Well…it has been a few weeks. Work is killing my bench time and finally the big bird day came. After all the festivities, I was finally able to get some time in the studio.
With the frame painted and the wheels and tracks painted, it was time to finish up the drive train. The bogie mount was assembled and mounted, minus the bogies. The idler was glued on. The track halves were assembled. Then the drive wheel was glued into position within the tracks. Now the tracks are worked into place over the idler and carefully pulled until the drive wheel is in position and can be pushed onto the axel. Repeat for the other side and then mount the front tires
Hummm….daughter use camera……changed white balance…..excuse the color!!
Afterward the bogie sets were mounted. Fixed up the bogies on the inside by using Dark Sienna oil, dry brushed for that rusty rim look. The metal center teeth of the track were painted with Alclad Burnt Metal. After drying, then dry brushed with some Dark Sienna. As some pre-weathering to get at some of the hard to get areas, I used MIG Grey for Green wash to give that some what sandy look. It is visible on the tracks
Moving on the cargo section was primed and painted with OD. I will have the model in position with the rear door open. Here is the cargo section mounted to the frame.
Also primed and painted the cab section
Most of the remaining assembly is around the howitzer and details. I worked on the cab dashboard. There are no decals for the dash and the PE set was…..IMO….a waste of time so after base coating with OD, I hand painted the white gauges with black or red insides. The placards are Archer transfers. The shifter knobs and horn on the steering wheel is black marker. The fire extinguisher is Tamiya Flat Red and Alclad Brushed Aluminum for the handle. Seats still have to be mounted.
Besides what is shown, I accomplished painting many of the howitzer assemblies which will be used later. Also began work on some of the other details like the Gerry cans, tools, etc.
Next up will be to finish the seats and get the cab mounted….then work the details until it is time for the howitzer.
As always thanks for stopping by. Your comments good or bad are always appreciated.
Rounds Complete!!
