Self Propelled Artillery/Mortar GB 2006-2007
    April 2006
Posted by Hermesminiatures on Thursday, February 22, 2007 11:52 PM
I started it yesterday and the only major gripe is ten or so quite deep ejector pin marks on the inside faces of the side armor that need to be filled. Other than that, it's great, and isn't based on the old (awful!) Tamiya Panzer II like many people assume. The texture on the cast parts of the suspension is quite impressive and even the tiny lettering on the gun breech is included. Of course it will benifit from PE tool clasps and a few brass and chain details but overall I really like it.
Jonathan
For every modeling technique that works, I have three that don't.
    August 2006
Posted by Gun Tech on Friday, February 23, 2007 1:05 PM
Yep, that little 105 mm Howitzer goes together like a charm Smile [:)]  Very nice.
Jean-Michel    "Arte et Marte"
    July 2006
Posted by redleg12 on Monday, February 26, 2007 9:25 AM
 Plastic_Cross wrote:
 redleg12 wrote:
As I said it is about 90% complete............Want to hear your comments.
Hoo Wa - that is one hunka burnin SPG you have going there.  It looks phenomenal.  Is that the Italeri kit?  How much of a departure from "out of the box" did it require?  I see the 107 kit appear on eBay on occasion, but have not actively pursued one as of yet.
Larry
I have finished and will post some more pics in the next couple of days but it is the Italeri kit. I have added a metal barrel from barrel depot. For this length and size it is a must. I also have some details for the photo etch kit from eduard. It is especially freat for the vents, and some other small details. The barrel and photo etch are still available. The kit is hard to find. The only other minor change from the out of the box is the decal marking. Since my first unit was a 175/8 inch unit, the marking are from my old unit.
In general it is a great kit. It does need some seam work for some parts but in general was a blast and turned out great.
I'll post some pics as soon as I get a chance.
"The Moral High Ground....A Great Place to Emplace Artillery."
    July 2006
Posted by redleg12 on Monday, February 26, 2007 7:29 PM
Larry
I'll post some pics as soon as I can
Here are the pics from my finished M107 I promised. Hope you enjoy them!!
    August 2006
Posted by Gun Tech on Tuesday, February 27, 2007 11:14 AM
Very well done. I particulary like the moved earth effect by the spade. Thumbs Up [tup]
    July 2006
Posted by redleg12 on Tuesday, February 27, 2007 11:50 AM
Thanks!!
Currently working on an M270 MLRS, in desert camo in the firing position with an M26 missle coming out of one of the pods. It's a challange. The missle is easy. Playing with the smoke is a blast!!
    July 2006
Posted by Plastic_Cross on Tuesday, February 27, 2007 12:37 PM
Wow - this I gotta see.  I'm new to modeling and still trying to figure out how to complete a decent armor build, so dioramas are not something that I'll be attempting any time soon.  But I thought that if I were to do one eventually, I would like to do something that captures the gun at the moment the projectile leaves the muzzle.   Your idea is fantastic and I will be very eager to see it in living color.
Larry
    April 2006
Posted by Hermesminiatures on Tuesday, February 27, 2007 10:25 PM
I finished construction of the Wespe this evening. It was less and less OOB as I went but still pretty much so by the end. I filled all the nasty ejector pin marks in the interior, drilled out the barrels and magazine ports on the MP-40's, added an antenna and a headset and wired both into the radio, cut off the silly-looking molded bumps around the top of the armor and replaced them with correct tie downs made from solder, and of course added Voyager tool clasps, 10 total or 30 parts in all (they actually do open and close!)
Tomorrow I plan to paint the model, that is if I can get my air compressor back in the house - it's in the garage and we have 2 feet of snow thanks to last weekend's blizzard, AND on top of that it has to go in the back basement door cause it won't fit down the stairs...Banged Head [banghead]...wish me luck!
Jonathan
Posted by espins1 on Wednesday, February 28, 2007 10:21 AM
Hermesminiatures, I'd be curious to see your painting sequence since you have the kit all assembled, especially considering it's an open topped vehicle.  I usually do my painting in before adding all the tools and non-camo colored bits.  If you wouldn't mind, can you take some interim photos as you go along?  I think it would be very educational for some of us still learning.  Smile [:)]
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    August 2006
Posted by Gun Tech on Wednesday, February 28, 2007 10:27 AM
Very good looking Hermes. Thumbs Up [tup] I like the tool clasps.
