Ship Sinkers Group Build - Submarines
    June 2007
Posted by squeakie on Sunday, December 23, 2007 2:04 AM
 dostacos wrote:
 squeakie wrote:
I know this is the wrong country, but thought all sub builders should know that Hobby Lobby has the 1/72 scale gato class sub for $60 and then another 30% off that price tag. Last one I saw was $100.
     Also finally got the last piece of photo etch in the mail today!! I'd just about gave up on it. Now for another question: Is the pressure hull kit really needed? If not I ready to goto work!!!!!
gary
got a link for that? I looked under hobby Lobby and cannot find anything for sale
No I don't, I just have a store about ten minutes north of me. Many guys on here hit the chain of stores all the time. Once or twice a month they print a cupon in the newspaper for 40% off any item in the store, and I do usually take advantage of it.
gary
    December 2003
Posted by dostacos on Sunday, December 23, 2007 12:25 AM
gary
Dan support your 2nd amendment rights to keep and arm bears!
    June 2007
Posted by squeakie on Saturday, December 22, 2007 12:26 AM
gary
    March 2004
Posted by drdull on Friday, November 23, 2007 2:58 PM
Hi Jim,
My local hobby shops carry the brass rod/tube/structural shapes.  Its manufactured by K&S Engineering.  I know that MicroMark also has it and I think someone mentioned that Roll Models does as well.
I started doing the surgery on the Nichimo 1:200 type IXC.  Here is a picture of the lengthed fairwater.  I just used some 0.010 and 0.030 styrene with a styrene I-bar for stiffness.
Here are shots of the lower hull now painted
Barry
    March 2004
Posted by DanCooper on Friday, November 23, 2007 2:29 PM
Hmm, I could have sworn that I registered for this GB ???
Anyway, I have a couple of subs (at the time I registered, I was waiting for my VIID "Minenleger").
First one that I'll build, will be the 1/144 Type XXIII... Smile [:)] (actually that'll be the second time that I'll be building that boat)
On the bench : Revell's 1/125 RV Calypso
    August 2007
Posted by ben1227 on Wednesday, November 21, 2007 10:06 PM
 JMart wrote:
Have a happy thanksgiving!
Sign - Ditto [#ditto]              Party [party]Make a Toast [#toast]Make a Toast [#toast]Party [party]
.:On the Bench:. Tamiya 1/72 M6A1-K
    March 2007
Posted by JMart on Wednesday, November 21, 2007 8:07 PM
AJB93 - nice little sub, good details! Gives me couple ideas what to do with my plain jane ARII modern subs stash that will get built some day....
drdull - very impressive sub! where do you get the brass rods? I wanted to stock on some for propeller shafts of the various floatie thingies I am building...
Have a happy thanksgiving if you are on my side of the pond!
Cheers, Jim
    June 2006
Posted by AJB93 on Wednesday, November 21, 2007 5:03 PM
 Thanks for the kind words guys.
 ben1227 wrote:
Looks nice...did you build it as a waterline sub?
Yes, it is waterline. It actually is a little to high, the kit came split down the middle, not actually waterlined, so it required some cutting and sanding to get right. And yes, it was an easy build Smile [:)]
    November 2007
Posted by chef_ben on Wednesday, November 21, 2007 3:02 PM
Bayerische Filmwerks in Munich Germany.  Therre is actually a full size mockup of the interior of the submarine along with the superstructure that they used.  The pool is also there that they filled the model scenes in!  I worked on the USS Requin (SS-481) in Pittsburgh, PA as maintenance and tour guide so I was very familiar with what the insides of a U-Boat should be like.  Very very close!!
