Russ - I've got you down for the /21 (for now, anyways) - and I'll move myself over into the /2 slot.
Pordoi - hmmmm. Well, I already have someone (FastasEF) slotted in the /17 command. If he's willing to give that slot up, or is unable to secure the kit, then I can certainly put you in there. Otherwise the only other option is to do one of the variants that will require some scratchbuilding/modification. I'm sure between me and Hermes we could help you find some info on what you'd need.
FastasEF - still committed to the GB? If yes, then no worries. Just checking to see if you've had any luck finding a /17 command (see above).
As things stand right now, the GB assignments look something like this:
251 GB Kit Assignments (as of July 15)
Espins1 Sd.Kfz. 251/1: Basic SPW fitted with the FuSpG ‘F’ R/T unit.
SMJModeler Sd.Kfz. 251/1: Stuka Zu Fuss
Panzer88 Sd.Kfz. 251/1: Falke IR vehicle
Dupes Sd.Kfz. 251/2: 8cm GrW34 Mortar carrier
MPKev31b Sd.Kfz. 251/3: Communications vehicle
BBrowniii Sd.Kfz. 251/4: Light artillery tractor
White_R34 Sd.Kfz. 251/5: Engineer vehicle for special assault engineers
Luftwoller Sd.Kfz. 251/6: Command Vehicle
Assurgeant Sd.Kfz. 251/7: Engineer vehicle basic
Hermes Sd.Kfz. 251/8: Field Ambulance
JMart Sd.Kfz. 251/9: 7.5cm KwK37 L/24 Support vehicle
Sfcmac Sd.Kfz. 251/10: 3.7cm PaK36 light anti-tank gun vehicle
x Sd.Kfz. 251/11: Telephone communications vehicle
x Sd.Kfz. 251/12: Artillery surveying vehicle
x Sd.Kfz. 251/13: Artillery surveying vehicle (Sound recording)
x Sd.Kfz. 251/14: Artillery surveying vehicle (Sound ranging)
x Sd.Kfz. 251/15: Artillery surveying vehicle (Flash spotting)
Lewbud Sd.Kfz. 251/16: Flamethrower vehicle
Wing_Nut Sd.Kfz. 251/17: 2cm Flak38 AA vehicle
Bish Sd.Kfz. 251/17: 2cm KwK38 Schwebelafette
FastasEF Sd.Kfz. 251/17: Command vehicle
x Sd.Kfz. 251/18: Artillery observation and command vehicle
x Sd.Kfz. 251/19: Mobile telephone exchange vehicle
Bufflehead Sd.Kfz. 251/20: 60cm IR “Uhu” searchlight vehicle (Ausf. D only)
Russamys Sd.Kfz. 251/21: Triple 2cm MG151 and 151/20 AA vehicle
Panzerguy Sd.Kfz. 251/22: 7.5cm Pak40 anti-tank vehicle
Moose421 Sd.Kfz. 251/23: Reconnaissance 2cm KwK38 turret
