Interceptors GB 2018 - CLOSED
    February 2010
Posted by 68GT on Sunday, July 8, 2018 3:36 PM
Thats a nice start on the 152.  I have one I want to get to one day.
On Ed's bench, ???
    June 2008
Posted by lewbud on Sunday, July 15, 2018 12:30 PM
Looking good SD!
Thanks 68GT.
Well, it's starting to look like an airplane now. Found a couple of seams that I filled after the pics were taken. Will be sanded and reprimed after I get home from work.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    February 2010
Posted by 68GT on Thursday, July 19, 2018 9:00 AM
Nice!
I'm a bit AWOL since I'm a Scout camp and reception is spotty.  Hope to get back into the swing of things when I get back.
On Ed's bench, ???
    June 2008
Posted by lewbud on Friday, July 20, 2018 12:41 AM
Thanks 68GT!
She went into the paint shop earlier this week and is now ADC Gray overall. The MM paint is pretty close, however being somewhat glossy I have hit or miss results on the model. Some areas are nice and smooth, others are kind of pebbly. Will have to revert to my car building roots and see if I can sand the offending areas smooth and then hit her with some gloss. I didn't take any pics of her before I masked, but here she is with a coat of Tamiya Semi Gloss black before I start with the metallics on the rear of the fuselage and the intakes.
Here is the rear of the fuselage. Paint is Model Master Stainless Steel. Detail on the petals is from the Eduard PE set.
Intakes should be done by tomorrow. Hopefully my decals from Fundekals will arrive tomorrow and she should be ready for decals Sunday.
    February 2010
Posted by 68GT on Wednesday, July 25, 2018 7:34 AM
Nice!
I almost got restarted yesterday but when I came home from work I cut the grass and that did me in.  Maybe today I will do some masking and painting on the Tomcat.
On Ed's bench, ???
    April 2005
Posted by taxtp on Wednesday, July 25, 2018 7:05 PM
That looks very good Lewbud. Cheers Tony
I'm just taking it one GB at a time.
    September 2017
Posted by Sailing_Dutchman on Wednesday, July 25, 2018 9:10 PM
I have finished the build:
And the cockpit:
Now on to priming, filling, masking, and painting.
Is there any way to get on the roster? I feel that I have not started yet as I am not on it.
    June 2008
Posted by lewbud on Saturday, July 28, 2018 7:42 AM
Looking good there SD!
It's been awhile since I posted here, but the F-102 is finished. The Meng kit overall isn't a bad kit, however, some areas are overengineered and it's fiddly as heck. Had a bit of a scare as I was cleaning up one of the wing fences. The masking tape pulled up part of the clear coat. Fortunately, a couple of coats of clear and it's hardly noticeable. Here's the pics.
68GT, thanks for hosting this build. For the front page, I like the next to last pic best.  Keep up the good work guys.
    April 2005
Posted by taxtp on Sunday, July 29, 2018 8:05 PM
Buddy, nice work on that kit. I've got one in the stash too, so your comments on the kit are pertinent.
Cheers
Tony
    February 2010
Posted by 68GT on Monday, July 30, 2018 6:47 AM
Sorry about that Dutchman,  I thought I did that already.
On Ed's bench, ???
    February 2010
Posted by 68GT on Monday, July 30, 2018 6:50 AM
Nice job on the 102!
On Ed's bench, ???
    June 2008
Posted by lewbud on Monday, July 30, 2018 5:09 PM
Thanks Ed and Tony! If this GB is still going on when I start the Case XX, I'll post it here. Right now I'm rescuing kits from the Shelf of Doom. I have a F-106, but it's already painted and ready for decals. You guys keep up the good work! Thank you Ed for hosting this GB.
    February 2010
Posted by 68GT on Thursday, August 2, 2018 9:54 PM
Thanks!
I think I'll just let the GB go till the end of the year and then no new starts.  This gives 5 months and then anyone who started in that time can finish when they have the time.
Me myself have been doing things to the house and with the family.  I have to get back on the bench.
On Ed's bench, ???
    February 2010
Posted by 68GT on Tuesday, September 4, 2018 12:39 PM
I actually sat down and did some building yesterday.  It was only some wheel painting but it was 5 sets of wheels and was a start hopefully.
On Ed's bench, ???
    February 2010
Posted by 68GT on Wednesday, September 5, 2018 7:37 PM
Sailing_Dutchman
Get any paint on this sucker yet?
On Ed's bench, ???