On the workbench: 1/48 Spitfire Mark II (Revell) - rethinking this situation! 1/48 Eduard Pfalz D.IIIa - 2%
    June 2007
Posted by squeakie on Wednesday, November 21, 2007 11:13 AM
 chef_ben wrote:
 squeakie wrote:
well I'm all psyched up now after watching Das Boot! I hope they got the colors of the uniforms right, and I'm now planning on the return trip. Not going out to sea.
gary
 I've actually been to the set of where it was filmed and it was very very accurate.  Possibly one of the most accurate war films I've ever seen
where did they fil this movie?
gary
    November 2007
Posted by chef_ben on Tuesday, November 20, 2007 8:06 PM
gary
    March 2004
Posted by drdull on Tuesday, November 20, 2007 5:07 PM
Nice work, AJ.
I got started on my U505 over the weekend.  I've never built anything smaller than 1:178 before and am finding this 1:200 a little challenging.  I guess the molds must be old because there is lots of flash to clean.  I started with the lower hull because I'm not making any changes to it.  I added the forward torpedo tube doors and horizontal planes.  These parts are fairly big and have definite mounting places.  The outer plane guards are a different story.  They are small and attach flush with molded bases.  I mounted them with a touch of tube cement so I could position them properly then when back and added a little Tenax to the joints.  Seemed to work OK.  Of the photos I took with my generation zero digital camera, this is the best (at least its in focus).  Maybe a new camera for Christmas?
The first step for the stern gear is mounting the center skeg.  The fit wasn't very good and I used some Mr. Surfacer to fill the gaps along the hull.  Before mounting the propellor shafts, you have to attach the small v-shaped bearing brackets to the skeg and the hull.  This is a purely do by eye operation; there are no molded mounting points.  I tried tacking the brackets in place with white glue to be sure I would get the propellor shafts (the end bearings rest on the brackets) in the right place, but it was pretty awkward.  I toyed with the idea of replacing the shafts with 3/64" brass rod to avoid flexing, but in the end I managed to get the shafts pretty well aligned. The stern plane and rudders go in easily but the stern plane guards are even smaller than those at the bow.  Apologies for the out-of-focus picture.
I painted the lower hull with Tamiya Dark German Gray.
The next steps will involve some surgery.  I have to extend the wintergarten and modify the deck to accommodate the added length.  I also have to remove the deck details associated with the large deck gun.  U505 had only anti-aircraft amarment.  I will be scratch-building the dual 20mm guns and the splinter shield for the 37mm.  Probably do that near the end.
Posted by Chatterer on Sunday, November 18, 2007 4:28 PM
Cool looking build AJ. Looks like it was an easy build.
David
    August 2007
Posted by ben1227 on Sunday, November 18, 2007 3:04 PM
    June 2006
Posted by AJB93 on Sunday, November 18, 2007 11:57 AM
Here's my entry, USS Florida SSBN-728 as she appears today. The kit is Dragon, built OOB. Scale is 1/700. Hope you like it.
    August 2007
Posted by ben1227 on Monday, November 12, 2007 9:20 PM
Awesome! That stupid Kilo is out of stock, so I'm tempted now to call Squadron and backorder it.
Posted by Anonymous on Monday, November 12, 2007 8:23 PM
 ben1227 wrote:
Cool. Wasteland, who started this, hasn't been in here in a while.
100% of my models tools, suuplies, cameras, etc are in boxes waiting to be unpacked while im painting and wallpapering.
I still watch and check your your pics and replies. Just hard between work...and work at home. I'll be back in full swing in a week
    August 2007
Posted by ben1227 on Monday, November 12, 2007 7:37 PM
    October 2006
Posted by kenjitak on Monday, November 12, 2007 6:05 PM
I sent a pm about getting into this GB but I'm not sure it got thru, so I'll repeat it here. Crash diving in with a Trumpeter 1/144  1944  Gato.
Ken
    August 2007
Posted by ben1227 on Sunday, November 11, 2007 6:56 PM
They just never satisfied my tastes...The most weathering I'd care to do on something that small in maybe the rust, a wash, and some dry brushing..