Same as Scott said, or did you just assembled the walls separately?
Good luck with your air compressor Wink [;)]
    April 2006
Posted by Hermesminiatures on Wednesday, February 28, 2007 11:38 AM
The sides and rear armor are just dry fitted in those pictures, and since the tool clasps work I just remove the various equipment before painting. Unless that makes a difference, I planned to take pictures as I went, since I'll be adding some pretty heavy weathering, and a lot of gear once the basic painting is complete. I spent the morning being angry at Tamiya for not molding sponsoons and once again requiring sheet plastic surgery.
I haven't attempted the air compressor yet - if you don't hear anything by tonight, you can probably assume it won and I'm pouting.Angry [:(!]
Jonathan
Posted by espins1 on Wednesday, February 28, 2007 1:27 PM
That's the one big annoyance I have with the Tamiya kits (which are generally pretty good)..... those damned open sponsons, what's up with that?  Why don't they close those up?  It makes what would otherwise be a pretty good kit more in line with what you'd expect from a toy. Dead [xx(]
    April 2006
Posted by Hermesminiatures on Wednesday, February 28, 2007 1:45 PM
For the same reason they sold necessary parts for the Leclerc MBT as a seperate set(Censored [censored]), and always use vinyl tracks. If they added sponsoons, they'd have to clean up all the ejector pin marks and rough CAD machining on the underside, and do something else about the always-thick fenders. They aren't really very concerned with customer satisfaction, which you would find out in a hurry if you ever try to contact customer support. That's the one reason why I don't like Tamiya.
I can see it coming now - an "I hate Tamiya" GB!Wink [;)]
Jonathan
    August 2006
Posted by Gun Tech on Wednesday, February 28, 2007 1:53 PM
With their line of Panzer IV based kits. Disapprove [V]
I am not buying any from Tamiya anymore because of the lack of underside details, and the ugly fit of the rear panel to the hull where the idler wheel is mounted.......      Not sure if it has been corrected on the 3.7cm Mobelwagen or the Wirbelwind.......  that why I passed.
    April 2006
Posted by Hermesminiatures on Wednesday, February 28, 2007 10:10 PM
Well, I managed to wrestle the compressor back downstairs, and had quite an eventful afternoon (attempting) to paint the Wespe.
I gave everything a final cleaning and used the airbrush to dust the parts off one last time.
Then I painted the entire vehicle with a custom-mixed Dark Yellow, 90% XF-60 Dark Yellow and 10% XF-7 Red. The red corrects the overly green tone of the Tamiya color.
I began painting a wide, random camouflage pattern with Tamiya NATO green, and managed to commit the biggest airbrush mistake possible - spill the paint in the color cup onto the nearly finished model! Fortunately it was only a small area and was pretty easy to fix.
The finished camo, ready for detail painting tomorrow. I deliberately add a visible 'squiggle' to the green to give it an uneven, field-applied look without being lumpy.
At this rate of mistakes, I ought to be done by ChristmasAngry [:(!]
Jonathan
    August 2006
Posted by Gun Tech on Tuesday, March 6, 2007 9:03 PM
OMG!!!!!!    I made workable U-Joints!!!!!!!!!     I'll post pics and updates as soon as I get time.
    April 2006
Posted by Hermesminiatures on Wednesday, March 7, 2007 4:49 PM
I finished detail painting on the Wespe and added some gear from a Gen2 figure set, with more to come after weathering. I used Archer dry transfers for the markings.
Jonathan
    August 2006
Posted by Gun Tech on Wednesday, March 7, 2007 7:43 PM
Looking real fine there Hermes! Thumbs Up [tup]
Does anybody know Will's whereabout?     I emailed him, but no answer so far......
Posted by espins1 on Thursday, March 8, 2007 11:14 AM
Your Wespe is coming along nicely Hermisminiatures!  Smile [:)]
You're a bit further along than I am on my JagdTiger Wink [;)]
    August 2006
Posted by Gun Tech on Saturday, March 10, 2007 2:08 PM
Alright.....  I made some progress, so here's some picsSmile [:)]
I drilled and installed the idler wheels. Care had to be taken as the retaining arm is a separate part and you can adjust the idler's position with it. I also added styrene for more details.
