WW2 Medium Bomber GB
    October 2007
Posted by 12Wings on Saturday, April 12, 2008 2:28 PM
Hey guys, I decided to redo the scratchbuilt dorsal turret. I didn't like how short the gun barrels looked, so I made some new ones. I also added an ammo belt. Here she is:
the ammo belts:
This one even moves up + down better than the original:
In the fuse.:
all comments welcomed, Thanks
... Ryan a.k.a. #12 Whoever invented soccer should be worshipped as a god!!
    June 2007
Posted by Hartmann352 on Tuesday, April 15, 2008 8:38 PM
Alright y'all, status report....have some stuff together, canopies masked & painted...but a bit of an issue w/the wing roots....advice on how to remedy really appreciated.
Photobucket" border="0" />Photobucket" border="0" />
Wow, I suck at these picky thingys...anywho...the shadow there at the wingroot is a gap between the wing and the recessed outline molded into the fuselage for the wing...I need to know the best way to solve the problem.
I humbly bow to those that ahve the knowledge to fix it & await the solution.
Make a Toast [#toast]
Dave
"Yesterday is history, Tomorrow a mystery, but Today is a gift. That is why it is called the "present".
    October 2007
Posted by 12Wings on Thursday, April 17, 2008 8:13 AM
Have you thought about using putty tho fill it in? I usually use that and it works great. You could also cut some styrene strips to shove in there- then fill it with gap filling super glue. The others will probably have some ideas too.
    March 2008
Posted by FastasEF on Thursday, April 17, 2008 8:24 PM
Little bit late but i'll hop in once I finish my IJN/IJA GB model.
I'll be doing Revell-Germanys 1/48 B-26B/G Marauder
    October 2007
Posted by 12Wings on Thursday, April 17, 2008 8:48 PM
I put you down on the list and no, your not late at all. This thing ends in March 09. I figured everyone was caught up in other GB's so I'd give them some time to join in.
    March 2008
Posted by FastasEF on Friday, April 18, 2008 12:34 AM
Sweet! Thanks.
I see some people were deciding between two planes to build, I being the same way. I also have a Monogram Dornier Do-217 E-5 waiting to be built. Decisions decisions ...
    October 2007
Posted by 12Wings on Friday, April 18, 2008 4:15 PM
 FastasEF wrote:
Sweet! Thanks.
On wikipedia it says the Dornier is a heavy bomber, but since its specs are close to the guidelines for this GB I'll let you build it. Tell me if you want me to put it on the list.
    July 2007
Posted by scorpr2 on Friday, April 18, 2008 9:08 PM
I use "liguid paper" to fill gaps on my a/c.  It works pretty good!  I use a sharp tooth pick to clean it up after it dries.  I hope this helps you out!
    March 2008
Posted by FastasEF on Saturday, April 19, 2008 2:09 AM
Nah, i'll just stick to the B-26. Looks like a fun kit and the Dornier will get built eventually.
    October 2007
Posted by 12Wings on Saturday, April 19, 2008 9:31 PM
Time for an update!
I've been working on the cockpit, scratchbuilding, painting and assembling. Here are some pics of the office before paint:
And with some paint:
The items higlighted in green are the scratchbuilt parts:
In the fuse:
This is the front landing gear bay. It was on the underside of the cockpit floor so I thought I'd show it off. Nothing on this was from scratch:
All comments welcomed.
    March 2008
Posted by kg4kpg on Sunday, April 20, 2008 12:32 AM
Looking good.  I got the interior painted and will get my office working this weekend hopefully.  Two projects going on at the same time.  I think after I do this 1/32 Spitfire, I'm going to stick to my 1/48 stuff for a while.  So much detail to do on the big bird I don't feel like I'm getting anywhere.Big Smile [:D]
    July 2006
Posted by telsono on Monday, April 21, 2008 6:10 PM
I would like to join this GB. My subject would be the old Supermodel 1/72 Cant Z.1007 with the twin tails.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    October 2007
Posted by 12Wings on Monday, April 21, 2008 6:45 PM
Mike T.
Your on the list
Can't wait to see her finished. I looks like it will be an interesting model.
    December 2005
Posted by viper_mp on Monday, April 21, 2008 8:34 PM
Hey Wings,
If its accepted, I'd like to switch my entry to an Italian IMAM Romeo 57bis.  The 57bis was a single seat bomber and carried one 500lb andtwo 250lb bombs.  It also had two 20mm cannons in the nose. I started it about a week ago, and didnt realize till now that its also a bomber.
Rob Folden
Secretary / Webmaster- IPMS Plastic Surgeons Member at Large-IPMS Hawkeye Modelers
    September 2012
Posted by namrednef on Tuesday, April 22, 2008 3:32 PM
Dave! It's moving along! When I had that type of wing root problem, I would glue in a piece of sheet styrene as a 'backing' before gluing the fuse together (That's if I thought to check that fit first!)