    March 2007
Posted by JMart on Sunday, November 11, 2007 6:47 PM
 ben1227 wrote:
There just isn't enough surface detail on those 1/700 and 1/400 sub kits for me...That Kilo is out of stock so I'm still waiting...
Indeed... not much detail in 700 scale, worse for modern subs, how can you weather them???
In the process of moving my workshop/booth around for wintertime, will post WIP pics in a couple weeks....
    August 2007
Posted by ben1227 on Saturday, November 10, 2007 10:31 PM
Posted by Chatterer on Thursday, November 8, 2007 3:29 PM
Thanks for the comments JMart! I'm sure your subs will turn out great Big Smile [:D]
Finshed the building on the U-Boat today. Fit not very good after building the Tamiya. Rudders and dive planes did not want to line up at all. I just hope the painting will be easier. I only have one picture of the sub right now. I'll get some more pictures later on this week before painting.
David
    March 2007
Posted by JMart on Tuesday, November 6, 2007 6:59 PM
 Waste Land wrote:
JMart, ever figure out which exact model you'll be going with? brand, name,? I know your doing 1/700
Greetings.... yes, Im still going to do this, will just be a bit... work issues getting in the way of fun building... also, tying to finish some stuff and do some priming (well a lot!) before I close down my spray booth and (attempt) to move it for the winter/cold weather.... cant use it when its <50oF or close to the furnace (I use enamels). Anyways....
I will attempt to do the ARII 1:700 modern subs, if just to show people how good a job Chaterrer did with his ;)  I will post pics of the sprues in a few, as well as the exact subs I will be doing... they basically come in pairs (2 LA class, 2 Kilos, etc) with the EXACT same sprues just different decals... and you get TWO top hulls for each, so you can show them waterline AND on a stand.. these kits are just too bizarre NOT to do ;)
Some modern sub web sites I have found (good pics)
http://www.netmarine.net/bat/smarins/monde/index.htm
http://www.globalsecurity.org/military/world/japan/yushio-pics.htm
These are models, all types
http://www.flankerman.fsnet.co.uk/submarines.htm
    March 2007
Posted by JMart on Tuesday, November 6, 2007 6:53 PM
Chatterer - Really REALLY nice work.... good job! love the detail in such a small scale....cheers
Posted by Anonymous on Sunday, November 4, 2007 11:45 AM
    June 2007
Posted by squeakie on Sunday, November 4, 2007 1:08 AM
anybody know of a source for a replacement 88mm cannon similar to the one on the deck of the 1/72 Revell U-Boat? I found the 20mm and a 37mm cannon, but not the big one.
gary
    August 2007
Posted by ben1227 on Thursday, November 1, 2007 4:01 PM
Keep us posted...that U-boat is bigger.
Posted by Chatterer on Thursday, November 1, 2007 1:39 PM
Thanks Waste Land and good luck with the move.  Barry thanks for the kind comments and I look forward to seeing your U-Boat.
I added a little more weathering on the sides of the sub. Sorry about the flash only way I could get a good shot. And the picture makes the weathering look really overdone. In person it is really hard to see. So I'm going to call this kit done.
Next up is the Mirage 1/400 U-673
Here is a shot of the parts layout Few parts to this one compared to my last kit. Detail is a little soft in places.
And here is a shot of the glued together hull next to the I-16 Even at 1/400 the kit is pretty small. But a lot more easier to work with. More to come later...
David
    March 2004
Posted by drdull on Wednesday, October 31, 2007 4:47 PM
Thanks, Ben.  Here goes...
I apologize for the less than stellar pictures, but it will give you the idea of what this kit is like.
This is the box and the two parts of the hull.
Here is the hull and superstructure fit together.  You can see the nice molding of the flooding holes in the superstructure.
The biggest of the three part sprues.  Small bits on this one.
I messed up and left half the top sprue out of the picture.  The bottom sprue has most of the decking.  The top sprue has the sail.  This will have to be lengthened by about 3/4" to match the extended wintergarten of U505.
