Macross GB
    July 2005
Posted by painklr on Sunday, November 6, 2005 11:51 PM
Vinman, put me down for 1/170 scale. Super Valkyrie VF-1S. Will be starting this week. Will keep the GB posted.
    November 2003
Posted by ghettochild on Tuesday, November 8, 2005 11:56 AM
got sniped on ebayCensored [censored] so still no kit, does anyone know is squadron sells the Hasegawa kits? I couldnt find them on the website.
-Josh
Posted by Anonymous on Tuesday, November 8, 2005 2:42 PM
HobbyLink Japan has quiet a bit of stock at the moment:
http://www.hlj.com/hljlist2/?Dis=2&MacroType=InjKit&from=detail&Word=Macross
    November 2003
Posted by ghettochild on Tuesday, November 8, 2005 3:05 PM
thanks zen ill check them out
-Josh
    February 2004
Posted by Trigger on Wednesday, November 9, 2005 11:43 AM
Okay, I can't resist. I've got a VF-19, VF-22 and VF-0 ready to go. I want to finish up two existing GBs first before I start on those, but I'm in!
------------------------------------------------------------------ - Grant "Can't let that nest in there..."
    February 2004
Posted by Trigger on Wednesday, November 9, 2005 11:52 AM
Cobrahistorian just sent me this link which I think y'all will like. http://video.google.com/videoplay?docid=8325577713966755008&q=macross
It's not directly related to modeling, but should provide a great source of inspiration for this build
Posted by Aurora-7 on Wednesday, November 9, 2005 1:36 PM
Here's where I had left off on my Hasaegawa VF-1A Battroid a few years ago. Just a bit more construction to do and then to start finishing.
    February 2004
Posted by Trigger on Wednesday, November 9, 2005 1:37 PM
Here are a couple more Macross links that could be helpfull:
http://www.macrossworld.com/macross/magazines/_magazines_hobbyjapan2001-2003.htm
http://www.macrossworld.com/macross/magazines/_magazines_modelgraphix.htm
(lots of good alternative schemes on this one)
    July 2005
Posted by painklr on Wednesday, November 9, 2005 4:46 PM
Can anyone help?  I am building a 1/170 Super Valkyrie VF-1S. I should have the preshading done tonight.  My question is what is the overall color of the a/c?  Is it white or grey?
Thanks in advance for the help.
Posted by Aurora-7 on Wednesday, November 9, 2005 6:17 PM
The standard colors to the Super Valks are pretty boaring. The basic white, red, blue or tan color to the valk's fuselage (depending on who the pilot was) and the standard trim and then the booster and armor attachments which tend to look dark grey or black, depending of how it looked on your TV. There have been many imaginative color schemes doen by people so I would advise to use the above links by trigger to get some ideas.
Here's an image of the standard VF-1A scheme:
http://www.macrossworld.com/macross/magazines/mg_aug2001a2.jpg
And here's a custom one:
http://www.macrossworld.com/macross/magazines/mg_1020012.jpg
Posted by Anonymous on Wednesday, November 9, 2005 6:39 PM
I would assume that there are multiple colour schemes for the fighters depending on the environment that they are fighting in.
Same as with modern aircraft, so feel free to go wild.
Plus, there are plenty of 1/72 markings out there to help you out.
Posted by Anonymous on Wednesday, November 9, 2005 6:43 PM
Wish I had the time and money otherwise I would rather be doing a "Super Ostrich" or the "Elint Seeker" Valkyrie.
Posted by Anonymous on Thursday, November 10, 2005 6:47 PM
Wow I just found this GB. I haven't logged in for a while. When does it end?
    December 2003
Posted by thevinman on Friday, November 11, 2005 9:31 AM
Since it's a pretty small subject, relatively speaking, it's a long build. It will end sometime in 2006. Probably later in the year. We will think about closing the build later next year.
    July 2005
Posted by painklr on Monday, November 14, 2005 11:18 AM
Man, I went crazy this weekend a spent some cash on this Hobby.(air brush, paint, putty, gap filler, thinner, cleaner, Dukes of Hazzard kit)  Luckily I am single with an understanding girlfriend, so I did not have to answer to anyone or justify my purchases.  Hehehehe.
I did work on my super valkyrie this weekend. I laid down the primer and began assembly.  The question I have is this:  I want to fill in the seams on the arms and legs.  Should I use putty or gap filler?
I purchased both over the weekend.  Just not sure which one will work the best.
As always your advice and comments are greatly appreciated.
