M-113 group build:dec 15,07 to dec 15,08
    October 2004
Posted by sfcmac on Friday, June 20, 2008 9:02 PM
 White_R34 wrote:
Hello all an up date on my build I'm not going to build the M113A2CDN TOW I'm going to build the one with the ADATS unit on top. I don't know why my images dropped off as I still have them.
Right know I'm still working on my project's for the IDF GB and once that's done I'll only have my HalfTrack Gb with one halftrack to do and start on my project for this GB. I order a new M113 so I can try and build an IDF M113A2 Armored Ambulance version.
Wow I haven't seen one of those in like forever. They caused a real ruckus between the different branches in the Army. The Armor and Artillery guys were dead set against it siting cost and resources but the truth is it just worked too well. Air Defense Anti Tank system. ADATS. Well seems like ADA is covered pretty well in this GB
    July 2003
Posted by diggeraone on Sunday, June 22, 2008 7:20 PM
Well ya'll I have started my M-163a this week.Maybe if camera decides to cooperate,I could have some pics up...Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
    October 2004
Posted by sfcmac on Sunday, June 22, 2008 8:08 PM
 Awesome digger! I can't wait to see it. I guess you know I am crazy about Vulcans. Which kit are you working on? here is a pic of what I am looking at. I need to get some paint and the store is closed so I am stalled for a bit.Banged Head [banghead]
    July 2003
Posted by diggeraone on Monday, June 23, 2008 7:30 AM
The kit I have started is from Italeri and have got the supsendsion done along with the top and back end.This has me running into a snag in which I will have to redo the drivers hatch in order to fit right.Digger
    October 2007
Posted by White_R34 on Tuesday, June 24, 2008 8:00 AM
 Man sfcmac that's a lot of small parts, as for my build I'm going to start to night. I don't know if I'm going to detail the interior or not yet. But I'll post my starting work images late tomorrow. I'm not saying that I'm going to do 2 for this build but in some of my images of this version in the back ground you'll see one more being worked on. It's a IDF Armored Ambulance. One resion I want to build this version is that I have yet to see it done and I think it's about time some one builds it. So I'll do it.
Building the Impossible Is my main goal!!
    July 2003
Posted by diggeraone on Wednesday, June 25, 2008 8:52 AM
Well I got my hatch pivots and pen for the drivers hatch.Also there are a few other details that where wrong on this thing that needed correcting.So with the help of my camera,I might be able to take a few pics to show you my progress,Digger.
    July 2004
Posted by stikpusher on Thursday, June 26, 2008 11:34 PM
Started my M113 FSV tonite. So far Step 1 complete... Make a Toast [#toast] Looks like a nice simple build!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2007
Posted by White_R34 on Monday, June 30, 2008 5:06 PM
Hello all I have started on my M113, I started on those big front units. Now all the brass you see is not PE parts. I cut out the shapes that I needed to bind in to the items that I needed. I used brass mesh for the screens on the two side units. The big trouble came when I was making the vints for the box on the right side the (left side from the drivers view). I should have had 6 vint not 4. On top of the 3 units, you'll see 5 small parts., I cut out small strips and used a scraper tool to poke at the sheet to make it look like nut ends. speaker wire was used on the one side as some type of handlebar. I have some PE parts left over from my first build of my bradley that I can use to mount the shovel.
Box Art:
Next I will start on the roof, this will not be an easy build.
    July 2003
Posted by diggeraone on Wednesday, July 2, 2008 6:57 PM
Well my wife got in today and has the better camera to use.I should have some pics up tonight.This kit is not the best out there and a lot of modifications have to be done in order to make it look half way right,Digger.
    October 2004
Posted by sfcmac on Wednesday, July 2, 2008 7:18 PM
 Looking forward to seeing some pics. I have been doing a little at a time and have to paint as I go or would never be able to get to it after assembly.  The work on the work white 34 has done thus far is pretty stunning.Thumbs Up [tup]
    July 2003
Posted by diggeraone on Wednesday, July 2, 2008 10:37 PM
Well this is what it looks like right now.I am still figuring this camera out and the misses has yet to get the other out of the truck of hers.Digger
So far on this build I had to,one fix the drivers hatch it was off center,two sribe a panel line for upper engine hatch;there was none,three make an ammo box holder,four redo the front water/armor plate to make it come down some insted of sticking out,five I will have to make new hinge plates for the front,six redo the head light,the light dampingner was upside down and finially sand down some of the gaurds as well as the front exhuast on the side so the gaurd would fit properly.Oh i forgot the sink hole in the veiw window on scopes around the drivers hatch had to be filled along with a gap between the driver assm.and the roof.So to me this a one crappy build but i have worked it perty good so far.I would not recommened this kit unless if you like to do a whole lot of work with it,Digger.