    September 2017
Posted by Sailing_Dutchman on Wednesday, September 5, 2018 9:16 PM
Yes, I did get it painted, but when I sprayed the TS-80 flat the can ran out and ruined the finish.
Does anyone know how to fix this? I was going to get a new can and try to spray over it in hopes that it would fix it, and if it did not work then use Purple Power to strip the paint and try again. Either way it will be a few weeks before I can get more flat clear.
    June 2008
Posted by lewbud on Wednesday, September 5, 2018 9:55 PM
What did you use for the color coats? If it was acrylic, you're probably out of luck other than sanding smooth and reshooting. As for throwing it in the purple lake, it's been my experience that Tamiya lacquers just laugh at Purple Power. I've had a car body sitting in the purple lake for about five years now and nothing has happened to the paint.
    February 2010
Posted by 68GT on Thursday, September 6, 2018 6:52 AM
Thats a clear lacquer isnt it?  How bad is it?
I would try to spot sand it and then give a few coats of clear gloss.  Aircraft in use were spot repaired all the time so getting a perfect match isnt really all that necessary and you want a gloss so your decals go down smooth and have no silvering.
Maybe try to use a fine scotch pad instead of sand paper.
On Ed's bench, ???
    January 2018
Posted by Jet Jaguar on Tuesday, September 11, 2018 8:58 PM
I haven't posted in a long time, just getting back to the bench after a long break.  No real progress on this kit, this pic is just a level set of where I left off.  Lots of small subassemblies, almost ready to come together all at once.  I'm going to do a wash on the weapon bays, then start the bulk of the assembly.
- Bob
    February 2010
Posted by 68GT on Thursday, September 13, 2018 6:53 AM
Good to see you getting back into this one!
On Ed's bench, ???
    September 2017
Posted by Sailing_Dutchman on Thursday, September 20, 2018 10:04 PM
I finished painting and decaling, but when I went to clean some overspray off the canopy I accidently used Tamiya Airbrush Cleaner instead of thinner. The clear was crazed and micro-cracks formed at the corners. I am contacting Dragon and should have a new one in a couple of weeks.
    February 2010
Posted by 68GT on Friday, September 21, 2018 7:39 AM
Do you think a light buff and some clear on it like Future might work on it?
How bad does it look?
On Ed's bench, ???
    September 2017
Posted by Sailing_Dutchman on Friday, September 21, 2018 4:43 PM
It is quite bad. I tried polishing it and putting it in future, but the erosion is to deep to fill.
  " alt="" />  " alt="" />
    February 2010
Posted by 68GT on Friday, September 21, 2018 6:17 PM
yeah, that's not going no to work.  You have to find a new one or fill it and paint it Black.
On Ed's bench, ???
    March 2006
Posted by simpilot34 on Friday, September 21, 2018 11:10 PM
Hey guys, sorry its been so long but been doing other things lol, bloody PS4Whistling Anyway some mighty fine builds have been made gents!!!! As for me I've lost the wind out of my sails on the F-106, just some things thatwould need to be machined off not just sanded in order for the fit to be right lol. Might get back to it but dunno. Started something else in the meantime to keep the *** embers going, 1/72 An-2 of a plane here in Oz that I got to take a ride on. 68 hope to jump back in with either something ele or the bloody dart soon.
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    February 2010
Posted by 68GT on Sunday, September 23, 2018 11:41 AM
Just jump back whenever you can!  I'll keep this GB open after January 1st to anyone that has started a build.
I'm in a rut myself and have done very little building in the past 6 months.
On Ed's bench, ???
    September 2017
Posted by Sailing_Dutchman on Thursday, September 27, 2018 10:39 PM
I have had no luck with getting a new part from Dragon, so I ordered a vac-formed Fw 190 canopy from trumpeter. With a little modding I can hopefuly make it fit, as the 152 was a high-altitude 190.
    February 2010
Posted by 68GT on Friday, September 28, 2018 8:26 AM
Ive never compared the two but might open up some boxes and see what my kit canopies look like this weekend.
On Ed's bench, ???
    April 2014
Posted by lostagain on Friday, September 28, 2018 8:48 PM
S_D, this is a spare from the Tamiya 190 D-9 1/48 kit. 14.5 mm wide, 49 mm long.
Yours if you want it, let me know.
    September 2017
Posted by Sailing_Dutchman on Friday, September 28, 2018 10:04 PM
Thank you, but I do not think that I need it. I have ordered one and it is on its way. I should have it in a few weeks.
