Modern Group Build - COMPLETED - THANKS ALL !!
Posted by Bish on Sunday, February 26, 2017 8:01 AM
Made a start on my second entry, Revell's 1/32nd He 162.
This won't go as fast as it might normally do as i am building it along with 2 other kits with all 3 being part of a seperate WiP thread.
This wa sthe first 32nd kit i bought and i got an Eduard BigEd PE set to go with it along with a few other AM parts. Work started by removing the moulded on detail in the pit and adding the PE side walls. This might bave been better left on as the PE parts are a bit to flat, especially for the ribbing along the sides, but it was to late by the time i spotted this.
And the rest of the interiour parts ready for some paint.
And then off to the paint booth for some primer and RLM 66.
Next i'll do some very light weathering and add the pre colured parts before putting all this together.
    November 2008
Posted by plasticjunkie on Sunday, February 26, 2017 9:37 AM
Dang Bish that looks awful familiarWink.  Looks great and I bet you find it easier to work with the pe than the 1:72 one .
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Sunday, February 26, 2017 9:49 AM
A little differant from your resin set though. Big Smile. Its like being in the land of the giants working on this, especiually switching from one to the other as i am at the minute.
    June 2014
Posted by BrandonK on Sunday, February 26, 2017 11:26 AM
Bish, that is gonna look very nice. And ya, the larger scale intimidates me a bit due to my nature of wanting to add more details. I think I would likely never feel I had enough. This is a cool kit and not one we see too often.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Sunday, February 26, 2017 11:31 AM
Thanks BK. I do tend to throw every bt of AM i can find at these kits. We seem to be a bit spoilt with them at the minute, what with PJ also doing the Revell kit, me doing a 72nd Dragon as well as this and we have at least one 48th kit about to be built.
    February 2006
Posted by DantheMan85 on Monday, February 27, 2017 9:24 PM
Thanks BrandonK.
Thanks Gamera.
Silentbob: Nice work on the A-6E cockpit.
Thanks Matt.
Bish: Great start to the He 162, looking forward to seeing this build.
Moving right along with the Eagle, after the glue and putty had dried over night I got to sanding. First started out with squadron course grit stick which worked great, some area's I used 400 grit paper. For the most part just sanding, a little grinding here and there. Then used 600, 1200 and finished off with 2000 grit sand paper. Nice and smooth seems.
 28 by Daniel Smith, on Flickr
 27 by Daniel Smith, on Flickr
 30 by Daniel Smith, on Flickr
Next up was gluing the vertical stabilizer's and horizontal stabilizer's on, I made a jig taped down with balsa wood and styrene strips. Popsicle sticks where taped to testor bottles to hold the vertical stabilizer's.
 36 by Daniel Smith, on Flickr
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    February 2014
Posted by silentbob33 on Monday, February 27, 2017 9:29 PM
Great work Bish, that PE really does the trick in that cockpit.
Dan, your Eagle is starting to look mean, and that's a neat trick with the jig.
I think I'm finally finished with the cockpit.  I did it OOB.  I'll probably go back and repaint the yellow on the ejection seat handles, I'm not really happy with how they look. There is flash on almost every piece so clean-up takes awhile.  And putting the seatbacks together was a pain.  I also realized Revell didn't include anything to cover the backs of the seats so I just put some styrene sheet in there to blank it off.  Any comments/critiques welcome.
On my bench: Academy 1/35 UH-60L Black Hawk
Posted by Bish on Tuesday, February 28, 2017 4:28 AM
Thanks guys.
Dan, the F-15 is looking nice and another good example of a home made jig.
Bob, nice work on that pit. Was just reading through your WiP thread, some nice info there.I didn't know what the TRAM was before.
Posted by Gamera on Tuesday, February 28, 2017 7:16 AM
Bish, Dan, Bob: Those all look great guys!
I really need to get more done on my F-16B but I've got a bunch of stuff that needs to be done first... Embarrassed
    February 2006
Posted by DantheMan85 on Thursday, March 2, 2017 9:18 PM
Thanks Silentbob: Nice work on the cockpit details.
Thanks Bish: Jig's always seem to come in handy.
Thanks Gamera: Looking forward to your F-16B.
