Nice work All,
Just catching up after being on a lengthy business trip. Haven't had a chance to build or post in almost 2 weeks.
Some more completions !
Theuns, That Catalina is nice. Quite striking in the silver scheme.
Keyda, The C-130 is nice too. Do you plan to show it at Noreastcon next month ? The Buffalo and Rochester IPMS clubs are hosting Noreastcon in Batavia on May 19 and 20.
Mike, the 410 is coming together well. Too bad about that twist - I've had that happen before too, But even with a pretty severe twist - its pretty hard to notice unless you are looking at it straight on. I suspect it will be the same with yours.
I'll offer one suggestion - because you asked . . . The german splinter camo schemes are strictly linear on the edges. The only thing I see that doesn't look quite right is the one rounded portion of the dark green on the port wing. Instead of a rounded "bump" like you'd see on a standard British scheme, the german spliter scheme would have that spot coming to a sharp point.
B-one, how are all those aftermarket parts blending with the kit's parts ? Looks like an extensive conversion.
Ed, The 188 is coming along nicely.
Hope to finish up the Blenheim cockpit soon. Just need some bench time.
Chris
