Hah! I was actually on here last night to issue the assignments, but I figured if I did that, some joker would wait until the very last second to squeeze in. So here we are now! 1st of August already, if you can believe that! Which leaves us 2 months to secure as much plastic-and-PE goodness prior to the start of the build. Without further ado, here is the official roster for October 1st: Espins1 Sd.Kfz. 251/1: Basic SPW fitted with the FuSpG ‘F’ R/T unit. SMJModeler Sd.Kfz. 251/1: Stuka Zu Fuss Panzer88 Sd.Kfz. 251/1: Falke IR vehicle Dupes Sd.Kfz. 251/2: 8cm GrW34 Mortar carrier MPKev31b Sd.Kfz. 251/3: Communications vehicle BBrowniii Sd.Kfz. 251/4: Light artillery tractor White_R34 Sd.Kfz. 251/5: Engineer vehicle for special assault engineers Luftwoller Sd.Kfz. 251/6: Command Vehicle Assurgeant Sd.Kfz. 251/7: Engineer vehicle basic Hermes Sd.Kfz. 251/8: Field Ambulance JMart Sd.Kfz. 251/9: 7.5cm KwK37 L/24 Support vehicle Sfcmac Sd.Kfz. 251/10: 3.7cm PaK36 light anti-tank gun vehicle Lewbud Sd.Kfz. 251/16: Flamethrower vehicle Wing_Nut Sd.Kfz. 251/17: 2cm Flak38 AA vehicle Bish Sd.Kfz. 251/17: 2cm KwK38 Schwebelafette FastasEF Sd.Kfz. 251/17: Command vehicle Pordoi Sd.Kfz. 251/18: Artillery observation and command vehicle Bufflehead Sd.Kfz. 251/20: 60cm IR “Uhu” searchlight vehicle (Ausf. D only) Russamys Sd.Kfz. 251/21: Triple 2cm MG151 and 151/20 AA vehicle Panzerguy Sd.Kfz. 251/22: 7.5cm Pak40 anti-tank vehicle Moose421 Sd.Kfz. 251/23: Reconnaissance 2cm KwK38 turret Which leaves us with the following variants, should anyone decide to get in late, or want to do a second build (personally, I'm leaning toward doing an /11 or /19 if no one else is interested): x Sd.Kfz. 251/11: Telephone communications vehicle x Sd.Kfz. 251/12: Artillery surveying vehicle x Sd.Kfz. 251/13: Artillery surveying vehicle (Sound recording) x Sd.Kfz. 251/14: Artillery surveying vehicle (Sound ranging) x Sd.Kfz. 251/15: Artillery surveying vehicle (Flash spotting) x Sd.Kfz. 251/19: Mobile telephone exchange vehicle I'll post all of this up on the front page here in a bit, as well as more info here, no doubt, that I'll remember after drinking some more coffee. Heh. |