A backing will help avoid major putty shrinkage and make things easier on you.....if it's too late for that option......you must be patient.....feed some putty in with a toothpick and build it out slowly (a little blast of a primer paint will help keep shrinkage between putty coats, also). Once the putty is applied to a sanding stage.....careful shaping of the wing root with a triangular jeweler's file is best to start with.
 The file (careful file!) shouldn't mar the surroundings. You need to go slowly at this point until you get to a point where you can use a fine sanding stick or very fine wet sandpaper to finish off the joint.
Hope this helps!
    September 2012
Posted by namrednef on Tuesday, April 22, 2008 3:39 PM
Wings! Great progress! As you know I'm starting the same kit.......you scratch stuff in nice! The highlights of the nose gear bay are well done too! Those d@mned tubular seat legs always look too big to me, But what are you gonna do?
I'm thinking of painting mine a shade of green with maybe a black accent to try and shrink their size to the eye.
I'm off all next week and should have some WIP pics for the site!
Edit!: Those guns look much better! Nice work! I felt they were short, but wasn't sure.
    July 2006
Posted by telsono on Wednesday, April 23, 2008 2:32 PM
Wings
That Cant Z.1007 has always been an eyecatcher for me. I have a set of RCR PE for it and Sky Decals set for Italian medium bombers so I have a good range of choices for it. This aircraft performed well but had an Achilles Heel. The wings were wooden which made it vulnerable to tracer ammo which would start fires easily. It was one of the bombers used heavily in the attacks upon Malta.
Mike T.
    March 2008
Posted by raider83 on Wednesday, April 23, 2008 3:23 PM
Hey 12wings, I'm not part of this GB, but I have a suggestion on your pit.  the scratchbuilt stuff looks great.  But have you tried washes or drybrushing in there? That would make it look even better and really pop out the detail. Great work though so farBig Smile [:D]
On the bench: Monogram 1/48 Kingfisher Cardinal Ritter- Class 1A 2008 Indiana State Football Champs
    October 2007
Posted by 12Wings on Wednesday, April 23, 2008 4:09 PM
thanks,
I was thinking of doing that but kind of forgot about it and got caught up with the bomb bay. Thanks for reminding me.
    October 2007
Posted by 12Wings on Wednesday, April 23, 2008 4:45 PM
I thought you were building the Revell kit? Anyway, thanks for the input.
    October 2007
Posted by 12Wings on Friday, May 2, 2008 5:21 PM
Before you other B-26 builders close up your fuselages, can you take a couple pics. of the tail turret for meQuestion [?] I need to do some improvements on the tail turret but can't seem to find any good pics of it. Thanks!!!!
    October 2007
Posted by 12Wings on Saturday, May 3, 2008 3:44 PM
Update Time!
Here's the nose and the instrument panel:
Here is one of the props that still needs some silver paint chipping and the tires that I flattened with a file:
And finally here is the bomb bay that will be opened up. The big box in the back is a fuel tank that could be added to the aft bay. I didn't know what it looked like so I kinda imagined it up. The tank will be covered up:
These are the bay doors:
Thanks, all comments welcomed.
    May 2006
Posted by Dr. Faust on Saturday, May 3, 2008 11:48 PM
Hey guys! I have a Italeri B-25 I just opened and started some glue up. Can I join? My first GB?
Would love to build a model with some Bros.
And exchange some insights and tips on the build process?
I looked at some other GB's and I thought this one fits the B-25 pretty good.
Looking thru the build log you guys are doing some mighty fine work.
I'm in if it's OK?
Just build it (and post pics when youre done)
    October 2007
Posted by 12Wings on Sunday, May 4, 2008 9:52 AM
I'm in if it's OK?
Your IN!
    March 2008
Posted by kg4kpg on Sunday, May 4, 2008 9:30 PM
Here are some of my A-20 update shots.
Not going to bad I think.  A long way to go.
    October 2007
Posted by 12Wings on Monday, May 5, 2008 7:02 PM
kg4kgp,
lookinn good. What kind of engines did the Havoc use?
    May 2006
Posted by Dr. Faust on Monday, May 5, 2008 8:26 PM
Nice work guys', I think the Havoc had the Wright Cyclone 2600's. I'll have to check that as I have that A/C in my stash. Very cool aircraft designed by some of the best at that time.
I'll have some WIP pics soon, only have some glue ups as of yet.
    March 2008
Posted by kg4kpg on Monday, May 5, 2008 8:28 PM
user="#12Wings"]
kg4kgp,
According to Daveswarbirds.com it used Wright R-2600-23 with 1600 hp each.
    May 2006
Posted by Dr. Faust on Monday, May 5, 2008 8:40 PM
 kg4kpg wrote:
user="#12Wings"]
kg4kgp,
Yep, just to interject on the A-20 powerplant, Horse Power was its' achillies heel. A couple hundred or so per would have helped. The basic design was there, just didn't have the Nads to get it done.
    March 2008
Posted by kg4kpg on Saturday, May 10, 2008 8:17 PM
Okay, wings are on and after a few seems are cleaned up we're going to paint.
