Pride of the Luftwaffe GB
    November 2008
Posted by plasticjunkie on Thursday, January 4, 2018 11:17 AM
modelcrazy
 The stripes are all on one carrier sheet so I'll cut out each one but that won't be too hard.
It's best if you cut them separate as you said, this way you will eliminate any silvering that may show up after shooting the clear flat.:frusty:
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by plasticjunkie on Saturday, January 6, 2018 12:56 AM
Rooster
The scratch work looks great.
Steve
Looks like you are off to a good start.
Well I finally got the HGW belts and man they are a PITA to put together. As a matter of fact I wasn't impressed at all with them. You have to cut these things and the printed cut line is way off cause it's too wide for the pe buckles. I had to trim off more material so it would fit thru the pe buckle. By doing this, most of the printed stitching is lost. It took me 2 evenings to assemble these belts but the Eduard PE ones only takes me a few minites.
The package has another belt to be assembled and I will use it simply because I have it but I will not be getting this product again. I also had to paint the back side since it's just blank.
I drilled two holes with a #80 bit to attach the shoulder belts with very thin wire. I think the PE belts look better and have more detail than these but they will stay regardless.
I also used my mini drill bit to drill out the exhaust pipes and carefully cleaned them up with a blade.
    July 2014
Posted by modelcrazy on Saturday, January 6, 2018 12:56 PM
I'm sorry to hear about the belts PJ. The British Sutton belts look great but they are a lot of work. I guess they come short on the German belts.
Steve
Posted by Bish on Saturday, January 6, 2018 2:43 PM
Sorry to hear you didn't like the belts PJ. I know what you mean about them being to wide if you follow the line, that and the blank rear are the two problems i have noticed with them. Those belts are the original ones, they also do pre cut belts but they don't do many for specific types, just generic ones for German fighters.
    November 2008
Posted by plasticjunkie on Saturday, January 6, 2018 3:51 PM
Hi Bish
Yes you would think they would have the right dimentions for that cut line. And not a fan of that white back side. I painted mine the same color as the front sides. Thank God for Tweezers, the optivisor and lots of cuss words LOL!
Eduard make some that are fabric textured and are super cool looking and WAY easier to apply. Oh well, one needs to try something different once in a while.
    November 2008
Posted by plasticjunkie on Sunday, January 7, 2018 9:04 PM
This center part took lots of dry fitting and a couple of DeWalt clamps to get it to sit evenly then I hit it with Plast I Weld in a Touch N Flow applicator. The two sharp tips broke off and two tiny white plastic sheet triangles were fitted and melted in place by the glue. This is the only part so far that required some work for a god fit.
The wells were painted RLM02 and more lines were added along with a grime wash. Click on the image for an extreme closeup.
The cannon shell ejector locations were dressed up in the wing interior otherwise it's just dead space when viewed thru the ammo ejection slots. Pieces of plastic sheet were cut and placed where the cannon would be.
I feared that paint would give a poor bonding surface to these parts eventually becoming loose inside the wing so they will pe painted black after assembly. Now there's something there intead od dead space.
The tiny hood scoop was drilled open
And so were the wing cannons and nose guns
Beginning to look like a Dora
    April 2006
Posted by jgeratic on Sunday, January 7, 2018 10:13 PM
Pj, great upgrades on the details, but that plumbing in the wheel bay is just brilliant!
regards,
Jack
    September 2014
Posted by rooster513 on Monday, January 8, 2018 6:34 AM
I've got to agree with Jack on that PJ...the wheel bay looks awesome!
-Andy
    November 2008
Posted by plasticjunkie on Monday, January 8, 2018 8:57 AM
Thanks Jack and Andy! Used some stretched sprue and electric wiring for the added plumbing.
Posted by Bish on Tuesday, January 9, 2018 3:36 PM
Time for me to put in an apperance.
This is my first Tamiya aircraft and one thing i noticed with this and some of the other i have is that there is not much to it.
But it does look very nice and so far the fit has been pretty good as well.
Of course, i started with the pit, useing the Aires resin one.
After a coat of primer and some RLM 02, it was lightly weathered and the detail painted in.
I am doing a engine maintanence dio for this, so am useing the CMK engine. For that i need to remove the from of the kit fuselage.
I have out the resin engine together ready for painting. This one comes with the botom cover molded on, which i have not seen before even on a CMK engine.
With the pit ready that was fited and the fuselage and wings all put together.
And that it for now. This wil be my 5th engine maint dio, i rather like them as they give a good scene for activity. But hopefully this will have a little extra.
    April 2005
Posted by taxtp on Tuesday, January 9, 2018 5:07 PM
It all looks excellent PJ, impressive. Cheers Tony
I'm just taking it one GB at a time.
