Since last update, I've completed the main construction of the Peashooter, and have continued to work on details, either improving/replacing existing items or adding to.
Probably one of the most visible details missing are the support fairings for the rigging wires on the underside of the aircraft. Utilizing plastic sheet, the ends should be hollow some what to receive the wire, but there is only so much you can do in this tiny scale.
On the starboard side fuselage, there is a horn shape object. Not really sure what it is, but have hollowed out both ends and added a short bit of 0.3mm brass tube in the front.
Three items still remain, the pitot tube, gunsight, and blast tube extenstions for the machine guns. Notice these are all tubes, so I'm awaiting an order of some brass to scratch build these details.
In the meantime, I can start painting the engine and maybe lay down some white where the insignia will go. I plan to make my own decals on clear decal film.
regards,
Jack
