50th Anniversary Vietnam War Group Build
    May 2009
Posted by Pawel on Sunday, April 19, 2015 1:48 PM
Bish - thanks a lot for your kind words - glad you like it!
Good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
Posted by Bish on Sunday, April 19, 2015 1:55 PM
Ye, I really do like that. I take it those are decals on the legs and in the bay, not seen that before. It adds a really nice bit of detail.
    May 2009
Posted by Pawel on Sunday, April 19, 2015 3:06 PM
That's exactly how it is - Hasegawa supplies technically accurate decals for the undercarriage parts in this kit.
Thanks for your comment and have a nice day!
Paweł
www.vietnam.net.pl
    November 2003
Posted by bobbaily on Monday, April 20, 2015 11:45 AM
Pawel-nice work on the detail-I'm not sure I am committed enough to apply all of the stencils of a modern plane.
Stik-an extension would be much appreciated-I've finally got all of the extras & paints for my Thud and have no travel plans for the next few weeks.  If not, no problems-I'm still planning on building it for the Monogram Mafia.
Bob
    July 2004
Posted by stikpusher on Wednesday, April 22, 2015 2:15 PM
OK, any projects already started and needing an extension are covered...
As for me, I am still chugging along with little bits of work here and there on my project. I have a wash on and have continued with detail painting of items on my 113
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2014
Posted by Rob S. on Wednesday, April 22, 2015 3:26 PM
Very fine work stik, very fine!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    October 2006
Posted by Archangel Shooter on Thursday, April 23, 2015 12:27 AM
Extension? Whew...I'm plugging away on the A-7. Got the gull grey and white applied. Mers are put together and needs painting.  Doing some sanding on the canopy seam that's right down the middle of the canopy.
Found one of the Hasegawa weapons sets and will be using a couple of the Mk-84's....go big! Also dug up a pair of Aim-9B Sidewinders, the kit has what appears to the the Aim-9M
The kit drop tanks are something I've never seen on an A-7 and looks odd so I may use a pair from the Monogram A-6 kit depending on the load-out I pick
Scott.
 Your image is loading...
 On the bench: So many hanger queens.
    July 2004
Posted by stikpusher on Thursday, April 23, 2015 12:41 AM
Archangel, I would suggest you try to find some AIM-9Ds for your SLUF. The Navy replaced the 9B fairly early on in Vietnam and the 9D was the type most commonly seen in photos when Sidewinders were carried...
       - Plankton
LSM
    February 2014
Posted by silentbob33 on Thursday, April 23, 2015 9:01 AM
Your 113 is looking really good Stik, I can't wait to see when you get to weathering.
On my bench: Academy 1/35 UH-60L Black Hawk
    July 2004
Posted by stikpusher on Thursday, April 23, 2015 3:15 PM
Thanks guys. I still need to do a bit more detail item painting, do the flat coat, then I can get the weathering done,,, soon...
       - Plankton
LSM
    November 2003
Posted by bobbaily on Thursday, April 23, 2015 3:24 PM
Stik-the 113 is looking very good-it's just a shame that all of the work that went into the interior isn't visible.
Looking forward to the weathered version.
Bob
    July 2004
Posted by stikpusher on Thursday, April 23, 2015 4:52 PM
Oh you'll be able to see most of the interior. I'll open it all up during the flat coat and before final weathering...
       - Plankton
LSM
    October 2010
Posted by peterjb on Sunday, April 26, 2015 10:22 AM
Hi, Been working on the raaf Canberra upto the painting stage run out of grey so have to order more.Wont be able to finish by the 30th a week longer to finish. Here are some photos so far.
    October 2010
Posted by peterjb on Sunday, April 26, 2015 10:25 AM
And two more.
    May 2009
Posted by Pawel on Sunday, April 26, 2015 10:54 AM
peterjb - looking good, especially the cockpits! Keep up the good work and have a nice day
Paweł
www.vietnam.net.pl
    May 2009
Posted by Pawel on Friday, May 1, 2015 5:47 AM
Hello!
So here's the next update - it was time to do some decaling. The kit I have gives you two paint options:  VAQ-131, AB-615 from the Mediteranean cruise and the VAQ-130, NG-614 from 1972. As can be expected in a Vietnam War GB, I wanted to do a Vietnam bird, and I found two photos of the VAQ-131, NH-615, BuNo 142403 from 1968/69 cruise, which was similar to the AB-615, so I decided to develop my own decals using the kit decals as dimensional help. That's what I did and a little companyfrom Poland called Malius Manu printed those decals for me. The biggest challenge was to get thin gray and white partition lines between some markings and the black stripes on the tail. In hindsight it would be best to mask the apropriate areas off at painting the stripes - but I didn't do that. My idea was to incorporate those gray and white borders in the decal - it worked with white, but wasn't doable for gray. So I did something else - I masked off and painted the right shapes on a clear decal sheet:
Then I put them on the model:
When this was dry, I put the decals on:
While not perfect, I'm quite satisfied with the results. The declas from Melius Manu react well to the mix of Micro Sol/Set, Mr Mark Softer and Solvaset - working withthem is a pleasure.
So now I'm putting the remaining decals on - hope you liked it, thanks for reading and have a nice day
Paweł
www.vietnam.net.pl
    January 2014
Posted by Rob S. on Friday, May 1, 2015 6:19 AM
Looks great Pawel..well done!
