Began playing with colors - as usual I had a fine time, but history got in the way of some plans. First, I borrowed a technique used by Andy (from Andy's Hobby HQ on YouTube - a very nice channel) who preps all of his armor with Tamiya NATO black and Tamiya flat white to create an abbreviated version of the "black and white" weathering technique. I've got a book from Spain about it, and it's an interesting concept. You use black, white and three intermediate shades of gray to create a gradually built-up kind of gigantic preshade before applying the base color. I'll try it some day, considering the white wash and heavy weather to come, I didn't think the elaborate modulation and tonal variations that result from "B/W" would be necessary. I used Golden High Flow white - and it spit a little which ticked me off. It was an old bottle, and a new one solved the problem. But considering the intent, it didn't really matter.
Blk-wht by Eric Bergerud, on Flickr
I did know that Panzer Gray is very dark. I also thought it was a "cool" color posessing some blue. Lots of good modelers use blue filters etc and it looks neat. That would have required creating a chromatic black (most of which have a blue hue - just cut it with white: that's how I create my German ship colors). But I looked into things and Dunkelgrau (or Panzer Gray) really isn't the color normally seen on models. It's very dark, close to neutral and, if anything slightly "warm" - it shows just a hint of green when cut with white but it's very subtle. I found many examples of Gray No. 46 (changed to RAL 7021 in late 1940) but it's tricky on a monitor. One source called for Vallejo Model Color 896 "German Ultra Dark Green Gray" which was a neat color. (I whipped up a really good airbrush brew with it. I used Golden airbrush medium and a polyurethene addative that comes with Mission Models Paint. If you don't mind waiting 20 minutes for the stuff to dry - probably due to both the Mission stuff and the Golden medium - it was great paint and applied splendidly. Obviously no tip dry.) But I'm pretty sure it was too warm. So instead I used Vallejo Granzer Gray Primer (RAL 7021) which I luckily had as a paint swatch. I was able to duplicate it nearly exactly with High Flow carbon black and neutral gray. To keep the tonality range on the surface I cut the paint big time: about 70% airbrush extender; 30% paint: applied in several coats at about 15 psi with a HS Evo with a .20mm tip. When you get used to High Flow it's simply terrific. It went on like really thin butter. I was painting for about 30 minutes and did no airbrush cleaning - I cleared the tip but I doubt it was needed. Naturally the airbrush was a snap to clean. (Those paper point dental tools are very nice for the thing HS nozzles and can't do damage.) This coat also took longer than Tamiya to dry - about 15 minutes. Do note that it's gloss. Because I cut the paint so much you can still see remnants of the white and light gray I put over the primer. It also lightened the paint a bit - although it's a little darker.
I'm actually pretty pleased. The base coat is as smooth as I can make it. Because applying the base so thinned, all of the details are perfectly sharp - zero excess paint. I'll actually be thinking of darkening the tank a bit with filters - even maybe with oils. But not much. Although Dunkelgrau was very dark, it was matt and quickly picked up dust etc and faded very quickly. But after looking at a tons of pictures and checking boards for the war gamers, I think that the World of Tanks guys that complain about German tanks being much too bright, too light and too blue are on the mark. (As one guy said, why would a tank want to carry a camo with a blue hue unless it served for the Kriegsmarine? Actually even the kit's box art shows a tanks that's a dark gray green.) Althoug the thing's already gloss, I'll coat it with Tamiya lacquer clear (I like spray cans) for decals and some pin washes. Then matt varnish and filters. And then..I don't know.
BTW: this tank carries markings for the 11th Panzer which was up to it's eyeballs in Barbarossa. According to Jentz/Doyle the D did not carry storeage and there are photos from the Balkans and Barbarossa training show it. They also show different levels of applique from what I can tell. (One photo shows some Ds towing wagons of fuel - they have big bundles of lots strapped to the back of the turrets: figure that.) Anyway, it ended up fighting in the Rzhev "Meatgrinder" southwest of Moscow in early 42 before joining Case Blue in the summer: didn't make it Stalingrad lucky for them but were hammered in the winter of 42-43. The division's order of battle in 1943 before Kursk shows only one battalion present in the OOB of June 1941. Ouch. Anyway, lots of room for dead Panzers during the desperate fighting against the Soviet counter offensive December - March 41-42.
Eric
base1 by Eric Bergerud, on Flickr
base2 by Eric Bergerud, on Flickr
