AFV M40 155mm SP Gun, WIP, 01-17-10, Finally Complete!!
    July 2006
Posted by redleg12 on Monday, September 14, 2009 5:31 AM
psstoff lbro -Thanks for stopping by and for the comments
batman - First welcome.....as far as cool....yep, I thinks so....that's why I build artillery!!
Thanks again
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    July 2006
Posted by redleg12 on Sunday, September 20, 2009 4:57 PM
This week I completed the front section including the barrel holder with SS wire replacing the kit supplied support.
I began work on the rear section installing, the ammunition storage racks, some internal structural assemblies, rear steps and details around the rear bumper and tail section.
Time for more PE with some detail in the rear section
The kit supplied bumpers are poor, but I cut them down and used them as the holding bolt for the PE supplied bumpers.  These are really really tiny and require 4 folds.....fun
In between glue drying on the main section I have worked on some other sub assemblies. Here is the firing spade. The B sprue had some bad pin marks which showed. The spade was a lot of pin mark filling prior to assembly.
The rear deck. This was also full of pin marks but since it will be displayed in the firing position, those will all be out of sight.
Lastly, the barrel. I will do a casting of the back end so I can pour a resin copy and "bologna" slice extensions to correct the barrel length.
I have to finis up the bumpers and the side tie downs on the hull, add the support bars to the deck and finish the spools for the lowering cable on the spade. Then after some cleanup, we are ready to hiy the spray booth for priming.
I will be trying to get everything ready for priming  but the prime work will be waiting a bit with a busy week coming and AMPS East next week. Should see you in two weeks for another update.
As always all comments are welcome and thanks for looking
Rounds Complete!!
    July 2006
Posted by redleg12 on Monday, October 5, 2009 7:08 PM
With AMPS East now over it was back to the bench.
With all the styrene assembled for the hull it was on to the PE. The time consuming part were the 4 PE holders on top of the storage bins on each side. These little pieces, about half the size of a pencil eraser had 5 bends and folds each. These were difficult to make and apply. They are the "wing" items on the top of the storage boxes. Also I replaced the rear step handles with SS wire. The kit supplied handles were brittle and just a pain to clean up.
The other PE task was replacing all the molded "blob" tie downs with PE tie downs. First all the molded in had to be removed then sanded and scratches polished out. Then the PE tie downs, five on each side and two in the back, had to be bent down and then out on each side and this plus application was a chore as these are about the same width as a micro clip. After numerous colorful metaphors, side view showing the tie downs.
Here is the fold down rear deck. The support bars were also a joy to attach as there is a ring through them which is glued to the deck. The trick is to glue the ring without gluing the bar (more colorful metaphors).
Lastly, some loose assemblies, the rear spade assembly, the cable reel which is used to raise and lower the spade and the air breather units.
Well.....we are finally at the point where it is time to charge up the air tanks and get some things primed and base coated.  Also time to start assembling the running gear.
The next couple of weeks will be hectic with work and Jerseycon coming but will try to squeeze some time in here and there.
Rounds Complete!!
    July 2004
Posted by wbill76 on Monday, October 5, 2009 7:24 PM
Nice to see this one getting some time again in the spotlight Mike. Nice work on the details and looking forward to more progress on this one. Thumbs Up [tup]
    August 2008
Posted by Pvt Mutt on Monday, October 5, 2009 7:31 PM
Yeah me too.Thumbs Up [tup]
Tony the Mutt
Shoot Low Boys They're Ridin Ponys
    October 2007
Posted by panzerguy on Monday, October 5, 2009 8:00 PM
    Mike just got caught up on this one, looking good buddyThumbs Up [tup]. All that extra work on this will pay off in the end I'm sure. Hmmm... do I see another ‘Best American' award in the making?
    You mentioned that the M40 saw some service at the end of WWII. Were they used in Europe or did they only see action in the Pacific?
"Happiness is a belt fed weapon"
    July 2006
Posted by redleg12 on Monday, October 5, 2009 8:30 PM
Bill -  Thanks, it feels good to get some building in. The next few weeks will be slow, then hopefully the winter building mode begins!!
