The Airfix Farewell GB from now until 1st Jan 2007
jwb
    February 2006
Posted by jwb on Saturday, September 9, 2006 1:23 PM
My Spitfire IXc/XVIe came in today. I wrote a "first look" of sorts in the Airplane forum.
I hope to get started in a few weeks. I should finish the 262 in a few days, then the Zero shortly after. By that time the P-47 will be along pretty well, and I can start the Spitfire.
I'll have a few of them by then. Once all the stuff I've ordered comes in, I'll have no less than 7 Airfix Spitfire kits. (Well, 6 Spits and one S6b....)
And I STILL want that 1/48 scale 70th Anniversaty set.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by osher on Saturday, September 9, 2006 1:46 PM
 jwb wrote:
 osher wrote:
OK, here's where I am with the model:
You're gonna be done before mine even arrive in the mailbox! LOL
Looking good!
Nope!  Still, I'm having a few hassles with it.  I screwed up when painting it, and to my knowledge Mig-15s didn't have giant fingerprints on them, etc
jwb
    February 2006
Posted by jwb on Saturday, September 9, 2006 7:02 PM
No, no. That MUST be accurate. All my kits have fingerprints! Wink [;)]
Jon Bius
    May 2006
Posted by Brews on Saturday, September 9, 2006 7:16 PM
Having done a bit of Waterloo research yesterday, I have found the following illustration, which helps a great deal:
Posted by osher on Saturday, September 9, 2006 8:25 PM
Laugh [(-D]
Ah, but were it just that!  Also, used the wrong thinner, leading to weird paint schemes.  It's also still not dry.  This one will be given to some 6 year old boy or another, for the infamous One-Way Airforce.
    July 2003
Posted by KJ200 on Sunday, September 10, 2006 10:09 AM
Osher, sorry to hear about your problems with the Mig.
Progress Update
Fuselage is together, and upper wing halves attached as well as the rear stabs. Still need to sort out the wing roots, but that can wait until the lower wing is attached.
I've painted the pit and the pilot, as well as applying the white for the Reichsvertidigungsverband on the rear fuselage.
I've just realised this is supposed to be the famous yellow 10, you certainly wouldn't guess from the camo scheme supplied by Airfix, it's well off!.
Just need to insert the pilot and seat, then I can attach the lower wing section. I've had to shim the front of this to eliminate a nasty gap along the front edge, and plugged the holes for the drop tank with plastic rod.
This kit has to have one of the worst canopies I've ever encountered. Spent half an hour last night polishing it up, before giving it, it's second dunk in Future!
Should be ready for a coat of RLM76 in a couple of days.
Karl
Posted by osher on Sunday, September 10, 2006 10:35 AM
Hi Karl,
What is a 'shim'?  Seems you're also having fun with your Airfix build.  Ah, these old kits...best left for memories?  Thanks for your kind words about the MiG, still, at least your FW-190 is coming on!
Posted by osher on Sunday, September 10, 2006 11:35 AM
Update:
Here's the MiG after the botched paint job
Here it is after I've sanded it down, starting with course, down to polishing standard.  Would make a great weathered winter distemper model!  Now for a second attempt to paint it.
    July 2003
Posted by KJ200 on Sunday, September 10, 2006 1:50 PM
Osher, if you're after a really smooth finish I can recommend the micro mesh polishing cloths.
These go from 3600 grade up an amazing 12000 grade. I use them for polishing up canopies etc, they really are one of those toll that make you think 'How did I cope before I had these?'.
As for what's a shim, it is simply a thin piece of material inserted between two surfaces, in this case the front portion of the lower wing assembly, and the fuselage to fill a gap.
I attached a thin peice of styrene sheet to the lower wing, then filled and sanded it smooth, so that with wing attached I'm just left with a neat panel line, with no need for filler.
See the thin white line in front of the wing, that's the shim....
I ended up doing the same on one wing due to a slight gap.
Karl
Posted by osher on Sunday, September 10, 2006 2:19 PM
Thanks for the info Karl.  I've never used a shimmy, just filler.  Maybe I'll try that technique sometime.  Is it better than filler?  Your FW-190 looks excellent, especuially considering the kit!
Anyway, here's the latest paintjob on MiG.  As you can see, a bit of a failure.  As I managed to squirt airbrush cleaner in my eye, I'm going to leave it for a wee while!
