As often happens, several odds-and-ends things interfered with my bench-time this weekend but I did manage to get all the external details attached in anticipation of painting next weekend.
Going back to the skipped steps, I started first with Step 11 which adds all the various gear and equipment to the right hull side. In terms of order, it's best to start by adding the small fender strip, H24, and then add the supports underneath it vs. the other way around. This is due to the fact that the part, at least for my kit, was slightly warped and by gluing it first to the hull and then adding the supports, I could work out the warp slowly one bit at a time instead of trying to do it all at once.
Some of the parts on the C sprue were also warped which meant that things like the spare track holders and the tool racks for the front of the hull had to be carefully glued into position and held with tweezers until the glue had caught enough to keep one side from popping up. I opted for the version of the jack block holder that had the block separate as that will allow for greater flexibility for painting and detailing that particular item. All of the pioneer tools will be painted and detailed separately after the hull is painted so these were also put off to the side for now.
For the left hull side, I first went back to Step 9 and assembled the gun cleaning rod case as directed. I used a sanding stick to carefully remove the join line once the glue had set up and set it off to the side until I had finished with Step 12 when it was installed to the hull as the last item.
Just as with the left side, the right side parts were also slightly warped and had to be dealt with in the same way. I also added the Bosch headlight and didn't bother with adding the clear styrene insert.
I also managed working in short sessions throughout the week and finishing up this weekend to get the MK track runs together. Since the guide-horns are separate pieces, it was a little more time consuming than usual but was worth the effort in the long run.
Next up will be the exterior paint work.