Painklr
    December 2003
Posted by thevinman on Monday, November 14, 2005 12:05 PM
What do you mean by "gap filler"? (please excuse my igonorance) Do you mean gap filling CA? If so, I would use plain old putty. CA drys stronger than styrene and you won't be able to sand it easily.
Posted by Aurora-7 on Monday, November 14, 2005 12:31 PM
I've used Zap Gap for glueing and sanding on the spot. It's quicker than using putty but the V-man is right about it not sanding as easy. If you glue two pieces with CA and use some accelerator, it's OK because the freshly cured adhesive is still soft enough to sand easily. But if you do not sand it right away, the glue  can be rock hard (depending on the brand) and you will end up sanding away the plastic around the glue.
Jeeze! guys, thanks for reminding me I need to get some more CA!
    July 2005
Posted by painklr on Monday, November 14, 2005 2:16 PM
I belive it is gap filling CA.  The attendant at the hobby shop called it gap filler.
Thanks for the help
    December 2003
Posted by thevinman on Monday, November 14, 2005 3:01 PM
Yup, that's the stuff. Generically called CA, short for Cyanoacrylate. aka super glue.
Stuff dries hard as a rock, so I wouldn't use it if you need to sand. (I never tried sanding after using accelerator, as Aurora-7 suggests...)
Posted by Aurora-7 on Monday, November 14, 2005 3:10 PM
Stuff like Zap Gap CA is best used as filler when you want to build and build and build without having to wait for putties to dry. Plus it makes for a stonger bond. For most construction I use things like Pro Amber Weld or Tenax but if it looks like I'm going to join something that will have a bit of a gap or warpage doesn't allow a regular liquid cement to hold two pieced together, I'll use Zap Gap.
    March 2011
Posted by stram8777 on Monday, November 14, 2005 7:29 PM
Is it to late for me to get in on this GB?  I have two builds going on right now but I really would like to build a VF-1 along with you guys.
    December 2003
Posted by thevinman on Monday, November 14, 2005 7:57 PM
It's not too late!
Welcome to the build! Sign - Welcome [#welcome] What make/scale/model of the VF-1 are you looking to do?
    March 2011
Posted by stram8777 on Monday, November 14, 2005 8:32 PM
I am gonna build a 1/72 Hasegawa VF-1 Fighter.  Unless I find a VF-0D before then.
    February 2004
Posted by Trigger on Tuesday, November 15, 2005 11:41 AM
Check out Hobby Link Japan's <a href="http://www.hlj.com/product/HSG18">site</a><br>
I got my VF-0D from HLJ earlier this year and my only "complaint" is that it takes a few weeks for your order to get here. I placed an order with them for a VF-0S, SV-51 and Tenjin Hidetak's book on the 9th and I got notice this morning that they're on their way. My previous order with them was placed on 1 Nov for a VF-22S and a VF-0S w/Ghost and the shipping notice came to me on the 8th. You used to be able to track your orders, but I'm not sure you can anymore. Anyway, I'll post when they start arriving.
Posted by Aurora-7 on Wednesday, November 16, 2005 8:01 AM
Ooooh, ModelBase is working on a new design for a base for Macross kits. It's gonna be the Skull Squadron emblem! This is the prelimnary design that was posted at macrossworld.com
Posted by Anonymous on Friday, November 18, 2005 4:46 AM
Not really made much progress, need to get seriously cracking here.
Got a bit sidetracked with 2 builds for someone:
Crusher Joe - Dongo(1/12)
Gasaraki - Ishtar Mk II(1/35)
    December 2003
Posted by thevinman on Friday, November 18, 2005 9:19 AM
Same here. There are 100+ decals on the YF-19. It's taking forever.
    March 2011
Posted by stram8777 on Friday, November 18, 2005 7:28 PM
I think I am gonna build a VF-1S Fighter and the corresponding Battroid since I had both kits in my stash.  My question is this though, one of my modeling weak points is painting white, anything white including airbrushing, brush painting, any white kills me.  Since the traditional VF-1S is white what brand paint would cover well and not cause me to have to do twelve coats?  I generally use Tamiya Acrylics as well as Gunze acrylics.  Any ideas?
I plan on getting started tomorrow, and doing these in conjunction with my other two builds an F-15C and a P-51D that I am building to represent the pair I saw fly together this summer at the St. Louis Fair and Air Show.
    December 2003
Posted by thevinman on Friday, November 18, 2005 11:05 PM
What was the question / problem?
    March 2011
Posted by stram8777 on Saturday, November 19, 2005 9:47 AM
whoops I guess I forogt that part.  My question is this, what brand of white paint can I use that will cover well in only one or two coats?
