Another update on my Dora....I was gonna give Hasegawa a pass on the color scheme mistake on Michalski's Dora thinking the kit was older. The kit isnstruction sheet is from 2005 and the Eagle Editions decal sheet containing the updated information is from 2003 so Hasegawa should have done some checking since the info was out and verified in actual pictures.
But then the Eagle Editions sheet has Michalski's name misspelled as Michaelski so even they made a mistake. As a side note, 21st Century makes a 1/32 diecast model of Michalski's Dora and they actually got the scheme and name correct LOL.
The corrected left wing tip area has what appears to be a paint patch, or half painted. This part is clearly visible in one of the pictures in the Eagle Editions sheet so It's correct.
The right wing also has a filled in area forward mid wing with RLM83 and the top of the right aileron is a solid RLM75 cutting into the green area.
Most all of the larger decals are on. I still have to add several small stencils.
I was going to replace the guns with brass tubing but I drilled out the bores even more and painted them several shades of Alclad paints till I got the desired metal color. I then hand polished them with a soft cotton rag giving them a metallic sheen.
The wing cannons
and the nose guns
I was going to replace the loop antenna with thin brass strip but tried first to thin the plastic to see how thin I could get it and it actually looks to scale so I will be using the part as is.
There are a couple more plastic antennas I will be replacing with thin surgical wire I have courtesy of my late friend and former FSM member John Staworski who sent me a ton of this stuff some years back.