    May 2006
Posted by Brews on Sunday, September 10, 2006 2:30 PM
I've had several Airfix Fw190D's over the years, including one or two of the early ones. However, I've never considered the canopy particularly nasty. Thick, but clear. Maybe the QC at Trun struck again.
    July 2003
Posted by KJ200 on Sunday, September 10, 2006 2:56 PM
Brews, the canopy was covered in what looked like a myriad  of stress marks. I'm used to dealing with Revell canopies which can be pretty dire, but this was something new to me.
Osher, shims are just another way of dealing with gaps. I find they are often stronger and neater than filler alone.
Just keep plugging away with the Mig, I hope you're eye is OK.
Karl
Posted by osher on Sunday, September 10, 2006 3:02 PM
 KJ200 wrote:
Osher, shims are just another way of dealing with gaps. I find they are often stronger and neater than filler alone. Just keep plugging away with the Mig, I hope you're eye is OK.Karl
Thanks Karl!  Yes, a slight sting, but that's all
    May 2006
Posted by Brews on Sunday, September 10, 2006 8:27 PM
Karl,
PM me your address and I'll send you an Airfix canopy that doesn't have stress marks. I have more than enough Falcon canopies for my own.
Bruce
    July 2003
Posted by KJ200 on Monday, September 11, 2006 7:05 AM
Brews, thanks for the offer, but the canopy is now sorted.
The polishing, and the dunk in Future have done the trick.
Thanks again though.
Karl
    April 2005
Posted by Thunderbolt379 on Monday, September 11, 2006 8:33 AM
Hi KJ200,
I recall building the Airfix Dora-9 about 20 years ago -- the molds were fresh and I remember it going together rather well at the time. Of course I probably wasn't as picky then as I'd be now, but I was quite impressed then. I used to have it shelved as a pair with the Airfix F-8, which also impressed the heck outa me when I was a teen.
Your D-9 is looking extremely good -- makes me wanna grab something and build! The Draken I picked up last week will take a lot of work, the raised panel lines are hideous and need rescribing. Plus, it's for conversion to an SF subject, and that'll take a long time, besides not qualifying for an OOB GB.
For an OOB I'm thinking about maybe something from the LHS. I'm probably picking up the Airfix Vulcan tomorrow, but that's for longterm storage (read: until I have a display cabinet!) Or I could dig through everything I've got for inspiration!
Cheers,
TB379
http://worldinminiature.blogspot.com/
    April 2005
Posted by Thunderbolt379 on Monday, September 11, 2006 8:55 AM
Oh, and one other thing...
I suddenly realised, though many of us are deeply concerned at the demise of Airfix ... not one of us is shedding a tear for Heller. I've never actually built a Heller, though I have their 1:100 HMS Victory and Le Soliel Royale put away for a rainy six months (each). Perhaps a lot of folks on the Continent are mourning the French giant, but it won't make a great deal of difference to my personal hobby activities. What about you folks?
TB379
Posted by osher on Monday, September 11, 2006 9:05 AM
 Thunderbolt379 wrote:
I suddenly realised, though many of us are deeply concerned at the demise of Airfix ... not one of us is shedding a tear for Heller. I've never actually built a Heller, though I have their 1:100 HMS Victory and Le Soliel Royale put away for a rainy six months (each). Perhaps a lot of folks on the Continent are mourning the French giant, but it won't make a great deal of difference to my personal hobby activities. What about you folks?TB379
At my LHS, the Airfix stuff flew off the shelves (although, to be fair, amazing how much remained) when the annoucement came.  As for the Heller stuff, well, a few bits moved, but that's it.  Nothing talks as loudly as a wallet.
So, will we see you onboard TB379?
    January 2006
Posted by sirdrake on Monday, September 11, 2006 3:05 PM
Not that I ever built an Airfix kit in my life (my adult modeling "career" is just too young...), but I find this such a nice idea that I have to join. Just ordered an 1/72  Avro 504K and a 1/72 Messerschmitt Bf 109E-4/B/(N)/Trop (for 50 cent!) from squadron. Don't know yet what to build (I like biplanes, but the Messerschmitt is tempting). More soon...
