Ich bin sehr gut Dre danke, und du? Well I have managed to get the Mig to the painting stage and I thought what the hell I CAN do a NMF if I apply myself so, I think it's the way a mig 21 looks best and it just requires more preparation than usual, so I decided it should take a methodical approach, I know that gloss black enamel takes a day to dry and gloss black acrylic not so, so I got to work last night, after a week of prep I had a smooth surface and most of the lost lines on the joins back. The seams were not hard as the kit fits really well, the only part was for some reason the left wheel well would not sit in properly, I also had a small gap under the fuselage where the front and rear meet. I used the existing detail on the interior of the main wheel wells as a template and glued wire over the top to enhance the overall detail and it worked quite well as there are no resin sets I know of and I had no access to photos and this seemed the logical thing to do as the detail in this scale was too flat. I have to say the finish is far from perfect on the fuselage but I have not finished with it, I used ALCLAD 2 aircraft aluminum and it seems quite dark to me but perhaps thats just me, the finish of the black paint afetr I used micromesh to get is glass smooth was uneven but I think I can use this to my advantage when it comes to weathering as I want the mig to look used and in service, it will be on a base with a frost on the ground with the supplied aircrew surrounding it and I want to get a few more things going on around it too if I can, I just don't know what yet. Okay so here it is so far,
The plane is being built in sections as I think it will make masking various panels easier as the fuselage is basically a tube.
You can see the unevenness in the metal paint, I am still not sure if this will work to my advantage or not however I will hopefully get a good result, I have a great feeling about this one guys! One thing I also did that was new to me was to paint the engine matt brown and then drybrush silver over it, I saw it in a magazine and the results are actually pretty good, it gives a realistis heated effect.
I still have to add much to the fuselage but I think the next layer will be different metal shades on the panels. Possibly I might paint the avionics but I doubt I will have that showing as it spoils the look of the aircraft for me.
Last image you can sort of see the extra detail in the wheel wells on this one which was simply wire stuck where the detail was. Also I attached the nosewheel as per the instructions as I remember seeing a few of you guys saying the landing gear was weak so I thought I would use all the strength available so the strut was screwed in as per the instructions. One more thing I used toilet tissue to buff the surface of the alclad and it seemed to work quite well. Thats it for now, sorry I have been out of touch for a while, if anyone has pointers for me that would be appreciated. How is everyone elaes migs looking?
