Trumpeter 1/35 M198 155mm Howitzer, Finished, 8/09/09
    July 2006
Posted by redleg12 on Saturday, June 20, 2009 8:32 PM
Final assembly is just about complete. The sights will be mounted after weathering. Sights will normally stay clean since the sights are only mounted in the firing position and are in their case during travel.
One problem with the sights is Trumpeter forgot to include the elbow telescope. Their decals have the direct fire plate for the AG side but without an elbow scope it would be hard to direct fire. I will scratch up a scope using some parts from an AFV M102 howitzer and some styrene tube (pics on the next update).
After assembling the elevating and traversing hand wheels and the travel lock folded under the tube, I applied the kit decals. The decal set for the kit if pretty good but is missing the serial number plates for the carriage, howitzer and recoil system.
Here is the elevating hand wheel and details
This shows the grease fitting on the barrel bushing which is dry brushed with Gunmetal. Also the travel lock in the folded position. The pins and collier are also dry brushed with Gunmetal to show ware.
Looking from the rear, you can see the Carriage, Howitzer and Recoil system serial number plates. I added these using Archer modern data plates.
Here is a view of a trail showing edge ware and scratches applied with dry brush Gunmetal.
I dry brushed the inside tube section of the muzzle brake with Gunmetal. Also gave the nice shiny tires the worn look and edge wear using a scotch pad
Here is a rear view of the howitzer
Besides the model work it was off to the wood shop to make the base (12" x 14") and stain it.
Next up is weathering on the model, sights and air lines to finish off.  Then we will get into the presentation on the base showing the emplaced howitzer.
Happy Fathers Day to all!!!
Total hours this update - 6.5 hours
Total hours this overall build - 34.5
Thanks for looking and as always, all comments are welcome.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    October 2007
Posted by panzerguy on Sunday, June 21, 2009 6:51 PM
    Mike this is one sweet piece. I've been peeking in here and there on your build and have to say this is one of the sleekest arty pieces I've seen in a while. Your builds definitely do bring some diversity to this forum. Looking foward to seeing what you do with the base.
"Happiness is a belt fed weapon"
    July 2006
Posted by redleg12 on Sunday, June 21, 2009 7:54 PM
Steve - Thanks, I am glad you are enjoying the different!! Artillery is definitly the minority in armor modeling. I being the "odd ball" only build artillery and the other strange and otuse vehicles!! Like many of you enjoy the world of PZ or Sherman, I enjoy going the different path.
I am glad to bring diversity and hope people enjoy it and learn from it. I'm always happy when you stop by.
The M198 is a cool looking artillery weapon. Going through all the accessories for the "stuff" around the gun. That will start shortly!!
Thanks again
Rounds Complete!!
    April 2007
Posted by SMJmodeler on Monday, June 22, 2009 8:41 AM
 redleg12 wrote:
Great shot Mike, I love the combo of camo colors!  The weathering should make it even better! I'm looking forward to seeing what you do with the hydraulics and those huge joints for the legs behind the wheels.
 redleg12 wrote:
Questions: Are the legs so huge for counterbalance or recoil support?...or both?  Does that plate at the end of the legs get driven into dirt?  What if the dirt is really hard or there's no support vehicle to assist?...would this baby just roll way back after firing in that case?  Does the anchoring, or lack of, effect it's range and/or accuracy?...I suspect yes..but how much?
    July 2006
Posted by redleg12 on Monday, June 22, 2009 9:32 AM
 SMJmodeler wrote:
OK....Lets answer these one at a time
Are the legs so huge for counterbalance or recoil support?...or both? Yes....The longer "trails" help counter balance the load when towing. Also because of the design, a front base plate to pivot, the longer legs give better support during the shock of recoil
Does that plate at the end of the legs get driven into dirt? Yes...the "spades" are intended to be dug in.
What if the dirt is really hard or there's no support vehicle to assist? If the dirt is really hard or emplaced on rock, the spades need to be "blocked and braced" to prevent the gun from moving. This could be done with logs. The weapon is normally towed by an M9oo series 5 ton truck or now the new LMTV series 5 ton. If the weapon is "air assualted" and no vehicle present the crew would just have to hup it.
