Well let me see this is pretty boring but very time consuming. I finished step 1 now step 2 is mostly putting on more cables. This is maddening as there are lots and lots!
Now The resin parts are not numbered so you have to do your best to match them to the parts diagram. When I do I have been writing the number on my table paper an placing the part above it. ( dont sneeze) Cant tell you how hard that was. Like a blooming puzzle!
Still have 2 extra not listed on the diagram. Hmmmmm guess I will have to search and see where they go? One thing they got right is in real life when a cable went bad it had to be routed an exact way otherwise it either would not reach or would catch or drag. Spent many many hours figuring those routes out.
Now the cables are resin and simply don't lay atop each other but are intertwined as on the real thing. Should be fun. Need about 12 tiny hands looks like. I'll sleep now and hit it again tommorrow!
The cable manuel was Bible thick and had equipment called a Stay-ICE to test it that would fill a pick-up truck bed. It was like trying to decifer codes one test reading at a time. WOW don't miss that. To cheat the 24M mechanics could sometimes use a simple multimeter with extended wires and just do a continuity check.
