Community Build Project #4 - Ship
Posted by djmodels1999 on Monday, September 8, 2003 4:29 PM
to upload on Ron's website, there's apparently only one 'album' where you can do it now. Called 'Upload here' or something like that. Took me a while to see it!
Posted by Anonymous on Monday, September 8, 2003 6:21 PM
I think it's gonna be a blast watching this one. Have any of you built a ship in the last decade? Big Smile [:D] Tongue [:P]
Seriously though, this should be fun with the variety of kits.
Posted by Anonymous on Monday, September 8, 2003 9:22 PM
Thanks dj, I've got the pictures uploaded now.
http://rongeorge.com/modules/Gallery/uploadhere/CBP4_2
http://rongeorge.com/modules/Gallery/uploadhere/CBP4_1
I started cleaning up some of the pieces this afternoon. It looks like I'll put the trailer together first and then work on the watercraft itself. So far it's been an average Revell-Monogram kit. A bit of flash and some mold seams but nothing that a bit of sandpaper won't cure.Wink [;)] The tires on the trailer are plastic though, I wish they would have included vinyl tires instead. Oh, well.
Ray
Posted by Anonymous on Tuesday, September 16, 2003 12:35 AM
OK> I'm finally getting started (a bit late) but I have the minicraft (chinese trumpeter) 1:700 hornet with little b25's to make the doolittle raid :)
I will need pointers and some good links for reference would be helpful too!
i'll post some pics once something is glued :)
Posted by Anonymous on Tuesday, September 16, 2003 11:25 AM
Here's Murray's update as it sits on the morning of 9/16/03:
The Ambrose is coming together, and things are starting to roll along pretty quickly now. My guess is that I've worked on it for about 5-6 hours in total and I'd say I'm about 75% done as far as appearance goes. The very bottom of the hull is not on yet, and the rest of the its and bits are very tiny and may take more time than I think.
I must admit that this is quite a bit harder than I thought. I made an early decision to go 'against the grain' and just build the whole thing out of paper, rather than get it transfered to some heavier cardstock or something like that. I see now that using heavier paper would have definitely simplified the building of the hull and the end product would have been much straighter and more solid.
Oh well, it is what it is and it's been a pretty good project so far. I have to give credit to whoever designed this though (www.digitalnavy.com), because it does go together fairly well. My initial look at the 'exploded' instructions caused me some grief because I wasn't at all sure where to start and in what order to do things. However, as I fuddled through building various pieces, I realized that everything seems to be numbered. And, if I would have assembled things in the sequence of the numbering, it would have gone pretty smooth!! Sometimes the most obvious things are totally invisible to me!!
It shouldn't take too long to finish it up, but I must admit that I don't really have intention of putting every last item on the ship (I spent about 45 minutes last night trying to put together the teensie-weensie little bell that sits on the bow). Unfortunately, my rough skills with paper have resulted in something that looks like... paper (unlike the one that was on the digitalnavy website!!) and therefore won't likely be put in a museum anywhere. There are some really fidly little bits that I think I'll just skip (the little handrails come to mind...).
Thanks to Ray (heylonghair) for suggesting the use of Rubber Cement. It's worked quite well for this. I used some craft glue earlier on in the project and it cause the paper to warp a bit.
If you're thinking of building something with paper, you really don't need any special tools. I've used scissors, xacto, a small putty knife, and a dental pic for applying glue, etc. I would recommend finding some sort of tapered dowel that you can use to wrap paper around. There are lots of shapes that need to be wrapped in a cylinder, and this becomes much easier if you have something the right size to wrap it around. Something like a long tapered knitting needle, or similar would work well. I'd also suggest that you print one copy of the pattern onto card-stock or heavier paper, and another on regular old printer paper. Some of the pieces need to be very thin to be shaped right. Others need the strength of heavier paper.
Well... I look forward to reading and seeing everyone elses progress. I noticed a few other updates, but haven't read them yet. Good luck to all! I'll post a final picture when I'm done...
Murray
Here's another pic more from the bow...
Posted by djmodels1999 on Tuesday, September 16, 2003 12:23 PM
It does look quite good from over here, Murray! Is there an International Paper Modelers' Society somewhere, where you can enter it into competitions??!
My Roman ship is slowly taking shape. I'm still working on the hull, as there are quite a bit of flash to remove. I'll be off on holidays for a couple of weeks soon, so the next steps will have to wait until early October...