Posted by osher on Monday, September 11, 2006 3:44 PM
Sir Drake, hello, and welcome aboard!  The Avro 504k kit is so so simplified, and it has no rigging diagram.  Not sure about the Messerschmitt, but I don't think it was one Airfix's best.  However, if you can make the Avro into something good, I'll take my hat off!
    July 2013
Posted by DURR on Monday, September 11, 2006 4:12 PM
i have airfix kits up the wazzoo so i would like to join your build if i may i just don't know yet which 2-3 i am going to do yet
Posted by osher on Monday, September 11, 2006 4:16 PM
All of them!!!  Welcome aboard!
Posted by osher on Tuesday, September 12, 2006 3:56 PM
My third attempt at a coat!  No.1 was, hmm, weird, but I did use cellulose thinner, so, that's probably why.  No. 2 was lumpy, but I don't know why!  No.3 used the same paint/thinner mix as no.2, but this time worked fine.  Almost.  For some reason, I wasn't paying attention or I don't know what, but the paint, on one wing, ran, and created drops.  Hopefully I can sand them off...  Funny, on the test kit (an unbuilt Matchbox JU-88 that's missing it's canopy, pity, the moulding is so sharp!) the finish was so nice.  I probably just sprayed too much on the MiG.
Posted by osher on Tuesday, September 12, 2006 4:04 PM
Modelling list updated on the first post.  Let me know if anything is wrong.
    April 2005
Posted by Thunderbolt379 on Wednesday, September 13, 2006 8:47 AM
Hi Osher,
I reckon I'm aboard! Forty years, or nearly, with Airfix, I should see the old firm off with a styrene salute.
Liking the looks of the Dora 9, I picked one up at the LHS today, Aus$5.95 was a good price (interestingly, there's been no run on their Airfix stock yet, though to be fair it's a wall of models in an educational toys shop, not a hobby store per se...). Panel lines are raised, but very fine. Besides Yellow 10 (actually a D-13, of course), the kit features marking for Red 1 of JV44, a subject I've been fascinated by for a long time, and the decals are very well-printed. I'm tempted...
Otherwise I'm thinking of maybe the old CA-13 Boomerang, the Mitsubishi Dinah, or something along those lines. Something that'll allow me to do a good, colorful airbrush job to compensate for shortcomings in the old molds. I also have a couple of F-14s put away, I first built one of those thirty years ago.
Cheers,
TB379
Posted by traveller on Wednesday, September 13, 2006 8:12 PM
Started a Vulcan, with Harrier GR3 to follow. After that, a pair of F-15A's with 9/11 decals. As soon as I figure out how to post images on the site, I will show you guys. By the way, can anyone help me with that?Smile [:)]
    May 2006
Posted by Brews on Thursday, September 14, 2006 1:15 AM
I use www.picturetrail.com to upload pics tand link them to here. Photobucket does the same thing. They're both free sites.
    December 2005
Posted by jeff on Thursday, September 14, 2006 11:31 AM
I've never done a group build before, but as an old Airfix fan, I can't resist.  Count me in, though it will be a couple of weeks before I can get started.  If all works out, I'm going for the brass ring with a 1/72nd  E-3D Sentry.  Otherwise, I'll do that most British of fighters, the EE Lightning.  I'll let you know ASAP.  Of course, if I do the E-3, I'll tell everyone so you can buy stock in Squadron putty Smile [:)].
As for Heller, I'm a huge Heller fan, especially the weird interwar stuff they did.  At least the molds are living on with Smer and others!
"Congratulations, gentlemen! You're everything we've come to expect from years of government training." Zed (Men in Black) [IMG]
    November 2003
Posted by JoeRugby on Thursday, September 14, 2006 12:48 PM
I know I said F86 but I have a Vampire rolling for the First Jets GB, here is the progress to this point.  I did try to rescribe panel lines and am making the squadron flash by hand.  It is supposed to be A RNZAF bird.
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
    July 2003
Posted by KJ200 on Thursday, September 14, 2006 1:37 PM
Joe, nice job on the Vampire.
That must be tiny in 1/72.
Progress Update
Dora is ready for the paintshop.
I've rescribed some lost panel lines and added a couple of panels from Tamiya tape, other that it's as Airfix intended.
I'll post some pics over the weekend.
Karl
