Well. got alot done yesterday, it was a quiet day, and my wife had to work, so no pestering from anyone, or anything. I like those kind of days... Heres some more WIP...
Wing sections and upper engine housings assembled, there will be a little putty work to do, but surprisingly very little from the looks of it.
Just a slight pressure to hold a slight gap closed while glue sets.
Moving right along.. Engines together, canopy taped and installed. I still need to file fit all the assembled pieces to give them a cleaner look. Gotta be careful not to disturb the panel lines or atleast be able to re scribe or recreate them if damaged.
As I said earlier, looks like very little putty work will be required.
Cut out those stupid indents and added ejection ports for spent shells, and opened up the gun ports. Really, if your going to go to the trouble of indicating them with an indent... Just open them up...
Well, everything filed and finish sanded to a cleaner looking fit. Used Qtips and Nail polish remover, (a cheap source of acetone) to soften and smooth putty. Saves on loads of sanding and smoothing. Thats about it for now... I can see already that I'm going to regret not doing more with Pit. Any way, Have a great day and Keep the Great Work Coming!
Doug