    November 2008
Posted by plasticjunkie on Tuesday, January 9, 2018 10:22 PM
Thanks Tony.
looks like a fantastic project Bish. Great little kit.
    November 2003
Posted by tempestjohnny on Wednesday, January 10, 2018 5:40 AM
Ernie that is coming along fantastic. Bish what a great start
Posted by Bish on Wednesday, January 10, 2018 6:48 AM
Cheers guys.
    September 2014
Posted by rooster513 on Wednesday, January 10, 2018 7:23 AM
Nice start Bish. Looking forward to seeing the dio come together.
-Andy
Posted by Bish on Wednesday, January 10, 2018 8:41 AM
Cheers Andy. I'll post some poics of the other bits to go with it and of what i am planning at the weekend.
    August 2015
Posted by crown r n7 on Wednesday, January 10, 2018 4:52 PM
looking good plasticjunkie and bish. moving along
 Nick.
    June 2010
Posted by 5-high on Thursday, January 11, 2018 12:21 AM
  hello guys and gal's
finnely got some time off work so id thought i'll share some pick's with you all.
dam its cold tonight ...-20c here in prince george b.c   BrrrrIndifferent . well ive done the camo and im pleased with the out come ..soon i'll be spraying the molting on the sides . so lets start with the intire upper surface's witch was RLM-82 ..then i rolled out the blue tack . and start'ed the upper wings and tail as seen here
    June 2010
Posted by 5-high on Thursday, January 11, 2018 12:30 AM
after i was satisfied i then got ready for RLM-83 . im trying for the stander'ed camouflage.
Posted by Bish on Thursday, January 11, 2018 12:45 AM
Cheers Nick
    June 2010
Posted by 5-high on Thursday, January 11, 2018 12:51 AM
 lol.....opps ...should have turn'ed that one around Embarrassed ..anywhoo..spray'ed on the 83 ..witch spray'ed like a charm . couple of light coats and walla she's done ..wait'ed the mandatory 24 hrs ..to take all that tack off ...its like opening a present lol . edges are a little heard but after some molting and weathering it should look the part eh. after i strip'ed the makeing off ,,i paint'ed the RV band yellow white yellow ..to depict the defense of the reich late in the war .
    June 2010
Posted by 5-high on Thursday, January 11, 2018 1:02 AM
so tonight i start on the underside with the leading edge RLM 66 ..after that its on to RLM-01 ..im still up in the air about depicting replacement panel's often seen on these dora's . oh here's a pick of the brass tubeing i use'd for the cannon's instead of the kits gun's
    June 2010
Posted by 5-high on Thursday, January 11, 2018 1:06 AM
well thats all for now ..hope you all like'ed it . there will be more to come .
cheer's 5-highToast
    August 2015
Posted by crown r n7 on Thursday, January 11, 2018 6:03 AM
a high 5 to 5 high ! nice masking
 Nick.
    September 2014
Posted by rooster513 on Thursday, January 11, 2018 7:38 AM
Great paint work 5 high! The brass replacement is a nice touch as well.
-Andy
    November 2003
Posted by tempestjohnny on Thursday, January 11, 2018 7:44 PM
Well this is coming along faster then I thought.  This is only about an hour maybe a little more. True Details seat
    October 2008
Posted by Rigidrider on Thursday, January 11, 2018 9:01 PM
PJ, excellent detail, REALLY nice!
Bish, great start...resin engine a plus...
5high... Good paint work... coming along nicely.
TJ... Emil looks good! The "E" is my favorite 109... Has a look all its own.
Andy, I was "yard sailing" about 2 weeks ago and picked up a Revell 1/32 190 D for next to nothing, already started, but just the engine built. It will have to be disassy, any way so if ok will you put me down for that as a next build?  I have to do a bit more research to come up with a staffel and color scheme. Keep up the great work all!  Thanks
Doug
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    November 2008
Posted by plasticjunkie on Friday, January 12, 2018 7:34 AM
5h
The Dora colors look great. Those brass tube guns also look great.
TJ
The Emil is shaping up great.
Doug
Thanks. Is the Revell Dora you got a ROG or the old Revell mold? If it's a ROG in a blue box then it's a Hasegawa rebox. If it's the old Revell one with the raised panel lines be cautioned about the incorrect wheel well configuration. The rest of the issues with it I can live with.
Posted by Bish on Friday, January 12, 2018 8:11 AM
Cheers Doug. I'll be adding a second engine to the scene as well.
    September 2014
Posted by rooster513 on Friday, January 12, 2018 8:25 AM
Rigidrider
Doug
Doug, that sounds good to me. I'll get you added. I got the new mold 1/32 Fw190 F-8. I'll be doing it for this GB but not till later in the year.
-Andy
