Making progress fitting the belly pan but before buttoning her up I need to address mounting to the stand I got for her.
Measured the posts and drilled holes in a block of wood and epoxied to the inside of the belly pan.
After drying, I drilled through the plastic
Test fit...
And finally mockup with the belly pan taped into position - I believe this will work!
I just need to make sure I secure that belly pan really well.
