Zvezda M-3 Scout Car ~FINISHED Pg. 9~
    December 2007
Posted by mg.mikael on Saturday, January 10, 2009 4:12 PM
Here's the kit I'm currently working on, a 1/35 Zvezda M-3 Scout Car, I'm building it for the Lend-Lease GB. Plan to put it in Russian markings, in order to make it a US vehicle that was given to the Soviets via Lend-Lease.
Here's some pics of my progress on the M-3 Scout Car. Finished one of the axles, took longer then I thought it would, due to mold seams. Alot of putty had to be used on some parts due to some big dents and errors caused by Zvezda when they were molding this kit. Other then that progress is moving along nicely, most of the parts fit together beautifully. Sanded down most of the ejector pin marks on the outside hull of the cabin (as you can tell there were alot of ejector pin marks.)
All comments, suggestions, and questions are welcome.Smile
"A good plan executed now is better than a perfect plan next week." - George S. Patton
  Photobucket
    January 2005
Posted by biffa on Saturday, January 10, 2009 4:37 PM
Had this one in the pile for a while now Mikael waiting for a cheap etch set to pop up on ebay, i look forward to seeing how yours goes maybe i wont need one after all but i see all ready that it will definatly need some TLC good luck i will be following.
Ron g.
    May 2005
Posted by terry35 on Saturday, January 10, 2009 4:46 PM
Is that not the old Italeri mould, if it is then I always thought it was O.K. but then I never had the kit.
Terry.
    December 2007
Posted by mg.mikael on Saturday, January 10, 2009 5:26 PM
biffa: Huh, didn't even know their was a PE set avaible. Oh well, I'm sure I can make this kit work without it.Smile [:)]
terry35: It's a re-box of the 40 year old Peerless Max M-3 Scout Car that has also been re-boxed by Italeri, Testors, and Airfix.
  Photobucket
    May 2005
Posted by terry35 on Saturday, January 10, 2009 6:23 PM
Didn't realise it was that old. I only remember the Italeri release, any good luck withthe project.
Terry.
    December 2007
Posted by mg.mikael on Sunday, January 11, 2009 6:35 PM
terry35: It's old alright, but most of detail still looks good, however some parts are showing their age. Thanks for checkin' out my build.Smile [:)]
  Photobucket
Posted by Rob Gronovius on Monday, January 12, 2009 7:19 AM
I think I still have one of the older issues that come with vinyl tires, canvas top and crew figures. Those Peerless Max kits were way ahead of their time, most came with vinyl tires, the 155mm gun came with a metal barrel and metal recoil springs.
    December 2007
Posted by mg.mikael on Monday, January 12, 2009 9:33 PM
 I wish this kit had vinyl tires, all I get is stryene ones that are in two pieces.Yuck [yuck] I can see alot of sanding in my future.
  Photobucket
    June 2008
Posted by Hans von Hammer on Monday, January 12, 2009 10:51 PM
I wish this kit had vinyl tires, all I get is stryene ones that are in two pieces.Yuck <img src=" border="0" width="15" height="15" /> I can see alot of sanding in my future.
Never met any vinyl tires that didn't need to be sanded either... In fact, they HAVE to be sanded to get any kind of "used" look to 'em...
    December 2007
Posted by mg.mikael on Friday, January 16, 2009 1:02 PM
Here's what I finished so far on my scout car, construction is going quicker then I thought. The tires are finished and the seam is sanded away, had to use three different grits. Along with a few other random parts inside the cabin.
The ejector pin marks on the lower hull have been sanded down and filled with Testor's contour putty. As you can tell there were alot.Yuck [yuck]
A part of the engine has been put into place, alot of putty had to be put around it. Since it had no fit at all with the other parts, it sort of just floated around in that spot. (there were no locating marks/pins at all)
Finally both axles are finished, abit of seam sanding and filling in of incorrect molding(Zvezda's fault) was neccesary.
 Thanks for looking, all comments and questions welcome.Smile [:)]
  Photobucket
    May 2005
Posted by terry35 on Saturday, January 17, 2009 4:23 PM
Well ,what you have done so far looks good. Can't say much for now but I'm very curious about how this one will progress, I seem to remember the Italeri box model being painted by Verlinden, when I was younger I was always impressed by this, it looked great, then you stated it was a 40 year old mould,,,,,,,,WOW......... that was an eye opener.
