OFF TO THE THEATER! - African Operations of World War II - 2021 GB
    November 2008
Posted by plasticjunkie on Friday, April 16, 2021 6:19 AM
Armor_Aficionado
Wow! That interior looks really great! Can't wait to see the whole thing.
Thanks AA.
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by plasticjunkie on Saturday, April 17, 2021 7:10 AM
 The pigments look dark because they are wet from the fixer but once fully dry the color is lighter. Been working closing her up and restoring the thin weld seams using stretched sprue.
    November 2008
Posted by plasticjunkie on Sunday, April 18, 2021 10:16 PM
 Shot the dark grey paint and then decanted cheap hairspray from the Dollar Store and loaded my AB and shot a coat on the hull and wheels then was set aside for a few minutes to dry.  Silly Putty was used to cover the markings.
 About 30 minutes later Vallejo Ral 8020 was sprayed and set aside to dry  for about an hour then removed the SP.
Grabbed a firm short bristled brushb and tap water to carefully attack the hairspray coat. I'm pleased how the chipping came out.
Next stop, more weathering .
    March 2017
Posted by StugIIIG on Monday, April 19, 2021 7:16 AM
Hello, I know it's a little late but I would like to join this group build. I have a set of 1/75 Plastic Soldier M5A1 Stuarts that I intend to turn one into a M5. I've got it started, but there's lots to do on it. It will be painted and weathered for Aftica. I buy these multiple Gaming kits for my son and I to build. With Armourfast we each get one, the Plastic Soldier kits have three, so I'm converting one to the earlier model. I can post build progress as I chop and fill the turret.
JohnA
    November 2008
Posted by plasticjunkie on Wednesday, April 21, 2021 9:26 AM
Got all the hatches attached late last night. Some of the ones on the fenders were left open as part of a small vignette setting yet to come.
Will be doing groundwork, figures, weathering and stowage. Still lots to do.
    November 2008
Posted by plasticjunkie on Wednesday, April 21, 2021 10:52 AM
 Been messing around with wine bottle foil making some rolled tarps. Some paint on them and I think they will look pretty convincing.
I also found this old picture frame that will gime me a tad more space for the lads at rest.
Meet the lads that will crew the 8 rad. I've had these for a while so time to report to active duty.
    April 2019
Posted by John 3:16 KJV on Wednesday, April 21, 2021 9:53 PM
Good work, guys! That set will be a great addition, plasticjunkie!
Welcome SignStugIIIG! I'll get you on the roster!
     “For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
     For God sent not his Son into the world to condemn the world; but that the world through him might be saved.”  - John 3:16-17
    November 2008
Posted by plasticjunkie on Thursday, April 22, 2021 4:43 PM
Used an old picture frame for the base I had in the garage. The ground work was done and the lads are being assembled and mocked up to get an ida of the setup. The figures had several areas undercut with the UMM Scriber to add separationand depth. Some of the undersleeves were drilled out and hollowed.
The sleeves were drilled out and carved out were they meet the skin. Same around the canvassboot. Plenty of seam cleanup remains.
    April 2019
Posted by John 3:16 KJV on Friday, April 23, 2021 10:37 AM
I like the dog and those wine foil tarps! Good idea; and good work with the drilling, too!
    March 2017
Posted by StugIIIG on Sunday, April 25, 2021 10:30 AM
So here's my build progress start on the M5 Stuart.  I originally wanted to do this for the 1942 WWII GB but life being what it is I never started it.  I haven't done a lot of plastic models as an adult but have been wanting to get back.  I have a young son and have been buying Armour Fast kits that come with 2 models so we each can build one at the same time. I got a Plastic Soldiers M5A1 set with three models and decided to turn one into an M5.
20210413_182328_HDR
20210413_182331
    November 2008
Posted by plasticjunkie on Sunday, April 25, 2021 10:58 AM
I have been paintnight and dry brushing the uniforms to get some tonal changes. These guys are about 50% complete. Still lots of blending, dry brushing, washes and fine detail work to do on them.
I have my Osprey book covering the DAK uniforms which were really a plethora of tans and greens. Uniform colors could be from a light reed green, tan/kaki, light brown, to a bleached almost white specially the caps. Great color variation resulted from multiple uniform manufacturers and the effects from the harsh North African desert conditions.
    March 2017
Posted by StugIIIG on Sunday, April 25, 2021 10:58 AM
These are for the gaming gang, go together quickly and have no real fragile parts aside from gun barrels.  Here's the hull, ready for detailing and accurizing.
