BK that looks awesome. Putting down yellow and reds is always a chore, particularly together. Well done. Going to be quite the eye catching bird when done. Any story behind those markings? Formation bird?
Thanks,
John
keavdogAny story behind those markings? Formation bird?
BK
On the bench:
Tamiya 1/35 M4A3E8 "Fury" with crew,
1/32 Kittyhawk Kingfisher,
1/35 Meng Panther Ausf A Early,
1/48 Pro Modeller P-51C "Boise Bee"
2022 Completed:
1/25 Revell 29 Highboy
1/48 Tamiya Sea Harrier
1/25 Revell 70 Boss 429 Mustang
1/48 Hasegawa D3A1 Type 99 Val
I started on IJN Shimakaze. Not much so far.
Big sheet of PE. To be honest I've never liked the stuff. I'm try to find some way to muck my way though it.
And a special set for the linoleum deck. Not sure how to handle this. I think I'm going to try to finish the kit and then attach them instead of trying to mask all this.
Gamera I started on IJN Shimakaze. Not much so far. Big sheet of PE. To be honest I've never liked the stuff. I'm try to find some way to muck my way though it. And a special set for the linoleum deck. Not sure how to handle this. I think I'm going to try to finish the kit and then attach them instead of trying to mask all this.
Ok fella's it's time I got my skates on. This is an old Nichimo 1/48th Kate. Not sure how the decals will go, but the kit itself is really nice for it's age, so the only problem I'm expecting is the builder.
CB: The Shinden looks fabulous.
Gamera: I hope your back has settled down - aint age a ***! The amount of PE on the Shimakaze would scare the living daylights out of me - good luck mate.
Svezda: I love the paintwork and detail in that pit.
Crown: That is an awesome metal finish on the F86D!
BK: What an amazing paint job! The masking work that that must have taken is hard to imagine.
Cheers,
Ferg
I long to live in a world where chickens can cross the road without having their motives questioned
Looks cool Ferg! Love those old vintage kits!
Brandon: Thanks! I'm thinking of just spraying the PE fret with the same grey I'm using for the ship and then cementing everything in place with Gator Grip and touching up any places where the paint chips off.
Sorry I haven't been around. My back is fine. The pollen has been giving me a headache though. That and one of the guys at work has been taking a lot of vacation/holiday time so I've been working some weird hours.
CB did a great job, but if he wants credit for doing a Shinden, he's going to have to build another model! It's really confusing because the names are so similar but CB built a Shiden, which is Violet Lightning in Japanese, George to the US. The Shinden is that late war pusher, and the Japanese called it Magnificent Lightning. I don't think the Allies gave it a name.
I made a start on the KI-46, which is a Ki-46 III, the smooth nosed recon version. Here's a bunch of pictures of the kit and the little I have done. I don't plan to use much of the PE, mostly just the instrument and radio panels, and seat belts. Mr. Color Mitsubishi interior green. The wheel wells have a seam running right down the middle, I got them as even as possible and scraped the seams, and used a dremel with a burr on the domes for the tires. I put thin glue on to melt the join, and will probably have to add some filler. The Tamiya glue is a different type I have not used before, it is supposed to be a resin and is rather heavy bodied. Anyone have any experience with it?
To see build logs for my models: http://goldeneramodel.com/mymodels/mymodels.htm
John: I went back and looked and I put down Shiden for CB. Or at least I think so, I'm getting a little senile.
I built that kit a few years ago, it's a great kit. Not sure what to do about the seam, I think you've done the best way to fix it. I don't remember how I fixed mine or if I even did. Not sure about the different cement, I've never used it.
Cliff, you have it right on the first page, I was referring to the posts while CB was building. Just my warped sense of humor in view!
I think I'll get those seams to disappear, probably after several hours of fill and sand. It's a challenge now.
It's almost right on the roster--not sure who this 'cbaltin' guy is..
John, nice catch, all this time I thought I built a Shinden...
jeaton01 Cliff, you have it right on the first page, I was referring to the posts while CB was building. Just my warped sense of humor in view! I think I'll get those seams to disappear, probably after several hours of fill and sand. It's a challenge now.
On the Bench: Too Much
Good pick up John. I live and learn. Nice start to your entry. Is it a different model of the Dinah?
