Knights of the Sky WWI GB The End
    October 2004
Posted by StephenLawson on Sunday, December 14, 2008 2:08 AM
 Daywalker wrote:
When this GB finishes up, I plan to put a post in aircraft to show everyone what has been accomplished here.  I have been saving everyone's photos as we went along, so I have copies of them all thus far.  Just wanted to be sure everyone is OK with that. Thumbs Up [tup]
Ok by me.
Stachel...unconfirmed by Armee means unconfirmed!!!!
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 6:55 AM
In a mad dash now that my vacation has started.  Now for the continuing Saga of the Roden D.VI.  Note the lower wing and forward fuselage repair I mentioned earlier.
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 6:56 AM
The brighter lozenges give you an indication on the stark difference in the texturing and the untouched decal.
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 6:59 AM
More of the cockpit and guns.  Note the scratchbuilt early version of the control yoke. The lozenge from the pilot's left side.  Yes I see it too.  I need to go back and texture the cockpit interior on the pilot's right side.
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 7:02 AM
Here are a couple more shots.
    September 2003
Posted by Daywalker on Monday, December 15, 2008 8:21 AM
Well done Stephen!  That texturing looks very nice.  Tell me about that prop, did you mask and paint it?  It looks like real wood.  Very well done. Approve [^]
I received my samples of the Easy Line on Saturday to try on my Nieuport 28 for the KOTS II.  Between the two sizes (.003 and .006), would it be safe to assume that the smaller size would be more appropriate for 1/48?
Frank
    April 2006
Posted by jgeratic on Monday, December 15, 2008 9:47 AM
That texturing of the fabric is interesting, what is the technique or was it already discussed in preceeding pages of this group build?
-Jack
Posted by More Power Scotty on Monday, December 15, 2008 4:22 PM
Roger,
I used Burnt Siena and Raw Umber oil paints over Model Master Acryl Wood that I airbrushed.  I just laid down some stripes with the oil colors, then wiped them off using a Q-tip of all things.  This not only mixed the colors, but left a wood grain appearance.  I have used oil paints before, but never wiped them with a Q-tip.  I liked the results enough on the interior parts that I used it on the propeller as well.
Frank,
I am nearly finished with the DH-2, and should in fact wrap it up this week if all goes well.  I will have a completely different entry for the build starting in January.  As far as a final photo of the finished products, I would say go for it.
Stephen,
I anticipate your response on the fabric work, as I can not recall where the discussion was in the now 92 pages of this posting.
Scott
    February 2007
Posted by DesertRat on Monday, December 15, 2008 8:27 PM
Wow! I really like the way that yours turned out! I've made a note of it for the next time I do wood. Thanks, Scott!Cool [8D]
Warmest regards,
Roger
    September 2003
Posted by Daywalker on Monday, December 15, 2008 10:22 PM
Outstanding Scott!  I'll be looking forward to seeing those pics! Big Smile [:D]
Frank
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 10:23 PM
 jgeratic1 wrote:
That texturing of the fabric is interesting, what is the technique or was it already discussed in preceeding pages of this group build? -Jack
Here is a bit of fun on texturing.
Click Here.
    October 2004
Posted by StephenLawson on Monday, December 15, 2008 10:33 PM
 Daywalker wrote:
  "Well done Stephen!  That texturing looks very nice.  Tell me about that prop, did you mask and paint it?  It looks like real wood.  Very well done. Approve [^]. . ."
Then here is a bit of fun on various aspects of wood  and wood simulated props.
Click Here
    October 2004
Posted by StephenLawson on Tuesday, December 16, 2008 5:11 AM
The guns and surrounding upper deck are done.  Here the top wing is added.
    October 2004
Repair shop begs to report 12.16.08
Posted by StephenLawson on Tuesday, December 16, 2008 2:26 PM
Greetings all; I have gone back and repaired the lost images to the Eduard Camel Combo build.  There is still one broken for now but the kit build images are all back. [url=http://www.aeroscale.co.uk/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=75083&page=1]Click Here
    February 2007
Posted by DesertRat on Tuesday, December 16, 2008 4:45 PM
Kinda makes me wonder about "Wongo Bongo", but she is an amazing looking build, Stephen! Well done!Cool [8D]
Warmest regards,
Roger
Posted by Jeeves on Tuesday, December 16, 2008 11:19 PM
I had started this one long ago for this build-- but ran into some issues.  First-- I made a boo boo with Eduard's painting instructions.  I assumed that the darker shaded color on the instructions was the darker of the two colors in the scheme-- when in actuality it wasn't.  Unfortunately, I had already decaled it when I discovered this-- so Lufbery's scheme is the exact reverse of what I have depicted.  Soon after that- it fell off the washer where it was perched after a rather vigorous spin cycle.  SO...until this past weekend it sat unfinished.  We had a power outage this weekend from the ice storm and I spent the day Saturday fixing the broken pieces and then rigging and adding the fiddly bits.  Nonetheless-- thanks to the generous end date on this GB, it's done.  Not my best work-- but not bad for my first biplane I guess.  I am amazed at how small these were compared to the WWII birds I usually build!