20210414_120820
I'm removing the front vent port (already done in this pic, awaiting a bit of putty), and up grade the lights and lift rings with wire.  I've already got some tests of this done on one of those extra hulls.  Here is a test, except I glued it on backwards.  Still experimenting trying to get the shape right then soldering on the little pieces that stand it away from the hull.
    March 2017
Posted by StugIIIG on Sunday, April 25, 2021 11:13 AM
I think that last pic is too big, I'll shave it down and see what happens.
Here is the turret as it comes in the kit (yeah, droopy barrel).  The M5A1 has the expanded bustle and MG on the side.  The M5 has the circular M3A1 turret.
Message_1618788018650
So I did a little surgery:
20210414_120846
And got out the Milliput:
20210418_175628_HDR
It was the first time I had used Milliput, and I found it really easy to get the general shape.  It did not require much sanding at all.
    March 2017
Posted by StugIIIG on Sunday, April 25, 2021 11:23 AM
Here's a shot of the turret after some sanding and a dry fit with a top piece.  Almost there.
Message_1618788554543
I'm just about to start making the sight ports on the sides and back of the turret.  I'm basically cutting coupons out of .3mm styrene and building it up too the right thickness, then making the cast "frame" out of Milliput.  I'll post that when it's done.  I'm going to make an MG bracket from cardstock and replace the way too thick post with more copper wire.  I'm going to add a tow cable made from twisted 24 guage wire that I've tinned to give it more stiffness.
    April 2019
Posted by John 3:16 KJV on Sunday, April 25, 2021 9:57 PM
Nice work on the little tank StugIII! Credits for taking the effort to detail and improve the kit! Big Smile
Plasticjunkie, those soldiers are turning out nice! Keep it up! Yes
PS- bufflehead, your Pz.I is looking good!
    November 2008
Posted by plasticjunkie on Monday, April 26, 2021 5:32 AM
Thanks John.
    July 2020
Posted by EricB on Wednesday, April 28, 2021 12:04 AM
I tell you what. If Finescale decides to keep sending posts my way (a real problem for a couple of years now) I'll enter the very very venerable Zvezda (Italeri) 1/35 Semovente M40 75/18 self propelled gun. The bad news is that it was new tool in 1973 - the good news is that a lot of after market stuff has come out - Tamiya even picked up the kit for a while. (Not that I'll be using after market - who needs detail when you've got desert weathering?)
So let's see.
Eric
    April 2019
Posted by John 3:16 KJV on Thursday, April 29, 2021 3:05 PM
EricB, Welcome Sign
I'll get you on the roster! The M40 was Italian equipment, right?
    July 2020
Posted by EricB on Monday, May 17, 2021 11:18 PM
Gents
I'd like to get started on my Zevezda Italian "tank annoyer". But I still don't think that I'm receiving any information from this Group Build or any other part of the Finescale community.
According to my Profile I am subscribed to no forums. I'm not at sure how to subscribe to a forum - the subscription as I understand it, takes place in the subforums - in this case "In the theater" Group Build. According to my Profile that is I get notifications from this group build - but I don't.
Over the last 12 years or so I've been on dozens of Finescale Group Builds - two years ago things came to a complete stop. For some reason, I was put back on the British Army GB for a few months but that's kaput too.
Does anyone know if I'm doing something wrong? Fee free to contact me if you do: rickt2@prodigy.net.
Best
Eric Bergerud
    July 2020
Posted by EricB on Monday, May 17, 2021 11:48 PM
Good Grief: I cleared my cache of Finescale cookies, logged out, and logged on and just received a message. Cross my fingers - let's see if I get another one - preferably from someone else on the list.
Eric
    April 2019
Posted by John 3:16 KJV on Tuesday, May 18, 2021 10:42 AM
Hey, Eric! I hope the emails will work for you. They haven't always been very reliable for me; recently they've gone to the junk mail folder. In my opinion, it's best to just check in on the website every now and again.
Your M40 will be a great addition to the build! I'm gonna have to whip out the airbrush sometime for my Wildcat and get going again.
    February 2005
Posted by Glamdring on Wednesday, May 19, 2021 9:17 PM
Gret looking builds going on here!  After a several momth hiatus, my little Panzer II got a coat of primer today.  Hope to lay down the Desert Tan this weekend, if the weather cooperates.
The Friuls also took a bath in burnishing fluid, but I think it went bad or something.  It was a batch I had from the last time I metal tracks.   I let them sit for an hour and they barely darkened, they may end up getting painted and washed if I cannot find the other unused bottle of burnishing fluid I bought way back when.