In general, the battery commander during his recon of a new position would evaluate the ground conditions and try not to emplace where it could not be dug in. If there was a situation where this was impossible, he would normally request engineer support as part of the battery occupation of the new position.
would this baby just roll way back after firing in that case? If the weapon was not supported, the gun would encounter "displacement" or move each time it is fired. The crew need to determine displacement after each round that is fired. After reaching a maximum, the gun would have to be "re-laid" or re-surveyed. This is not a situation you want to be in.
Does the anchoring, or lack of, effect it's range and/or accuracy?. Yes...as the wepon displaces, it can change the position of the wepon not only to the rear, but sideways, if the barrel when fired was not on center with the carriage.
I suspect yes..but how much? Yes for sure.....how much it is off target depends on the amount of the displacement, the range you are firing at and if you are firing high angle or low angle. When firing high angle, the "range probable error" is higher since the round ins in the air longer, goes higher and is susectable to more atmospheric conditions. To give you an idea, the PE at low angle and 5,000 meters in range is ~20 meters at high angle and range of 25,000 meters the PE is ~105 meters.
Couple that with displacement and you could be off by a few hunderd meters.
Artillery relies on survey, ballistic calculation, meterorlogical input and other factors to shoot long distances accuratly. It's not a tank where you can see the target and shoot it. You may be shooting over a mountain and hitting a target on the other side.
All of these inputs are put into ballistic formulas to calculte the "deflection" azimuth and "quadrent" elevation for a specific round type with a specific powder chage.
Hope this helps
Rounds Complete!!
    July 2004
Posted by wbill76 on Monday, June 22, 2009 2:07 PM
Now you're in the best part Mike, dealing with all the details! Coming along nicely, look forward to the next "round". Laugh [(-D]
    July 2006
Posted by redleg12 on Monday, June 22, 2009 4:19 PM
Bill - Thanks for stopping in and your comments. Yep...looking at all the details...on and off the weapon. It will make for the fun part for sure.
Thanks......putting the fuse on the next round now!!
Rounds Complete!!
    June 2008
Posted by Hans von Hammer on Monday, June 22, 2009 4:44 PM
Just expanding upon Redleg's answer, we carried two railroad tie sections on the gun trucks (this was for M101 105mm, but the deal's the same for the M198).  Each section was about 3 feet long with holes bored through the middle...  We also had ice stakes about 4 feet long made of solid steel and pointed at one end.  When we had to emplace on frozen ground, or rocky areas too tough for digging, we use these "Dead-men" (the ties) in position behind the spades...
We would displace a skoshi-bit more than if we had dug in, but it would settle down by the third or fourth round..
    June 2009
Posted by Guney on Monday, June 22, 2009 4:59 PM
Fine progress....:)
Are you recommend this kit?
    June 2008
Posted by Hans von Hammer on Monday, June 22, 2009 5:02 PM
Who, Me?  I'll do any artillery kit... It's just a matter finding them...
    July 2006
Posted by redleg12 on Monday, June 22, 2009 8:29 PM
Guney - This builds into a nice model. It has its quirks which I hope I pointed all in this thread.
So yes I would recommend it and thanks for looking in
HVH - Had the ice stakes from the M102 that we used on the M101A1. Rock and Ice let you know why most Infantry are "small" guys (look up the latin derivation of the word) and most Redlegs are big Censored [censored].
Rounds Complete!!
    June 2008
Posted by Hans von Hammer on Monday, June 22, 2009 8:54 PM
Ya, we had to fabricate the ice stakes, they weren't BII on M101s..
    April 2007
Posted by SMJmodeler on Tuesday, June 23, 2009 9:43 AM
Mike: Thanks for all the info!...it's very interesting...
    July 2006
Posted by redleg12 on Wednesday, June 24, 2009 10:39 AM
Steve - Your more than welcome. That's what this site is for, to share, teach and learn!!
Rounds Complete!!