    July 2004
Posted by stikpusher on Friday, May 1, 2015 10:36 AM
Wow! That is looking mighty sharp there Pawel!
       - Plankton
LSM
    November 2003
Posted by bobbaily on Friday, May 1, 2015 11:51 AM
Very nice work indeed Pawel-looking forward to seeing the finished product.
Stik-I'm throwing in the towel-even with an extension, I don't know when I'll have the Super Sabre complete-started painting but now I'm debating on adding PE or not....I am planning on using it as my second build for the MM III though-I've got until Sept. 30 to finish it....
Sorry for the withdraw-hopefully the Vietnam Era GB will become a regular-too much history to not be revisited.  Thanks for hosting and running a great GB.
Bob
Posted by Bish on Sunday, May 3, 2015 7:03 AM
Really nice results there Pawel, a good idea for those decals.
    October 2006
Posted by Archangel Shooter on Monday, May 4, 2015 8:49 PM
I'm just about finish on the A-7. Decals are on, still need to smooth out the scratches on the canopy in my attempt to remove the mold seam down the center. Got the bombs painted and adding them to the racks now. Figure tomorrow if I don't have any interruptions I should wrap her up tomorrow or Weds.
    July 2004
Posted by stikpusher on Monday, May 4, 2015 9:45 PM
Sounds good to me AS. I got in a few minutes of bench time with my 113 this morning and got a bit more work knocked out: lead foil tie down straps added to the rear Jerry cans, and then I glued them in place. I also got the tow cable on the ramp painted. On my days off this week I just might get around to finishing this way overdue project...
       - Plankton
LSM
    October 2006
Posted by Archangel Shooter on Tuesday, May 5, 2015 6:08 PM
I'm going to call it this one done here. The Hobby Boss kit is okay but I do prefer the Hasegawa model as I feel it's has better details to the kit. This was out of the box, were I to purchase this one again I will get a resin cockpit. The decals were very good, laid down with no issues using the Micro-Set and Sol. Paints were MM enamels and the bird was a test bed for my new Badger Krome AB which is great!
The MK-83's and the M-177's are from the Hasegawa Weapons set, the M-82's came from the kit. I used a toothpick to do the data info on the bombs, hand brushed the stripes.
I had done pre and post shading which looks good to the eye but the camera is showing the bird much cleaner than it is.
Thanks for hosting the build, I enjoyed following all the builds here's, winners all.
Happy Modeling
Scott
    November 2003
Posted by bobbaily on Wednesday, May 6, 2015 11:53 AM
Very impressive build Scott-your attention to detail, especially the ordinance, pays off.
Bob
Posted by Bish on Wednesday, May 6, 2015 11:57 AM
Another nice build Scott, really nice work. Are the vehicles from hasegawa as well.
    October 2006
Posted by Archangel Shooter on Wednesday, May 6, 2015 12:14 PM
My last 2 builds were 1/24th scale birds and going back to 48th I had to squint a bit while working on the Corsair. I normally will add much more details to a kit but time was against me as I was wrapping up on my last GB.  The two support equipment been in a parts box for some 25 plus years??? The tractor is resin and I believe was from Verlinden and I can't remember who made the bomb loader. I do remember using them in a dio with the Hasegawa A-7 parked next to a couple of F-4's.
Posted by Bish on Wednesday, May 6, 2015 12:47 PM
Actually I don't know why I said hasegawa. I am sure they don't do the USN equipment. I know Verlinden do resin ones and its Fujimi that do the plastic ones.
    July 2004
Posted by stikpusher on Wednesday, May 6, 2015 1:48 PM
AS, that looks real sharp! Especially on the flight deck base with the vehicles! Thanks for joining in this GB! She has been added to the front page roster.
I gotta say though, you would think that this was an Air War GB with the lack of ground subjects in completed builds. I guess that I better get my 113 finished up...
       - Plankton
LSM
    May 2009
Posted by Pawel on Wednesday, May 6, 2015 2:09 PM
Scott - a very nice-looking SLUF, I like it a lot! Maybe a bit clean, but looks sharp, anyhow!
Stik - funny thing, of the few ground-themed subjects, even fewer were actually done - it's a pity. Even more sad is that we have had no sailors here. Well - I guess we can't help it any more.
Paweł
www.vietnam.net.pl
    July 2004
Posted by stikpusher on Thursday, May 7, 2015 8:50 PM
Yes Pawel, we had a good turn out of completed builds, but many more who signed up, especially land and water subjects, did not happen. Next time I hope...
Well this past week of so the urge to work on this has returned and I am now in the final phase... yes it is past due, but oh well... to quote Patsy, "It's only a model"
so in the past few days I have been doing little stuff getting the small detail painted up, like the machine guns & tail lights, plush dry brushing worn areas on the MGs and the pioneer tools. I also added some foil straps to some proper jerry cans in my spares bin and glued those in place. And then today I airbrushed on a coat of Humbrol Matt Clear (my personal favorite flat clear coat... absolutely dead flat and total control applied with an airbrush)... After that had dried I added the final top deck stowage of a tarp, some ammo cans & a crate... I still need to add some tie down straps for the .30 cal tripod...
Tomorrow I will paint the last details like headlights, tail light lenses, periscope lenses, add an antenna, and then final weathering after that... finish line dead ahead...
       - Plankton
LSM
