Greetings all;
Thank you Frank & all for your continuing support.
I hate it when I screw up. For instance with all the modifications and notes I make to myself here is a faux paux I could have avoided. The forward vertical uppright ( 22C ) that is supposed to hold the horizontal support for the forward end of the gun breeches should not go in as the instructions note if you extended the fuselage.
That veritcal support should go between the ammo box and the empty belt box. So to fix this you have to cut off the guide block on the lower end of 22 C and add the rudder bar ( 14 C ) to that side.
Below I did not catch it until after I had added the photoetch C -yokes, turnbuckles and rigging wires. Note - the rudder bar is ok its just the vertical support bar is facing the wrong way.
