Managed to squeeze in a little bit of work in between turkey and shopping over the holiday. The last remaining bit of business before painting was the rear turret details, so I proceeded to complete Step 18 by adding the spare track links and rear turret bin.
The Atak turret rear replicates the plate on the DML turret perfectly and I didn't have any fit issues, just had to be careful to place the links in the correct spot as each one is shaped a little differently due to the curve of the turret. I had hoped that I could detail the links and install them later but due to their placement and how they fit in with the turret bin that wasn't possible. I used a #68 finger drill to drill out the open track pin holes on the links at either end of the runs for a little more detail and then used CA gel to glue them to the resin turret and regular glue to each other to complete the runs.
Next I assembled the turret bin and used a #11 blade to remove the molded-on bin latches and replaced them with the 3-part Lion Roar PE parts. The bin was then installed to the turret rear.
Test fit with the hull showed the bin had plenty of clearance all-around and also helps balance out the overall look of the turret relative to the hull.
Tomorrow should see the paint work start if the weather holds up!