    December 2007
Posted by 1SG Davis on Wednesday, June 24, 2009 11:06 PM
Mike,
I must sadly admit that being an 11B I'm not smart enough to know if I should be offended by the above reply to Hans Von Hammer (still lookin for my Latin dictionary to try and figure it out)
That aside, I've enjoyed looking at your build and have especially appriciated all the infomation as you've gone along.  As always, outstanding work!
Gary
    July 2006
Posted by redleg12 on Thursday, June 25, 2009 5:04 AM
Gary - Thanks and Laugh [(-D]
It is always great to have top stick his head in the tent. As far as above......now you should never be offended by this old soldier. At 6' 4" I was too big of a target. The big guys always humped rounds.
Besides you should realize old soliders were arrogant.....now they are perfect!Wink [;)]
Thanks for the comment on the build. I always try to keep it interesting.
Rounds Complete!!
    June 2008
Posted by Hans von Hammer on Friday, June 26, 2009 5:20 PM
Once you get a Zulu in the 11-series CMF (or any other, really), it don't much matter if you got a Latin dictionary, Top... The lozenge you got takes care of that...  Big Smile [:D]
I knew I'd never make 1SG m'self... My ,shall we say, sense of humor precluded it...  Well, maybe that's not it, but I DID have a problem with "tact" around the O's...   Reckon that's why they sent me to the Brigade Staff instead of a Chemical Company when I was a SFC...  That way they could kick me outta the TOC on a regular basis... Some Majors are kinda thin-skinned at times... Especially the ones I knew back when they were Two El-tees and were later passed over for O-5 a couple times...Big Smile [:D]Wink [;)]   But that's another story, lol...
    January 2008
Posted by Bodge on Friday, June 26, 2009 6:18 PM
A beautifull piece of work. Thumbs Up [tup]
    July 2006
Posted by redleg12 on Saturday, June 27, 2009 1:52 PM
Andy - Thanks for stopping in and for your comments. It's always great to get comments long distannce Smile,Wink, & Grin [swg]
Rounds Complete!!
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Thursday, July 2, 2009 10:06 PM
 Ok Mike, http://i213.photobucket.com/albums/cc93/jontreichel/Smileys/cowlookingzc5.gif where 'ya been. Waited and waited to see how the weathering is gonna come out before bestowing honors.......http://i60.photobucket.com/albums/h21/mykukla/smileys/fistbump.gifhere's a bump to get 'ya going.
http://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
 https://i.imgur.com/LjRRaV1.png
    July 2006
Posted by redleg12 on Friday, July 3, 2009 6:22 AM
DM - The past few weeks have been a zoo with traveling for work during the week and catching up on the week end. I have 3 days before I have to get on a plane again......I intend to get it done this week end and have an update by Sun at worst.
I'll BE BACK....(and thanks for the thought)
Rounds Complete!!
    July 2006
Posted by redleg12 on Saturday, July 4, 2009 10:03 PM
OK...It has been a while as work and travel has cut my bench time of late. I finished up some scratch details and the weathering.
First I did some dry brushing with Alclad Steel on the edges especially on the trails where the paint is quickly worn off. Next with the exception of the steel areas, the model received a filter using MIG dark filter for greens. After the filter I used the MIG Dark Wash to highlight some details. Lastly, to give the model that dusty look, I used a mix of MIG Dried Mud, City Dust and European Soil which I lightly dusted on and worked in. Prior to using the pigments the model was coated with MIG pigment set.
The spades which are steel I used a mix of different MIG rust pigments on the edges and around attachments.
Here is an overall view of the completed model
As for the details, the kit does not include the air lines for the brake system. The lines are Verlinden hoses and the connectors are made from .010 sheet punched .059 in diameter with a .030 styrene rod on top with the end cut on a 45 degree angle. The "Chicago" fitting are painted steel and mounted in the stored connection area.
