December 2013
Posted by schmidty on Monday, March 31, 2014 6:01 PM
499 posts before this GB even opened.  This is going to be fun!!!
--Mike
    December 2004
Posted by panzerpilot on Monday, March 31, 2014 7:23 PM
Ok, folks! I''m all done. 1/32 Trumpeter D model. Eduard masks, Quickboost exhaust and props. I used Mr Color and MM paints. Thanks for looking.
April Fools!! (It's just a 1/144 scale, or so, metal toy I picked up somewhere years ago)
(Actually, I won't be able to start for a few days and I still need to clean up my bench Cool) Cheers! I look forward to seeing all the fine work.
-Tom
    September 2013
Posted by Raven728 on Monday, March 31, 2014 8:22 PM
Tom68, welcome aboard! I'm also getting back into the hobby after a long time away, and just started with group builds fairly recently as well, so you're not alone. Be warned: GBs can be very addictive. Ask me how I know. Wink
Funny, just yesterday I was drooling over examining the back of my kit box and noticed the stubs on the spats in one of the four Stuka images; couldn't figure out what they were but now I realize they're the trumpet stems. Odd thing is, they're visible on the 'Bulgaria, April 1941' version, but not the others, including the two from 1940. Hmm
- Steve
    March 2012
Posted by mustang1989 on Monday, March 31, 2014 8:52 PM
Ok fellas. I'll be editing this post later to show the kit flooring and the Aires flooring from the update kit that I am using. I am glad I test fitted the flooring in the fuselage first thing because it only touches one side of the fuselage and not the other. What tha hek???? For what I paid for this update kit one would think that it would fit better than that. Oh well that being said and my rant over, it's time to get to work!! I'm going to strip the kit flooring of detail at the pilots floor area and sand the floor from beneath the detail and seat mounting on the Aires floor and transfer the detail and seat mounting apparatus over to the kit floor along with that nifty foot pedal just aft of the gunners seat area. Will edit and show pics later when I get my computer back from my wife who is using it to take a medical exam for work right now.
The Aires part is on the left and the box part is on the right:
The transformation begins tomorrow at 4 am!!!Wink
 Forum | Modelers Social Club Forum (proboards.com)
    September 2013
Posted by Raven728 on Monday, March 31, 2014 8:54 PM
Well, I'm not going to start building right out of the gate, but I can post pics! Italeri 1/48 Ju-87B-2:
- Steve
    March 2010
Posted by Nathan T on Monday, March 31, 2014 10:59 PM
Cool! Good to see another Italeri kit here. Mustang- 4am? Hope you have the coffee pot programmed.
    March 2012
Posted by mustang1989 on Tuesday, April 1, 2014 4:54 AM
Nathan T
Dude, the coffee pot is always set for 3:45 am. Now, how much modeling gets done between that time and the time that I have to go to work are two different things. My jeriatric doggies sometimes do not allow for a whole lot because those guys are a friggin' hand full. But the coffee pot is ALWAYS set!
 As far as the Italeri kit Raven, that thing looks like its going to be a cool build. Lots of parts I see!!
As far as progress this morning,I started removing the detail from the Aires flooring as promised:
and here is the "part" I was after:
 and I removed all the pilots flooring detail from the Hasegawa flooring to accomodate that of the Aires variety.................
    March 2012
Posted by mustang1989 on Tuesday, April 1, 2014 5:23 AM
Bish: Thanks for the heads up on the post count. I knew I was going to be close on the post count!! LOL
    April 2013
Posted by SchattenSpartan on Tuesday, April 1, 2014 5:43 AM
IT HAS BEGUN!!!
Looking good so far, Joe! I prefer Chai tea because I get headaches from drinking too much coffee Embarrassed
Pilot: Now that was quick! Wow Wink
Posted by Bish on Tuesday, April 1, 2014 3:46 PM
Raven728
Its ok, your among friends, you can admit to drooling.
The sirens were not fitted until the later B-1's, I think after the Polish campaign. So its not uncommon to see pics of B's without them. And the siren mounts were fitted at the factory, but the sirens were fitted by the ground crew. There are a number of pics of Stuka's with the mounts simply faired over. I guess it could be upto the pilot of unit commander as to if they were fitted.