Tony - Thanks, nice of you to drop by
Steve - Another best American...humm, I usaully bet lightnining does not strike twice...but I can try!!
As far as action of the M40 it was first fielded by the 911 FA , Feb 1945, in trial platoon. Some were then sent as replacements for M12s but very limited European duty. To my knowledge they never saw action in the Pacific.
Thanks guys
Rounds Complete!!
    January 2007
Posted by the doog on Monday, October 5, 2009 10:26 PM
Jeez, you're blowing this one away, Mike! Great looking build going here!
    July 2006
Posted by redleg12 on Tuesday, October 6, 2009 5:58 AM
Karl - You are tooooo kind, Thanks for the peek and the comment.
Rounds Complete!!
    April 2005
Posted by wing_nut on Tuesday, October 6, 2009 9:38 AM
I had forgotten about this build.  Obviously you didn'tWink [;)]  Lookin' good.
Marc
    November 2006
Posted by dupes on Tuesday, October 6, 2009 5:17 PM
Dang Mike...I see why you told me it wouldn't be ready for AMPS now. Heh. Wink [;)]
Awesome detail work my friend.
    July 2006
Posted by redleg12 on Tuesday, October 6, 2009 9:21 PM
Marc - Thanks, yep..with AMPS East and fall chores progress has slowed. Hopefully after the next two weeks, finishing with Jerseycon, my time will free up and I can accelerate into winter modeling mode!
Dupes - You should know me by now with artillery details. I have not even started the gun portion yet.....now you know why group builds are not my thing......I LOVE the details. Thanks for stopping by. Target completion for this guy should be somewhere around Turkey day.
Rounds Complete!!
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Wednesday, October 7, 2009 3:20 AM
What beautiful detail work here.
http://i177.photobucket.com/albums/w226/redleg12/m40-3-1.jpghttp://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
 https://i.imgur.com/LjRRaV1.png
    July 2006
Posted by redleg12 on Wednesday, October 7, 2009 5:15 AM
DM - My friend, I am humbled by your comment...thanks
Rounds Complete!!
    May 2005
Posted by terry35 on Wednesday, October 7, 2009 3:28 PM
Wow Mike its so long since I seen any progress on this one that I had forgotten about it, great progress. As always its sometimes better not to rush along with something like this, briliant detail work.
Terry.
    July 2006
Posted by redleg12 on Wednesday, October 7, 2009 3:35 PM
Terry - Thanks. as I said, this past month has been busy and should lighten up in two weeks or so. Thus the progress is slow....but steady.
Thanks again
Rounds Complete!!
    January 2012
Posted by I make stuff on Wednesday, October 7, 2009 3:52 PM
This is a COOOL project, I like the extra details.
Can't wait for paint, Redleg!
Bill
    July 2006
Posted by redleg12 on Wednesday, October 7, 2009 5:27 PM
Bill - Thanks...I am hoping to charge up the airbrush for priming...maybe tonight....
Rounds Complete!!
Posted by HeavyArty on Wednesday, October 7, 2009 7:17 PM
She's coming along great, Mike.  Keep at her.
    July 2006
Posted by redleg12 on Wednesday, October 7, 2009 8:46 PM
Gino - It is always a pleasure to have the IG drop by the mortor pool!!Shock [:O]
Driving on....thanks
Rounds Complete!!
    August 2008
Posted by Pvt Mutt on Wednesday, October 7, 2009 9:06 PM
Mike, not trying to high jack your post here but I was just ask a question and I can't answer the guy. I've often wondered myself so since i'm not a proud type of person i'll show my ignorance and ask you.
How are those range poles used?Blush [:I]
Thanks        Tony the Mutt
    July 2006
Posted by redleg12 on Thursday, October 8, 2009 5:54 AM
Tony - Hummm...where do I start....First they are called aiming posts. They are used for reference of the left to right traverse.