Terry.
    July 2006
Posted by constructor on Saturday, January 17, 2009 6:48 PM
Terry.
I had it as the Peerless kit before. I hope they improve on it somehow.
    December 2007
Posted by mg.mikael on Monday, January 19, 2009 11:53 AM
Finally started painting my M-3 scout car. I'm using Model Master Acrylic Olive Drab, and as you can see the base coat has been applied on the lower support structure of the vehicle. Later today I'll get the axles and suspension in place.
I also masked off the tire hubs with silly putty, so now the tires can be painted. They'll be painted using Floquil enamel Weathered Black.
As always all comments, suggestions, and questions welcome!Smile [:)]
  Photobucket
    December 2007
Posted by mg.mikael on Saturday, January 24, 2009 3:55 PM
I was able to get quite a bit of work done yesterday an today on my scout car. I finished the muffler, axles, suspension, and everything else on the bottom half of this vehicle. With all the parts in place I was able to start drybrushing some dark-steel paint, made from a mixture of Testor's enamel Steel and Flat Black. I also start painting the cabin with the MM acrylic Olive Drab.
The tires have also been finished, so here they are without the Silly Putty mask. Though it will be awhile before they can go on permanetly.
Now construction will be moving to the cabin, where work on the eight seats will commence. It should take awhile, since I want to upgrade each seat with more of a realistic fabric texture. Thanks for looking, all comments, questions, and suggestions welcome.Smile [:)]
  Photobucket
    April 2008
Posted by Huxy on Saturday, January 24, 2009 4:03 PM
That looks sweet....  Tell me, you know of any acrylic that match the weatherd black? It looks spot on.
"Every War Starts And Ends With An Invasion".
    December 2007
Posted by mg.mikael on Saturday, January 24, 2009 11:47 PM
Huxy, thanks for the comments.Smile [:)] As for the question, I currently use Floquil enamel Weathered Black. As for an acrylic, Floquil nor any other company makes a paint that is like this to my knowledge. Their is the PollyScale acrylic Grimy Black, but I don't know how this paint looks when dryed, since it's more of a weathering paint like the colors mud and grime. If you want to check the paints Floquil/PollyScale offer here's the link to the paints they offer: http://www.testors.com/category/133504/Floquil
  Photobucket
    August 2007
Posted by MaxSheridan on Sunday, January 25, 2009 11:56 AM
I've used Tamiya's NATO black XF-69, It makes a really nice weathered black for tires and such. I picked up that tip from someone on the forums here, so I'm not gonna take credit!Big Smile [:D]
Nice work, by the way, Mg!Thumbs Up [tup] I got one of these in the stash, and I've been following this for tips.Big Smile [:D]
-Mark
    November 2006
Posted by jadgpanther302 on Sunday, January 25, 2009 2:05 PM
polyscales engine black works well for tires, goes on well too.
    December 2007
Posted by mg.mikael on Sunday, January 25, 2009 4:06 PM
MaxSheridan and jadgpanther302: Thanks for the comments and for checkin' out my build!Smile [:)]
  Photobucket
    July 2004
Posted by wbill76 on Monday, January 26, 2009 12:51 PM
Making good progress MG, looking forward to the next update. Thumbs Up [tup]
    December 2007
Posted by mg.mikael on Monday, January 26, 2009 7:59 PM
Thanks for the comments, wbill76!
  Photobucket
    December 2007
Posted by mg.mikael on Saturday, April 11, 2009 1:59 PM
Yeah, I know it's been awhile since I last posted an update, due to the fact I got sidetracked by my Universal Carrier. But with that completed, I can once again start work on this build.
 I started the upper hull parts of the scout car. I think the pic below says it all. It needs massive sanding, and a ton of putty. These pieces that are just plain riddled with ejector pin marks. And I mean riddled, heck some of the ejector pin marks almost seem to be in places impossible to sand without wrecking the detail. If their's a carpet monster, then theirs one that's ten times as grim, and that's the ejector pin monster. This one bites.....hard.Evil [}:)]
The head rests for all the seats have two holes(not all the way through, but almost), like for positioning on each one. However there's no positioning marks on the seats(geez) so I gotta be careful when gluing so it doesn't melt the thin plastic.
As for the seat cushions themselves, I finally put on the tissue to give them more texture. But you gotta remove a pestering seam that can show even through the tissue.