The kit has very nice details but the sight systems are the pits. The kit does not include an elbow telescope (used for direct fire) which is normally mounted on the AG side. Using the end of a spare elbow telescope for a M102, I mounted a 0.120 diameter styrene tube. To create the sun shield I wrapped the end with a strip of PE. The front lens is a MV lens mounted in the tube. The handles and focus is painted Alclad Steel, the eye lens is Alclad Chrome with Future top coat and the eye piece is Tamiya Flat Black
The lanyard is made from wax coated ship riggers string, painted NATO Green. The ball on the end is .040 styrene rod with the ends shaped and the center drilled to allow the string to pass through. The lanyard attachment hook is .026 wire
The brake system has two gages on the right trail. The kit does not include any decals for these so I shrank a picture of the actual gages and printed the decals.
The panoramic telescope is in need of detail. The eye cup is painted flat black and the vision lens on top is Alclad Chrome. The knobs are Alclad Steel.  The front surfaces where the readouts are were just a flat surface. I added a small white box where deflection would be read.
Besides the work on the model I finished the basic base.
Next up is position improvement!!! Adding
  • Ammunition
  • Powder Cans
  • Ramming Staff
  • Pail for RBC (Rifle Bore Cleaner)
  • 5 gallon can of RBC
  • Shovel and Pick
  • Section Tool chest
  • Bore Brush
  • Collimator
  • Water Cans
  • Ammo Cans for fuses and primers
  • MRE
Generally all the stuff everybody pack on a vehicle which has to be on the ground for a towed howitzer.
Happy 4th of July to all.
Total hours this update - 9.5 hours
Total hours this overall build - 44.0
Rounds Complete!!
    August 2008
Posted by glorbes on Saturday, July 4, 2009 10:18 PM
Lovely detailing on this...your small-scale additions really add to the realism.  I love the dirt and weathering effects as well...such subtle and effecive work.
    January 2009
Posted by Schnobs on Sunday, July 5, 2009 2:12 AM
Mike this looks like the real thing but that was the point right?
Seriously Sir fantastic workmanship and attention to detail.  I am quite impressed.  I want to eventually do some German Arti.  I really want to do an 88 in the future.  Have yuo done any German artillery Mike of just U.S. stuff?
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation." Herbert Spencer
    October 2004
Posted by sfcmac on Sunday, July 5, 2009 3:00 AM
 I have been really enjoying watching your progression and these great little details done up so well really make it top notch!  It looks just like what I have seen and I am really inspired by your great work!
    July 2006
Posted by redleg12 on Sunday, July 5, 2009 7:00 AM
Glorbes - Thanks for looking and your comments, especially on the weathering.
 Schnobs wrote:
Mike this looks like the real thing but that was the point right? Seriously Sir fantastic workmanship and attention to detail.  I am quite impressed.  I want to eventually do some German Arti.  I really want to do an 88 in the future.  Have yuo done any German artillery Mike of just U.S. stuff?
Edmund - Next...I have to get it to smell like the real thing!!! Thanks for the comments on the details.
Now, as far as German.....it's against my religion!!! Wink [;)]. You hang around here long enough....you know I'm Mr. OD.
That said.....if I ever built anything German, it would be an 88. The US Army even put out a Technical Manual on the German 88. I thought of doing one being towed by an M4 High Speed Tractor as a capture weapon. Problem is I have about 30 years worth of US work in the stash  Whistling [:-^]....Thanks
Aaron - I love doing the details Banged Head [banghead]....thanks, I appreciate your comments.
Rounds Complete!!
    June 2008
Posted by Hans von Hammer on Sunday, July 5, 2009 7:04 AM
Can almost smell the Wolf P*ssy, Redleg...Wink [;)]
    July 2006
Posted by redleg12 on Sunday, July 5, 2009 7:13 AM
Ahhhhh......my favorite perfume!!Wink [;)]
Thanks
Rounds Complete!!
    February 2009
Posted by scratchmod on Sunday, July 5, 2009 8:17 AM
I like what you've done with this model especially the details. Yep your a cannon cocker for sure.
The painting and weathering is perfect, looking forward to seeing all the goodies still to come.
Rob
    July 2006
Posted by redleg12 on Sunday, July 5, 2009 9:14 AM
Rob - Thanks for looking and your comments. Cannon Cocker....remember
 "Artillery lends dignity to what otherwise would be a vulgar brawl" Wink [;)]
Rounds Complete!!
