philo426 wrote: |
Looks great!The panel lines are very well done!How did you do it? |
THanks, Philo. THe panel line wash is a veyr easy technique I learned in a copy of Finscale. Tempra paints. They are cheap and water soluable, so if you make a mistake, you can wipe it off and re-do before you seal them in. I basically make a dark gray color by mixing black and white, then dilute it a little so it flows into the grooves.
Basically, you slop it all over the panel lines and let it dry. Once it's dry, wipe OVER the panel lines with a damp paper towel to remove the excess paint. When you are satisfied with the look, seal it in with a clear coat (I used flat clear for military aircraft). It is cheap, easy and I think adds a lot to the look of an airplane.
Give it a try on one of your older models you've already built.
