Frank,
Cant say I have seen that kit before, but always good to see something new.. Can I assume that it will be your next project?. And if so, what livery will you be doing?
Neil, sorry to see what has happened.. My only suggestion would be (and you will hate the idea) but sand it all back, mix or find the yellow colour. Spray the engines yellow. Then sit down with some masking tape, and cut out the long diamond shapes, and then place them where the decals were supposed to go, and then go over it with the red. I would also suggest that for the tail.. I think you will be happier with the end result..
Simon, great work, I mainly stick to modern-er aircraft, but always great to see the older aircraft being done..
As for me, I turned to the dark side today and bought 4 Hasegawa kits in 1/200.. I usually build 1/144..
I got a JAL 777-300 (That will be done in the new Vaustralia scheme from Virgin Blue). A JAL 767-200 (JAL) A JAL 767-300 (new Delta scheme) and a little A319 (Jetstar)
Chris