    November 2003
Posted by GA.modelmaker on Thursday, July 10, 2008 3:03 PM
everyones builds are looking good. i have a little more to do on the kangaroo and finish up the jeep ambulance that i am doing for the forgotten war. then i will be able to start on the m106a1 i havent decide on how i am going to paint it yet. was the m106a1 uesd in ods? if so it will be another desert vechile i can paint.
    July 2003
Posted by diggeraone on Sunday, July 13, 2008 5:02 PM
Well this is the best on photos I can do for right now.This is what I have done on this so far.I am making it with a faded paint job,Digger.
    October 2004
Posted by sfcmac on Sunday, July 13, 2008 5:10 PM
 Hey digger that is looking like it is going together well for you! If you can think of it on a good sunny day take it outside and snap a few shots. My camera does better in the daylight and gets a bit fuzzy from the workshop lighting at night. I got my paint but Edward has come out with a 163 interior and exterior set. Probably not much diff between them and the others but I have to be sure.......Shock [:O] Finishing up my BOB GB project today and plan on going hot and heavy on the vulcan! Hope it looks like yours when I'm done!Cowboy [C):-)]
    July 2003
Posted by diggeraone on Sunday, July 13, 2008 6:32 PM
sfcmac,oh I will snap some shots of this puppy when it is done outside.I don't know if I will leave od or add the brown and german grey to camo it.If I do it will be faded to.With the tracks that are in the kit,it should make it look right.I have a lot of sink hole/or injector marks to fix on the tracks before I can install them.They are the link and lenght tracks,Digger.
    October 2007
Posted by White_R34 on Monday, July 14, 2008 7:35 PM
Good news guys I just got in my order from Evergreen so I can do my top unit with styrene tubbing and not K&S tubbing. I still don't know if I want to try the interior.
Images of the 1:1 scale ADATS.
Hay any one here know what this GB badge is or what it looks like??
    July 2003
Posted by diggeraone on Tuesday, July 15, 2008 7:15 AM
White have yet to design a group badge for this.I am wondering what ya'll ideal for it.As for me I was thinking of a badge that would change to all the variants of the m-113 or a choice of 4 different badges that might cover all.I would also need to learn on how to make one so everybody could have it.I have yet to do something like this,also we have till dec for the badge to be passed out to.So if you have and ideal for one or one that you made post it and we will all vote on it.Also can't wait to see your bad boy to take shape.Digger
    October 2004
Posted by sfcmac on Wednesday, July 16, 2008 1:22 PM
 Sorry to be so slow, Just finished a project for the BOB GB that took longer than I thought. It was my first Classic Airframes kit and a bit of a challenge. Gonna be focusing on the Vulcan today!Party [party] As far as a suggestion for the 113 GB Badge.  You may do something as simple as a track shoe which is a common component for all and the bane of most 113 models. Whatever you decide is fine I have lotsa faith in your imagination! Thumbs Up [tup]
    July 2003
Posted by diggeraone on Wednesday, July 16, 2008 2:17 PM
Well ya'll I have and ideal to pass by ya'll about a group badge on this.It hit me last night after I posted my reply.I was thinking like a horse in the backround and the M-113 in the fore front with the words,Work Horse of the Army.So let me know what ya'll think,Digger.
    October 2004
Posted by sfcmac on Wednesday, July 16, 2008 2:31 PM
 Hmmm been called that before. Sounds like a good idea to me .
    October 2007
Posted by White_R34 on Wednesday, July 16, 2008 6:37 PM
Yes i like that also you can go to the top of the GB section and one of the Forum guys can make the badge up for you. As for the image yes yes the horse should be in a faded look and the M113 should be that of the basic type as all othere versions are based off it. Any way back to the images color I thing a cammo color of a light tan back ground with the faded horse in a mid brown and then the M113 in a mild Olive Drab. and the words in old Military block letters in Black(Work Horse of the Military). Well that's My Idea. I'll draw up an image for you to look at later tonight I would love to try to make that type of badge but it would be more that I can do on  or in my photoshop program.