I finally made those "U-Joint".  Smile [:)] and they are workeable Big Smile [:D]    I'll wait for the "Scratchbuilt" forum to be operationnal to explain how I did them.
I also started the gun's construction. Eduard's PE helped in hidding a few seams (like in the craddle) and adding details.
 There is a lot of steps that will be confusing after that. A lot of planning will be needed for the gun shield, barrel, muzzle brake and forward assembly of the craddle.  MTF
    April 2006
Posted by Hermesminiatures on Sunday, March 11, 2007 9:57 AM
Lookin' good!
Jonathan
    July 2006
Posted by Plastic_Cross on Sunday, March 11, 2007 11:56 AM
Bravo on the U-Joint GT! You must have used an electron microscope to put that assembly together.  You must also have some pair of steady hands.  And I see by your photo that you have some great looking fingers. Smile [:)] .
Larry
    August 2006
Posted by Gun Tech on Sunday, March 11, 2007 12:10 PM
Larry
Well thanks Larry Laugh [(-D]  I wasn't expecting that. Let's say it took a while to get them together, and a few prototypes......    I saw your Hotchkiss, and you have a way better interior with Bronco than Trumpeter. Too bad I already got the Marder I and the Beobachtungswagen from Trumpeter Tongue [:P]      Oh well..... C'est la vie
Thanks Hermes! That howitzer is a bit trickier than the one from Tamiya's Wespe. But it has such a unusuall look Cool [8D]
    August 2006
Posted by Gun Tech on Wednesday, March 21, 2007 9:06 PM
I finished the gun assembly. The inner shield is left out for ease of painting. The muzzle brake is held by blue tack, as it will be impossible to remove the barrel after installing it. Same with the sight for ease of painting. Here's are some pics.
The craddle wasn't centered in the carriage, which might have resulted in alignment problems in the future. So I fixed it with a hairdryer. But I wasn't carefull enough........Disapprove [V]
It has been fixed though, by replacing the recoil guard by one from a Tamiya's Wespe in my scrap pile (pic 2 and 3)
    February 2005
Posted by Manic Moran on Friday, April 6, 2007 12:15 PM
Just checking in, seeing what's up. The PzH is about done, picked up 'model of the month' at the club meeting a couple of weeks ago.
That M107 is well done. I have the same kit, it's a real eye-catcher on display on the shelf. They just don't make them like they used to.
As for those U-joints... You're certifiable. And very impressive.
NTM
The difference between infantrymen and cavalrymen is that cavalrymen die faster for we ride into battle!
    February 2005
Posted by Manic Moran on Sunday, April 8, 2007 6:34 PM
Right, so.
It's in the main armour forum as well, but pics here.
NTM
    July 2006
Posted by redleg12 on Monday, April 9, 2007 9:28 AM
NTM
Thanks on the M107.
Working on the M240 MLRS firing with missle leaving the launcher. Should have some pics soon.
    August 2006
Posted by Gun Tech on Tuesday, April 10, 2007 7:19 PM
Thanks NTM Big Smile [:D]
You did very good on that beast. Cool [8D] Your camo scheme is top-notch! And the subtle weathering really brings it to life. I have seen real vehicles with paint scheme that looked only half decent as yours.
Congrats Thumbs Up [tup]
    July 2006
Posted by Plastic_Cross on Wednesday, April 11, 2007 7:50 AM
NTM,
Great results on your behemoth AFV.  The camo is spellbindingly perfect.  I'm not exaggerating....it's really well done.  I particularly like what you did with the rear of the vehicle, an eye-catching finish.  Your photography is excellent, does justice to your fine build.
I have that kit in the stash.  Every so often I open the box and take a look, wondering if I should take the plunge.  I got the kit pretty cheap on eBay, but the low price was because someone had started the kit and then abandoned it.  The turret and mantle were assembled were very poorly assembled. Everything else appears intact.  I'm working on the tiny Soviet ASU-57, which should not take long.  Maybe I'll start the PzH2000 next.
Thanks for sharing your results.
 Larry
Posted by espins1 on Wednesday, April 11, 2007 12:32 PM
Cool [8D] Very nice NTM!
