Build Update:
I was able to get some great traction this weekend on weathering and track assembly while balancing quality family time.
On Friday night I was able to finish applying the dot filter method to the turret and hull followed by a pin wash of black and brown wash oil paints. I then very carefully using Model Master Schwartsgrau enamel rather than the Poly Scale Acrylic Reefer Grey I had used on the last tank applied a light chipping effect over the entire hull and Turret. I used the swing out magnifyer and chanted "Less is More" the entire time. I then appiled a variety of MIG pigments again sparingly to the turret and hull.
On Saturday after some plannned family time I sarted on the Magic Track assembly, painting and mounting. My confidence was high due to the success I had on my second set of Magic Tracks which was short lived!
I set up my first set of tracks according to Karl's tutorial and applied Testors slow setting glue whcih gave me an hour window to mount the road wheels for that side.
The first three suspension arms snapped off in my hands trying to mount the the road wheels!
I almost lost it but I reminded myself that this was "fun" and methodically glued each suspension arm back on with thick CA and then still had time to basecoat, drybrush and apply an oil wash to the track before mounting!!
I also had a slight problem because I doubted Bill. On his build log he had indicated to use 92 links for each side and I disagreed with my vast amounts of experience compared to him that it should be 94. I was incorrect it was 92.
It turned out okay so here are a few pics: I still need to mount the antenna, and I just basecoated all the Jerry Cans and other stowage I am going to mount on the rear rack.
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation."
Herbert Spencer
