Not a criticism, just a question:
How long does it take wood to weather, and how would you represent a weathered axe handle? Shades of grey?
For my build(s), I did a little bit more to the Valentine last night. The engine cover (which looks like the same baffled arrangement of the Centurion's) wasn't a perfect fit, but it didn't take too many scrapes of a sharp blade to make it so. The Valentine was one of those tanks used as the British imagined them - vast fleets of vehicles navigating the desert in formation - bravely launching into battle like the Light Brigade (and with similar results). I quite like it, in a quirky sort of way. It was hard enough to find the Bishop SPG, and if I can find plans, I'd like to scratch the parts needed to convert one to an Archer (but that's a tad off-topic).
If anyone is planning to build the Dragon 1:35 Valentine, I have this word of advice regarding the bogies:
- if you want to have the wheels aligned properly, then attach them to their axles prior to cementing the sub-bogie axles for the smaller wheels to the main assembly, as the axles are not colinear (different diameter wheels) and the fit of the sub-bogie to the main bogie is a little vague. Attaching the wheels allows for the modeller to place all wheels on a flat surface (with no need for a jig) while the join sets.
The bogie assembly is actually quite nifty, and allows for rotation of the bogie arm so that posing the model in a diorama negotiating rocky ground (or driving over a kubelwagen) for instance, is simple.
For my next build, I might go for the Airfix 1:24 Ju 87B, with OOB markings Libya, 1941 (70/71(splinter) with irregular, rounded patches of 79, over 65, with white wingtip and fuselage bands).