Oh I needed to add it's called a faded silhouette image of the horse or an out line of it as the secend layer over the tan background and the 3rd layer would be that of the stock M113 APC. Oh and the letters would also be on the background before the 2nd layer go's on.
If all that is to much you can always take the Image from the post above my post and put the words Work Horse of the Military or the way youfirst put it Work Horse of the Army just to the top and side and then put in the letters M113 in the middle on close the the bottom.
    November 2003
Posted by GA.modelmaker on Thursday, July 17, 2008 3:52 PM
hi guys your builds are looking great. i hope to start on mine this monday. but i am changing mine from the m-106a1 to the m-577 command post car. so digger if you can will you please update the list for me
    October 2004
Posted by sfcmac on Saturday, July 19, 2008 5:40 PM
 Been digging pretty deep into mine. Jumping into everything from paint colors to B.I.I. and stowage items. So far my most interesting accomplishment is my mess I've made. Stopping to regroup and reorganize lest I be overwhelmed. I am loving every sec of this build though!Party [party]
 I may have gone a wee bit overboard but I am trying totake the best from each kit and set and create from my memories. I got plenty of stuff and the will. Hopefully will find the talent. This PE stuff can be challenging.
    July 2003
Posted by diggeraone on Saturday, July 19, 2008 6:49 PM
sfcmac,from what i see it is looking good,Digger.
    January 2008
Posted by _jacob_ on Saturday, July 19, 2008 10:57 PM
I'm in, I'll build Trumpeter's 1/72 M113.
Jacob[{(-_-)}]
    October 2004
Posted by sfcmac on Monday, July 21, 2008 2:57 AM
 Well Digger that is still all pretty preliminary stuff measuring and positioning a lot of the scratch built stuff for the interior. I was serious when I said I want the ultimate vulcan. If I posted every little thing I've done you would be bored to death knowing more about this vehicle than you'd ever care too.  I cannot describe the great detail in the Hobby Fan turret enough. Down to some of the tiny quick release pins and battery hold downs. Everything there is also on the money and I can find no errors and very few small ommissions. The cables not only have the proper elbow connectors but have the lable sleeves molded in on the detail. Incredible obsessive stuff.
 These are the parts for step one. Have to paint everything first as it is so small you could never hit the details right when together. So many colors and tiny little details are flooding my memories. I can't believe the mental images flashing back as I build this thing knowing what every part is and what it does. The ammo drum even has tiny site glasses to see how many rounds are in the drum. I carefully filled them with future to replicate the glass as it is too small for clear parts cement.
 The only thing I have found missing thus far is the azimuth brakes located where the gunners knees would be in the turrent but that is easily replicated. I really need a better camera to focus on the tiny tiny details such as the gears and knobs on the drum loader.
Sorry to be so long winded but I am really into this kit.Thumbs Up [tup]
    November 2003
Posted by GA.modelmaker on Monday, July 21, 2008 1:21 PM
well i hope i was going to start mine today. but it looks like it will be on tuesday. i still have coupls of other gb to get done before i can start on the m-577.
    July 2003
Posted by diggeraone on Tuesday, July 22, 2008 7:04 AM
sfmac,i am glad you are having fun in this group build.the work you are doing is awsome to say the least and would love to see the details.i can say this is a heck of a group build and still have a lot of time to do more kits on this subject.i myself have another m-113 waiting in the wings to build that i picked up at hobby lobby for $10.we most defenitly are going to see a lot of interesting builds on this subjet.also lets see if we can get more people to join in,Digger.
    October 2004
Posted by sfcmac on Saturday, August 2, 2008 12:37 AM
 Ack been held up. Worked my tail off all last week and now my order for the detail sets has been delayed by a mixed up customer service girl. Not getting mailed until monday. So I am stalled in two builds until then.Confused [%-)] When I get it together I sure will try to include my thoughts and reasons for what I am doing. Don't say I didn't warn ya. Thumbs Up [tup]
    July 2004
Posted by stikpusher on Monday, August 4, 2008 5:16 PM
My Aussie M113FSV is taking final shape. The replacement AFV Club tracks arrived at my LHS. here are a few pics. Painting will begin real soon!
Turret
Top deck- I modified the drivers hatch for a half figure
Hull side view
Hull rear 3/4 view
Most components
Kit tracks on right, AFV/Club replacements on left
       - Plankton
LSM