Posted by SNOOPY on Wednesday, September 17, 2003 11:55 AM
Hey Murray,
It looks really nice. I downloaded the Dreadnaught Battleship. I was thinking of building that next. One question is, where were you able to print on thick post card material? I do not want to ruin the printer I am using with too thick of stock.
Scott
Posted by Anonymous on Wednesday, September 17, 2003 3:19 PM
Snoopy,
I didn't actually print anything on cardstock, however I wish I had done so for several of the 'structural' parts (ie. hull and deck pieces). Most printers will accept thicker card-stock if they are set correctly for it. The color-laser I use is a Techtronix and it has a setting that allows thicker papers to go through. If not, then maybe the best solution is to get it color photocopied on top of some thicker paper.
The instructions for the Ambrose have recommendations that some of the pieces should be about 1mm thick. I don't think this would go through a printer, so the only way I could think of doing this was by using something like 'matt board' similar to the stuff used in picture framing. It's pretty thick and rigid. The other alternative would be to use some thin cardboard, maybe like the stuff that's on the back of a pad of paper. (If you have an old 'binder', you can rip the covering off and I think there's cardboard inside there that would work.) If you just attached the print-out with some spray adhesive you should be able to cut the pieces out no problem.
Here's what I'd recommend (based on my vast experience of building about half of one model...)
Hull, Decking and other major pieces - use thin cardboard or matt board with the patterns stuck on top.
Main deck structures/buildings/etc - use thick paper. Something around the thickness of a file folder would be good. Use the thickest stuff you can get to go through the printer without any problems. (A file folder might be too thick for a printer, but you get the picture.)
Anything cylindrical or round - chances are that paper will work best for this. The thicker stuff doesn't really 'roll' very well...
Again, my buildup is entirely out of plain old regular printer paper. If I build something else, I'll definitely do it different.
Murray
Posted by Anonymous on Wednesday, September 17, 2003 3:28 PM
Hey Domi!
Thanks for the compliment, but I'm afraid it's not competition quality in any sense. I'm happy I chose it and it's going to be a really good learning experience. I will say that it's a GREAT way to get in a 'fix' when you can't get to the bench. Very few tools are required and it's pretty easy to work on something like this while your hanging out in the living room with the wife and kid.
A fellow club member has built some airplanes from paper and they looked awesome. I'd like to try one of them too...
Murray
Posted by Anonymous on Monday, September 22, 2003 8:49 PM
I'm new here and am wondering, what is a community build project? Is it where several people build a kit at the same time and keep everyone updated on progress. If it is, is it too late to get in on this? Sounds like fun.
Paul
Posted by Wolfp on Tuesday, October 28, 2003 9:11 PM
So,
How is everyone doing on this one? I have yet to get finished and only 3 days until the deadline. Dont think I am going to make it...heh.
J.B. http://photobucket.com/albums/a303/jbrunyon/
On the Bench: !/350 TOS Enterprise; 1/72 Tie Interceptor
Posted by djmodels1999 on Friday, October 31, 2003 6:27 AM
Wolfp, I'm far from being finished on mine... I've just found out about a book that might give me some more info, so as far as I'm concerned, it's being put aside for a week or so until that book arrives.
Posted by Wolfp on Friday, October 31, 2003 11:07 PM
Heh...I have the hull and all the superstructure complete. I will soon start my first PE job, probably be another month before this is finished.
Posted by djmodels1999 on Saturday, November 1, 2003 4:17 AM
Looking forward to seeing your efforts, Wolfp... Which PE kit are you using? Is it going to improve on the kit a lot?
Posted by SNOOPY on Saturday, November 1, 2003 10:43 AM
Well, for me, this became the busiest month yet. A bathroom floor and out of town work became a priority for my ship and it still sits with only the hull put together. Not a very good first try for me.
    January 2003
Posted by Jeff Herne on Sunday, November 2, 2003 1:03 AM
Sheesh....I've built 14 ships in the last 2 years...and 2 aircraft, 2 artillery pieces, 1/2 car, and 1/2 tank...
I can loan someone a ship model if they need it!! :-)
Jeff Herne
Modelwarships.com
Posted by Wolfp on Sunday, November 2, 2003 3:55 PM
Tom's models or some such. I think they will just based upon the reference I have looked at and the amount of detail missing on this Heller model. It should look pretty smart, providing I dont gak it up...hehe. LOL Jeff, I have too many other hobbies that take up my time, so my production schedule is a leeeetle screwy. I have considered downsizing, however. ;-)