Robert
"I can't get ahead no matter how hard I try, I'm gettin' really good at barely gettin' by"
    August 2015
Posted by crown r n7 on Monday, May 24, 2021 5:51 PM
very good work gents... I'm in with a Trumpeter P-40B Tomahawk IIA (RAF) in 1/48.
 Nick.
    April 2019
Posted by John 3:16 KJV on Tuesday, May 25, 2021 3:27 PM
Welcome to the build, crown!
    August 2015
Posted by crown r n7 on Wednesday, June 2, 2021 11:35 AM
PJ. Nice job on that weathering, got caught in a few sand storms . Th figures look great right down to the sun burn! no sun block then lol.
Stug. That tank looking sharp.
up date on P-40. test fitting.
 Nick.
    August 2015
Posted by crown r n7 on Friday, June 4, 2021 5:43 PM
This it is real fussy, I hope my other trumpeter kits are not like this.
 Nick.
    February 2011
Posted by GreySnake on Sunday, June 6, 2021 2:41 PM
Finally started work on my build. The kit is going to be OOB other than a resin tank commander and some Archer dry transfers for the Afrika Korps markings.
In typical Dragon fashion the instructions are very “busy”.
Believe it or not it took me almost four hours to put all this together. Each suspension with the road wheels is built out of eighteen parts! There was a lot of cleanup involved due to how many points parts attached to at the sprue.
    July 2006
Posted by bufflehead on Sunday, June 6, 2021 7:28 PM
Hello all!  Been away for a bit but had some time today to get caught up (finally) on the GB!  Had to backtrack quite a bit to see everyone’s great work.
keavdog – sorry I missed your awesome Bf-109E Trop.  Great camo job….I never had a liking to German fighters in desert camo, but seeing yours…well, its inspiring me to do something similar in 1/72 for the GB!  Congrats on a fine build!
Armor_Aficianodo – Sweeet looking Bedford truck!  You did a bang-up job on that Italeri kit…really love the homemade canvas top! So much better than plastic!!
Glamdring – looking forward to that vintage Tamiya Pz. II being completed!  I’m impressed with all the detail work you’re doing to bring the detail up a few notches!!
Plastijunkie – oh Man that Sd. Kfz. 263 is looking soooo good in the worn desert paint scheme in that cool dio!  Super work on the weathering, the wine foil tarps and the figures.  I hope my little Pz.I looks half as good!
StugIIIG – that is one little M5!  Kudos for all the detail work on that tiny tank!
crown r n7 – Oh yeah!  Shark mouthed P-40 in the desert!   Is that Trump kit new?  I don’t think I’ve seen it before.
Greysnake – Nice!  That Dragon Ausf. E is the perfect kit for this GB!  Eagerly anticipating the finished build!
John 3:16 KJV – Thanks for the website link on the Wildcats of Operation Torch!  Great reading!  I have this kit in the stash and I’m paying attention to your build for future reference!
Though it’s been several weeks since my last post, I have been slowly plugging away at the Italeri Crusader Mk. I tank.  I’m happy to say assembly is almost done….I’ll post an update in a day or two.
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    February 2005
Posted by Glamdring on Monday, June 7, 2021 11:02 AM
Great work going on here!
As I hop around on my multiple projects, the Panzer II got it's bench time.  Because of the cavernous interior that is visible through the engine grates, meant for a battery pack on the old motorized version, I inserted an old gift card and paintedf it Panzergrau.  I comtemplated grabbing some greeblies from the spares box but it just seemed like wasted effort.
The desert tan has been laid down, the road wheels installed along with the AM MG34, and tools and muffler hand painted.  I think I will decal it tonight, if all goes well:
Robert
    April 2019
Posted by John 3:16 KJV on Monday, June 7, 2021 4:40 PM
Crown, the Tomahawk is coming along great; and Greysnake, my sympathies on the wheels...that's the down-side to German armor I guess... ;)
Glamdring, I like the rust on the back of  your Pz. 2 and that wooden box!
Bufflehead, I'm glad you enjoyed the article! I figure the Wildcat is a unique subject for the N. African Theater considering how tightly it's associated with the Pacific Theater. Add on the fact it fought American tech=fun build with a backstory. I'm honored that you'll be monitoring my build for reference! I'll keep a lookout for your build updates, too. :)
I have to get out and airbrush again still; but in the meantime, I painted the canopy lines and the pilot.....
AND......started yet another Wildcat, in 1/48 this time. I intend for it to be another Op. Torch one. My progress is limited to the cockpit so far:
The Kit
& the Cockpit
