Greetings, and welcome to yet another episode of Yet Another Stryker. In tonight's action-packed episode, Johnny asks Emma to go to the barnraising, crazy Uncle Ed can't make bail, and we put full slats on the Stryker.
(its late...my mind is going...Dave...stop, Dave...)
Where the heck was I...oh, yeah, I promised psstoff995 a "Slat bracket aligner/paint mask". And so he shall get his slat bracket aligner/paint mask...but first, a view of what is being masked, in this case, the brackets for the right side slat assembly.
And without further ado, I give to you, the
Slat bracket aligner/paint mask.
The faces of the brackets attach to various points along the slat assembly frame. In order to keep them aligned and somewhat shielded from damage, I bent a piece of hollow aluminum tubing into the general shape of the slats, or at least in such a way that all (or most, as I was short by about an inch) of the brackets made contact with the shape. I secured the shape using Micro Mask liquid frisket, as it hardens enough to hold things together, but peels off easier than white glue.
The shape also serves as a painting mask. I have no intention of painting this monster with the slats attached. They get painted as separate assemblies, then attached later and touched up. Masking the parts now means I wont have to scrape paint later, potentially knocking a bracket off.
Here's a view of the left side, before most of the brackets have been installed. Note the four brackets on the side hatch that hold its separate slat frame.
Once I got all the left side brackets installed (they were pretty much identical to the right side, with a few differences), I was able to test-fit the left side slat assembly. It needs a little massaging, but I think I can coerce it to fit.
I apologize for the poor quality of this next image. I'm using a handheld 2-megapixel Nikon Coolpix to shoot these, not my good 10-megapixel D200. The main purpose of this shot is to show the toothpick clamped to the bottom of the slat assembly. The gap is for the side hatch slat frame, which isnt in place yet, so the only thing holding the left side of the slat assembly to the right side is that thin folded square tube along the top, glued to the frame next to it (near the clip), and three barely-loadbearing slats. The clamped toothpick adds strength to the slat assembly while its being fitted in place.
(And yes, I discovered this inherent weakness of this particular assembly when it fell off the brackets and broke in half.)
Here's a view underneath. The horizontal brackets along the bottom attach to the bottom tube of the slat frame.
I couldnt contain myself. I had the left side gently clamped into place and really wanted to see what this thing looked like with the right side attached. The fit wasnt perfect (it fit over the alignment/mask, but not very well).
And yes, I let loose with my best "mad scientist evil laugh" when I clamped the other side in place.
One more image... mwa ha ha...MWAAA HAHAHAHA....
Ok, I'm better now. Yeah, right, and if you believe that, I have bridge in Cleveland for sale for you. I'm seeing slats in my sleep. I align my french fries to look like slats. I think I'm getting slat-happy.
Anyhoo, once I get a few more minor bits and pieces in place (another aligner/mask, the side door slat frame, the rear corner piece and the modified headlights), I can start worrying about painting this beastie. Oh, that should be a joy.
Ranger Joe, Defender of Bunnies and Deprived of Sleep
(Daisy, D a i s y , . . . )
