I spent some time working on putty this weekend... what fun!
The fuselage step and seams puttied and rough shaped with steel files... quick work with a new file.
and with the nosecone join line all gooped up...once this is all dried and shaped I'll go back in with a rigorous wet sanding and polishing to remove all the tool marks and scuffs and get the plastic all shiny smooth and ready for paint.
On the tail end, there's a complex-curve that needed a little love and putty... need to shape that back into a neat appearance. That green bottle contains my 'special mix' putty that is probably banned in most countries for its cancer-causing properties.
Its hard to see here, but I used a flat steel file to get a verticle surface around the wing roots. Kind of a tricky area to putty and work on as the wing fit and seam depend on keeping the lines straight. Alittle wet sanding and polishing gets this finished. The ares not puttied are hidden by the wings themselves, so i only worked on the places where the fuselage seam could be seen.
A quick check of the wing root join- it is damned near perfect out of the box, but with the putty work I have to make sure I didn't gouge up the upper surfaces or alter the seam line. So far, so very, very good.
And finally, an all-around test fit of the wings, fins and stabs to see where I need to do more work, or just stop before I trash something. It's begging the look a lot like a MiG-29M!
I've since added the speed brake between the fins and an engine air scoop to the spine. A bunch of wet polishing all-around and this will soon be ready for the small, breakable parts and paint.