After the glue had dried on the rear stabilizers, I glued on the nose cone. The right rear tail was not straight so I removed it and re glued and re-positioned it. Filling and sanding the rear stabilizers was pretty easy, the nose cone was not. First I used 400 grit sand paper, that worked on the sides and bottom, not so for the top. Had to bust out the 320 grit, and grinned the top of the nose till it was flush with the fuselage. A little filler was used. 320 grit really leaves scratched behind so I took extra time to polish them out with 1200 and 2000 grit sand paper.
 38 by Daniel Smith, on Flickr
 39 by Daniel Smith, on Flickr
 40 by Daniel Smith, on Flickr
Next up was building a stand, using balsa wood glued together with hot glue. All the layers glued together looks like a gingerbread house.
 42 by Daniel Smith, on Flickr
 43 by Daniel Smith, on Flickr
 45 by Daniel Smith, on Flickr
Next was antenna's and pylon's. I was going to leave the exhausts off but when sanding down a part that had been cut to, I took a little to much plastic off. So I glued the jet exhaust on. The pylons didn't meet up flush with the under side of the wing, only the two line up pines and the front and rear are making contact with the wing.
 46 by Daniel Smith, on
Flickr 47 by Daniel Smith, on Flickr
Only a few more parts to go and the Eagle will be ready for primer. Looking ahead the camouflage scheme will be a challenge to paint. Cool
Up Coming: ?
    June 2014
Posted by BrandonK on Thursday, March 2, 2017 10:20 PM
Dan, that is definately looking good. That's a -15 if I've ever seen one. And after watching you put this together you have given me several ideas for working with mine. Great job.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Friday, March 3, 2017 7:51 AM
Thanks Brandon:  Forgot to add, I used the box art as a guide for the antenna's, the kit comes with many different sizes and shapes. Big Smile
Up Coming: ?
    June 2014
Posted by BrandonK on Friday, March 3, 2017 9:04 AM
My F4-B is basically done. I have to attach the open canopies and take pics. I will post those up late today. Glad to have this one wrapped up; it was fun, but the amount of stencils about did me in.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2014
Posted by BrandonK on Friday, March 3, 2017 4:20 PM
OKay ! As promised, here is the completed Academy F4-B, VF-111 Sundowners.
What a splendid kit to build. Simply execellent throughout. All the parts fit perfect, or near perfect and this is a putty free build. The decals are simply the best I've ever used as I had absolutely NO silvering anywhere. I did have some wrinkle on the nose art, but with a complex curve I just could not get it down any other way.
I have plenty of flaws in my paint work, but nothing so bad that I can't live with it. Overall, I am quite pleased with the outcome of this kit. I will likely add the -C to my collection from Academy in the furture and do a camo Vietnam era bird.
If you haven't built this kit yet I highly recommend it, you won't be sorry.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Friday, March 3, 2017 5:46 PM
Now i do really like that BK. Really nice finish and great choice of markings. Got to be chuffed with that one.
    November 2003
Posted by tempestjohnny on Saturday, March 4, 2017 6:54 AM
Dan. Great looking Eagle.  Your stands and jigs are a great idea.
BK that is awesome.  Now I see why decaling took so much time.
    February 2014
Posted by silentbob33 on Saturday, March 4, 2017 8:30 AM
Great finish BK, that looks awesome!
    June 2014
Posted by BrandonK on Saturday, March 4, 2017 10:43 AM
Thanks guys, I appreciate the kind words. Even with all the decals, it was a fun kit. And you can't see half the decals in the photos either.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Saturday, March 4, 2017 8:26 PM
BK: That's a beautiful job! Makes me want to pull out a Phantom from the stash and build another myself!
Dan: Nice work!
    February 2010
Posted by 68GT on Sunday, March 5, 2017 6:03 PM
Gamera
68GT: Cool, that's one plane I still haven't built. Love the eye-catching blue on the tail, and is that a puffin?
Not really sure what it is but it looks like a Trojan helmet.
On Ed's bench, ???
Posted by Gamera on Monday, March 6, 2017 7:18 AM
68GT
Gamera
Ah that's got to be it. I've seen those markings before. Sorry my eye-sight isn't that good and it's not getting better with age... Blind Fold
    February 2006
Posted by DantheMan85 on Thursday, March 9, 2017 4:27 PM
BrandonK: Great job on the F4-B, excellent finish. Really like the colorful tail. I've been thinking about picking up one of those Academy F-4's.
Thanks Johnny.