When a howitzer moves into position the tube is surveyed or "laid" onto the azimunth of fire. Leaving out a to of details....uning an instrument called an aiming circle to lay each gun from a surveyed point withing the battery area. The gun will sight the aiming circle using the pamoramic telscope (sight on the left side of the weapon, looking from the rear) and make adjustments to the tube position until the readings on the panoramic telescope and aiming circle agree. Now the tube is laid on the azumuth of fire.
All deflection or left and right traverse will be from that "reference point". In order to be able to put the tube on that azimuth or left or right of it the poles are put out as a referance point. They are normally set out 25 meters and 50 meters infront of the weapon. They are set into the ground straight up and in such a way that when viewed through the panoramic telescope the two poles at two distances appear as one.
Hopefully, this gives you an idea of how they are used. The old style poles were painted red and white (candy cane). As wer moved into the 70s we camoed the poles and they became green and black.
Well, there is a short explaination. any more questions just pull my lanyard
Rounds Complete!!
    August 2008
Posted by Pvt Mutt on Thursday, October 8, 2009 7:03 AM
Thank you sir at least I know more than I did,not real clear but I get the idea.
Thanks so muchThumbs Up [tup]        Tony the Mutt
    July 2006
Posted by redleg12 on Thursday, October 8, 2009 8:27 AM
Tony - Sorry if it was not totally clear...written with only one cup of coffee.
Think of their use this way. Once the gun is laid and the poles set up, the poles line up through the site at say 2800 mils (17.7 mils per degree) which is the azimuth of fire. A target comes in that is 30 mils to the left of the azmiuth of fire. The gunner will set off 2830 mils on the site which rotates the site head. Then he traverses the gun tube while looking through the site until he lines up on the poles. The tube is now pointing at an azmuth of 2830.
It is a survey reference point to use for that tube!
Rounds Complete!!
    August 2008
Posted by Pvt Mutt on Thursday, October 8, 2009 9:13 AM
No problem Mike i've got enough info now so that if i'm ever ask again I can give some sort of a reasonable answer.
You did goodMake a Toast [#toast]        Tony the Mutt
    July 2006
Posted by redleg12 on Saturday, October 10, 2009 8:08 PM
Quick update from here at the bunker. I charged up the tanks and primed all the assemblies thus far with Tamiya Flat Black
After drying for a day, a check for OOPs and off I went with the first base coat with Poly Scale OD
A view from the rear
In between all the paint drying...and a bit after, I assembled the six suspension assemblies. The AFV kit suspensions are very well detailed and are live when assembled. That's the good news...the bad news is the six assemblies take a total of 96 parts to assemble. With that said, the suspensions were time consuming.
Well that is where I am at. Next up will be to prime and base coat the suspension and road wheels. Then it will be time for some shading on the main hull prior to attaching the road wheels.
Rounds Complete!!
    May 2005
Posted by hughes2682 on Saturday, October 10, 2009 8:17 PM
Redleg,
That is coming along nicely.  I have been enjoying watching this one develop.  Thank you for the posts.  Looking forward to more!
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    July 2004
Posted by wbill76 on Saturday, October 10, 2009 11:32 PM
Making good progress Mike! Those bogey suspensions sound like a lot of work...reminds me of the DML Super Kit Pz IV suspensions. I'm sure they're worth the effort in the long run and glad you didn't go nuts in the assembly process. Propeller [8-]
    August 2003
Posted by Nachtflieger on Sunday, October 11, 2009 5:40 AM
This one is coming out great Mike! Outstanding attention to detail.Thumbs Up [tup]Thumbs Up [tup]
Nate
    July 2006
Posted by redleg12 on Sunday, October 11, 2009 6:26 AM
Dave - Thanks for looking in and I am glad you are enjoying the build. As always I will try to keep it coming.
Bill - Yep, with parts clean up and then assembly it was close to 5 hours...but the PIA was worth it. Thanks for stopping in.
Nate - Thanks for stopping by and for your comments
Rounds Complete!!
