That's starting to really look the part Doug, your weathering brings it to life.
I've continued work on the 109, with an intention of getting it done this year.
Here, I've masked it up for RLM 65.
Light coat on RLM 65 on the fuselage sides to obliterate the overspray of the camo colours.
Reinstated the pre-shading to the fuselage sides.
I must have missed photographing it at this stage, sprayed it with Gunze RLM 65, then a slightly lightened tint in the middle of each panel.
Then I've sprayed the fuselage side mottle, trying to emulate the pattern that was on the real aircraft. I think it's a reasonable copy. It's quite a different pattern on each side.
I couldn't see that the mottle overlapped much on the upper surface colours, so maybe they had masked that before they sprayed the mottle. I've gone for that look.
I've since given it a couple of coats of Future, with any luck I can finish it this weekend.
I found that spraying the RLM 65 after the topside camo was good because I had less area to mask. I didn't really come up with a downside, but I've done it both ways in the past, and probably will in the future too.
Cheers
Tony