    September 2003
Posted by Daywalker on Tuesday, December 16, 2008 11:38 PM
Stephen- Smart looking Camel, love the woodgrain effects! Thumbs Up [tup]
Jeeves- Outstanding little Nieuport!  Can't see any evidence of her tumble in the photos.  Your build really makes me want to move my Bebe up the list in the build pile! Approve [^]  I added your finished build to page 1, thanks for being a part of it!
Frank
    October 2004
Posted by StephenLawson on Wednesday, December 17, 2008 5:47 AM
Greetings all;
Here is where I am at this moment.
    October 2004
Posted by StephenLawson on Wednesday, December 17, 2008 5:51 AM
 Jeeves wrote:
I had started this one long ago for this build-- but ran into some issues. . . Nonetheless-- thanks to the generous end date on this GB, it's done.  Not my best work-- but not bad for my first biplane I guess.  I am amazed at how small these were compared to the WWII birds I usually build!
Don't beat yourself up over these issues.  I have seen far worse attempts of this scheme.  The cool thing is it is decently done and you finished.  Next time things will go a bit easier. Model On!
    August 2007
Posted by BGuy on Wednesday, December 17, 2008 8:38 AM
Nicely done Stephen.  I completed an eduard 1/48 Nieuport 17 myself fro this GB and I'm very impressed with your results.  Did you have trouble with the interplane V-struts the way I did?  Mine refused to attach flushly and I ended up with an unsatisfactory result.
Posted by Jeeves on Wednesday, December 17, 2008 9:26 AM
Daywalker-- thanks for having me-- it is definitely a step out of my comfort zone.  Might have to pick up another WWI bird for the next build-- I have a Revell Sopwith in the stash but I am not sure that one would be so enjoyable...
Stephen-- Thanks for your comments.  Seeing your work-- it means a lot.  There are others I am anxious to try out-- always liked the look of a Spad XIII...
Posted by More Power Scotty on Wednesday, December 17, 2008 4:38 PM
Mike,
That really did turn out nice, so don't beat yourself up.  Thumbs Up [tup]
Stephen,
Your work continues to amaze me. Bow [bow] Thanks for the links, and I did write down the directions on the fabric process this time.  One quick question, how are you putting together those multi-photo pictures in your postings?  They look great, and take up less space than typical photos.
Scott
    February 2007
Posted by DesertRat on Wednesday, December 17, 2008 8:31 PM
Outstanding work on the rigging, Jeeves! Very well done!Cool [8D]
Warmest regards,
Roger
    October 2004
Posted by StephenLawson on Wednesday, December 17, 2008 10:22 PM
 More Power Scotty wrote:
". . .Stephen,  Your work continues to amaze me. Bow [bow] Thanks for the links, and I did write down the directions on the fabric process this time.  One quick question, how are you putting together those multi-photo pictures in your postings?  They look great, and take up less space than typical photos."
Greetings Scotty
I use a light green image and cut and paste them inplace with an imaging program.  "Microsoft Pictureit!"  is mostly what I use.  I like the multiple image block but most people want the finished build to be a bit higher in resolution.
So with that. . . . drum roll please!
    October 2004
Posted by StephenLawson on Wednesday, December 17, 2008 10:26 PM
Yes my dear wingnuts!  Stick a fork in it.  Its done!
Now from the quarter rear views.
    October 2004
Posted by StephenLawson on Wednesday, December 17, 2008 10:29 PM
Now the tails up rear quarter views.  Frank Please mark this one down - completed.  Looks like that completes my list on page 1.
    September 2003
Posted by Daywalker on Wednesday, December 17, 2008 11:32 PM
With pleasure Stephen!  Another stunning example of a not-often-modeled subject.  Love the weathering on this one, very authentic looking.  Thanks for another awe-inspiring piece of work. Approve [^]
Gents, that makes 34 completed builds here.  Is this amazing, or what?
Frank
Posted by More Power Scotty on Friday, December 19, 2008 7:32 PM
Frank,
Let us make that thirty-five.  I wrapped up the Airco DH2 this morning and photographed it this afternoon.
Scott
Posted by More Power Scotty on Friday, December 19, 2008 7:35 PM
Stephen,
Wonderful work once again! Bow [bow]
Just out of curiosity, have you heard any comments about Eduard decals for the DH2 Weekend kit that I just finished?  The white used to make the decals appear to be faded came off in spots when I set them in place with Micro Sol.  The decals were not damaged, the top color just came off in random spots.
Scott
    August 2006
Posted by wyoroy on Friday, December 19, 2008 7:39 PM
Scott, that looks way cool.  Great job.
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
