I've started on the MPM P-63A. Thanks to whoever posted the cockpits link, I found a photo of a P-63 there. The P-63 instrument panel doesn't look like a P-39 very much.
Today I removed the pour blocks from the resin parts. The pour block on the instrument panel was scary, but I got it sanded off without breaking anything that I know of. The block is attached over the entire back surface of the panel, and you have to get most of it off, but when you get close it would be very easy to grind off the fit for the rudder pedals. I cleaned up the major injection molded parts, thinned down the wing trailing edges, thinned down the doors, thinned down the inside door panels and glued them to the doors, fit the left door to the fuselage, which fit pretty well after a little sanding work. Tried to fit the right door. OK, the left door on this one is going to be closed, and the right one is going to be open, because it would be a lot of work to get the right door to fit and I don't want both doors open.
I read a review on this kit, on Modeling Madness, I think, in which the reviewer ended up with a banana-shaped fuselage when looked at from above. I think I'll be able to avoid that by carefully fitting the cockpit floor which will stiffen up the fuselage some. Right now it is very bendy because of the door cutouts. Last thing I did today on the P-63 was to fit the vac form canopy. The right side of the fuselage is going to need some work here, as the aft part of the canopy doesn't fit the fuselage cutout, which is too low. It's going to have to be shimmed up with some sheet styrene to fit the vacform canopy. The curve on the fuselage is too low there compared to photos and the Monogram and Eduard P-39 kits.
That's all for now, folks!