Finally the seats themselves, a little flash had to be removed. However here is where the kit's aging molds shows once again.Dead [xx(] The tops of the seats have just plain bad molding(it's an old mold), so quite a bit of sanding is neccessary, of which you can see also in the pic.
  Photobucket
    May 2005
Posted by terry35 on Saturday, April 11, 2009 2:25 PM
MG the seats are coming along well and wow those pin marks look vicious. Progress is slow on this one, looking forward to seeing you progress further.
Good luck,
Terry.
    December 2007
Posted by mg.mikael on Sunday, April 12, 2009 1:54 PM
Good luck,
Terry.
Thanks for lookin' in! Hopefully I'll get alot of work done this week, since I'm on vacation aka spring break......hopefully.
  Photobucket
Dre
    June 2007
Posted by Dre on Sunday, April 12, 2009 6:30 PM
Looking good thus far, but a few look-outs that I found on mine.  The bulged out sides on the cushions didn't fit right, so I ground off the bulges to fit the profile of the rolled upholstery seam on the top.  They fit much better this way.
Really nice touch on the tissue paper, I can't wait to see how that looks painted and weathered.  I'm going to remember this for the future!
I had fit issues with the top hood panel meeting the side panels evenly, so that got glued down in sections for a seamless appearance.  Also watch the decals, while they're OK and in register, they sure didn't want to go down over all of those tie-down lumps on the sides or over the hinges on the top hood panel.  Lots of Solvaset and pin-pricks later, they still don't 'lay down' the way other decals do- a thinner decal with a little more elasticity would have been nice.  If you have any spare Soviet stars and slogans from a better source, I'd use them over the kit supplied decals.
Dry fitting the wheels on mine showed that only two wheels would touch ground at any time, so I loaded up the body with weights (3 Tamiya paint bottles!) to force all 4 wheels flat and even when I glued them on.  That actually worked out well and didn't give any of the wheels a nasty camber!  I guess that the plastic is soft enough to absorb the difference.
Hope these help and looking forward to seeing your's finished!
    December 2007
Posted by mg.mikael on Sunday, April 12, 2009 8:14 PM
Thanks a million for the tips, Dre!Bow [bow] Thanks for lettin' me know about the decals, I think I have some decal sheets left over from a Katyusha build that's filled with Ruskie stars and etc. I guess I better go find it. As for the wheels, I noticed the same thing, and I'm still trying to figure out how I'm gonna solve it. But thanks to your tip, I might just do what you did.
  Photobucket
    December 2007
Posted by mg.mikael on Thursday, April 16, 2009 2:32 PM
Here's my progress so far on the scout, going a bit slower then I woud like(probably due to the fact every, single piece needs massive cleanupGrumpy [|(].) Anyways I got all the seats in finally, and I got all the locating hulls on the bottom of the hull filled in(you got to remeber to do this or it will be impossible later.) The seats are painted with a mixture of Testor's enamel brown & black. As for the drybrushing on the floor and etc. I used a mixture of Testor's Steel & black.
For the upper hull pieces, the marks have been cleaned up and painted. Now I'm just test fitting them, because I just know their's gonna be problems. The fender pieces have also been put together, but they obviously need a ton of cleaning up. Plus on those two small pieces I decided I'm gonna scratch the springs that react w/the counterweight (so some modification had to happen, such as the filling in of locating holes for the kit piece.)
All comments, questions, and suggestions, welcome as always!Smile [:)]
  Photobucket
Dre
    June 2007
Posted by Dre on Friday, April 17, 2009 12:07 PM
Looking good so far, mg.  I like the tissue paper texture- that worked out well.  How did the seats fit?
    July 2004
Posted by wbill76 on Friday, April 17, 2009 1:56 PM
Very nice work on the seats and added texture. Thumbs Up [tup] I hear you about the added time due to clean-up and it's a common thing with the EE kits unfortunately, especially the older ones. Looks like you're tackling it fine though, look forward to the next update. Wink [;)]
    December 2007
Posted by mg.mikael on Friday, April 17, 2009 9:35 PM
Dre- You were right about the seats, the bulge had to be completley trimmed off for the seat cushions to fit. That I did with spure cutters, that's seriously the amount of stryene that had to be removed.Shock [:O]
wbill76- Thanks for the comments and for lookin' in!Cool [8D]
  Photobucket