Dodgy, the Ki-46 II had a stepped windscreen, while the Ki-46 III had a windscreen that faired smoothly into the nose. The Ki-46 III Kai went back to the stepped windscreen and also had armament. The Ki-46 III was a pure recon airplane without armament. There was also a trainer version also with a stepped windscreen and a humped greenhouse. That version is almost not pretty.
This kit is just falling together, there are not that many parts and they all just click together. I did add some of the Eduard set but not much, but still it seems worthwhile, especially the instrument panel. I did almost completely cover the seams in the gear wells and if I had worked a little harder putting the parts together it would have been less work. Probably will never be seen again. The wing to fuselage fit is particularly good. As is my usual, I modified the propellers and engines with music wire and brass tubing so they are free spinning and removable. I've never been able to get the props to be free turning with the provided black bushings that Tamiya and Hasegawa kits have.
I used Gunze Mitsubishi interior green for the interior with a little dry brushing with aluminum for wear.
That looks great John, nice work!!!
As re Shiden/Shinden I mixed 'em up a few times at first until someone, I don't remember who straightened me out!
Thanks, Cliff.
More progress to report on the Dinah, the major parts are together and a lot of minor parts are painted. The engines and exhaust are Tamiya XF-56 metallic grey. I added a brown wash to the engines but doubt it will make much difference as the cowls are pretty tight. I intend to mess the exhaust up a bit after assembly. I filed flats on the main wheels to give as bit of a weighted look. The main gear struts will eventually be aluminum. Not all that happy with the area in front of the instrument panel, just looks messy in the pictures, and the area closest to the panel should be very dull and it's not. . The parts breakdown on this kit makes assembly and painting very easy. (Casts a frown toward the in progress Hobbycraft CF-105).
Looks good John. Do you have any experience with the LS 1/72 kit? Been thinking of getting that one...
Looking good, John. Don't beat yourself up on the instruments, the camera picks up far more than our eyes do. I find I like my work until I see it in pics, then I kinda hate it. Really does look nice.
CB, I have an L&S kit, 300A No 2 is the number, if a Ki-46 II, is that the one you are thinking of?
And thanks to both of you.
jeaton01 CB, I have an L&S kit, 300A No 2 is the number, if a Ki-46 II, is that the one you are thinking of? And thanks to both of you.
Just curious about the LS kit in general John, if anyone has built any version of it and what there toughts are. I found some stuff on goodle. Seems likea decent little kit.
cbaltrin jeaton01 CB, I have an L&S kit, 300A No 2 is the number, if a Ki-46 II, is that the one you are thinking of? And thanks to both of you.
jeaton01
I'll get it out tomorrow and have a look.
I put the glass on the Dinah tonight. Unbelievably I had to touch two of the small windows up to get them to snap in like all the rest. Where is their quality control
Lol, gotta love Tamiya!!!
Finally completed two other gb subjects and will start on my entry very soon.
Sounds awesome Steve!
I got all the glass masked and painted IJA grey on the bottom. Used some Floquil IJA Light Grey over a mottle of Model Master Dark Sea Grey. I hope the light grey is dark enough. This is the first IJA airplane I've built, after many IJN birds. The bottom is almost all masked so maybe tomorrow I can get to the top side. I plan on using Tamiya XF-13 for that.
Sounds great John, looking forward to pics!
Wait, there's more!
The painting is done and weathering has begun. The wing markings were painted on, but I used decals for the aft fuselage and tail markings. The decals were Scalemaster Invisiclear in this kit. I sometimes have issues with Invisiclear decals but not so far, although they haven't reacted much to Microscale red bottle after the first application.
jeaton01 Wait, there's more! The painting is done and weathering has begun. The wing markings were painted on, but I used decals for the aft fuselage and tail markings. The decals were Scalemaster Invisiclear in this kit. I sometimes have issues with Invisiclear decals but not so far, although they haven't reacted much to Microscale red bottle after the first application.
The paint looks very good John. I find Set and Sol useless on decals. Have been using Solvaset for decades and works every time in giving the decals a painted on look. Love using the product.
Thanks, Ernie. I have a pretty good selection of sets and sols, don't really know why I go with Microscale stuff first except that it won't hurt the decals if they don't like strong solutions. If I get really mad I've got some Walthers. The decals have settled in pretty well now. The panel lines are very fine on this kit.
John you got me mixed up with Steve aka Modelcrazy. We have similar Eagle avatars .
Ah, sorry. I knew I was going to do that someday. Ernie, right?