Thanks Gamera.
Work continues on the Eagle. Last Friday the aircraft was fully assembled. I dry fitted the canopy on it is first perfect, lines up great.
 50 by Daniel Smith, on Flickr
 51 by Daniel Smith, on Flickr
 52 by Daniel Smith, on Flickr
 53 by Daniel Smith, on Flickr
 54 by Daniel Smith, on Flickr
 55 by Daniel Smith, on Flickr
Before I primed I masked off the cockpit, using Tamiya tape sticky side out, then placed a cotton ball inside. I used Model Master enamel gray primer #2737, letting each side dry over night. Filled in and sanded a few seems. Next up I pre-shaded with Tamiya X-1 Black. I covered the nose with the X-1 to make the gray darker, plan to use XF-24 Dark Gray.
 56 by Daniel Smith, on Flickr
The first base coat I applied was Tamiya XF-82 Ocean Gray.
 60 by Daniel Smith, on Flickr
Finished painting both AIM-9X and AIM-120C
 58 by Daniel Smith, on Flickr
The tip was painted Tamiya Gunmetal X-10, body MME Light Ghost Gray #1728, fins where hand painted Testors 1180 Steel.
 59 by Daniel Smith, on Flickr
The tip was painted MME Insigina White #1745, body MME Light Ghost Gray #1728, fins where hand painted Testors Steel.
The AIM-120C's are mounted to the side of the fuselage, the kit has you mount them under the wing to the pylon. I'm going to try and scratch build parts so I can mount my AIM-120C's to the fuselage.
 Clipboard01 by Daniel Smith, on Flickr
Up Coming: ?
    June 2014
Posted by BrandonK on Thursday, March 9, 2017 10:29 PM
Man, that -15 is looking really nice. I hope mine will build up half that good.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Friday, March 10, 2017 7:54 AM
She's looking really sharp there Dan.
Love how you left one sprue gate on the ends of the missiles for painting. Clever idea, I'm going to have to steal it from you.
    September 2014
Posted by rooster513 on Friday, March 10, 2017 8:15 AM
BK that F4 came out incredible! Beautiful finish!
Dan - nice work on the F-15! Coming together really good. Looks like a nice little kit. I haven't built a F-15 before so I may have to pick one of these up.
-Andy
Posted by Bish on Friday, March 10, 2017 2:36 PM
F-15 is looking real nice Dan.
Been playin a bit of catchup on the 162 last couple of days afer falling behind a bit. The Revell pit was finished off withthe remaining PE and some masking tape on the gun barrels, the idea coming from PJ's build. The guns in the Revell kit are pretty awful bearing no resembelance to the real thing. Good thing they can't be seen. I do like this PE pit, but if i was to do this again or be asked for a suggestion, i would go for the CMK resin pit that PJ has used.
And the ejecion set all ready to slide into place.
And the main wheel bay fitted with PE added. Still got to oput the indentation in one piece.
And then closed it up. Still got some clean up to do and finish off the wheel wells. Going to get those, the doors and undercarriage poainted before adding the wings.
More soon. I hope.
    February 2014
Posted by silentbob33 on Friday, March 10, 2017 7:38 PM
Dan that F-15 looks like a nice little kit, you're doing a great job with it Bish, the PE in the 163 looks really good, I can't wait to see how the others are doing
    June 2014
Posted by BrandonK on Saturday, March 11, 2017 9:56 AM
Bish, that pit does look good. Those upgrades are well worth it on any Revell kit. IMO
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2014
Posted by silentbob33 on Saturday, March 11, 2017 9:34 PM
It's been awhile but I've finally made a bit of progress on the Intruder.  I've got the fuselage together and the cockpit installed.  There was a bit of a gap behind the cockpit and the fuselage and some small ones here and there along the join.  I filled them with Testor's contour putty and spent the next week or so sanding it out and getting rid of the prominent seam line since there was a bit of a fit issue and there was a step along the entire join.  To protect the raised panel lines, I placed masking tape on top of the panel lines around the area I was going to sand.  Pretty time consuming but it worked and the seam looks pretty good to me.  I'll have to check it out when I prime it after I get the rest of the plane assembled.  I also primed and painted the landing gear bays.
    June 2014
Posted by BrandonK on Saturday, March 11, 2017 11:42 PM
Coming along nicely there SB.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
