Alright, I had some time with my Hurricane again. I used a leftover Eduard PE compass from my Spitfire VIII kit, the Airfix instrument panel decal, and a decal from a Tamiya Spitfire V kit for the harness. I don't love the harness decal, but I suppose it's better than nothing. I probably should have used tape, but I may close up the cockpit, in which case it will not matter.
I got the majority of the large parts together. The wing tops went down over the spars and the lower wings really well, and the cockpit sat nicely. I then glued the fuselage halves together and glued them on top of the cockpit/wings. **Those building this kit, here's a tip** - The fuselage halves do not cover the bottom (it is a separate piece for the underside of the nose, and a separate piece for the underside from the rear of the wings to the tailwheel. When I added those parts, there was a 0.5 mm step from them to the bottom of the wings (when sitting upright, the wings hang slightly lower than the fuselage). To fix this, I would probably sand down the wing roots slightly, or consider inserting a small strip of styrene to space the lower fuselage parts. In my case, some filler feathered into the front and rear of the wing will have to suffice.
I hope that makes sense, since it reads confusingly to me even now, but hopefully if you're looking at the parts it will make sense.
So here it is now - looking like a plane.
And here's a closeup of the instrument panel. It's a decal, and it went down well with some Micro Sol.
Next up is some filling of seams and then getting the elevators, rudder and a few other assorted parts mounted. Then paint!
-BD-
