Made a lot of progress with the build and completed the sIG 33 gun. Work on this begins in Steps 15 and 16 and deals with the sides of the gun carriage. One of the expedient characteristics of the Bison II was the fact that they essentially took a regular sIG33 and plopped it into a Pz II modified hull with very little changes to the actual sIG33 itself.
I did a couple of modifications. I drilled out the holes in the gun sight elevation/range calculation mechanism to provide some detail and I held off installing parts A26/27 until I had added the rear spade plate in Step 17 (not that it really matters much as that entire portion gets hidden away by the rear compartments). I also didn't install the optics portion of the gun sight as those are provided as clear parts and I want to detail them separately before installation later on.
In hindsight, I would have held off installing the hand wheels as their attachment points are very small and in subsequent steps they had a tendency to be in the way and get knocked off repeatedly.
Steps 17 and 18 add parts to the interior and exterior and bring the two halves of the gun mount together. You have to give some thought to this in terms of the order you do this as there are a lot of parts that all have to line up just so to keep the halves in alignment. I found that the best approach was gluing all the necessary inside parts to the right frame side as called for, then gluing the two halves together, then adding all the different additional detail parts. The one exception was part A50, this has a very snug fit at the front and should be added before gluing the halves together.
One area that you have to be extremely careful with is adding the rear spade and towing eye. These are essential to line up the gun carriage correctly in the vehicle lower hull but there's no guide provided to get the spade exactly centered, so I broke out my small metal mm ruler and used that to insure I got things centered correctly before committing to glue.
Step 19 is a very involved step. It assembles the gun and recoil sled as well as the recoil housing trays. A small amount of putty was needed along the join line of the breech halves but otherwise the gun itself assembled cleanly. I left the breech block removable to facilitate detail painting later on. The gun itself is also removable for the same reason.
That took me to Step 20 and deals with the front splinter shields. The instruction diagram isn't too clear on exactly how the support arms for the left side shield should install...you need to have the curved support inside the L shaped support in order for it to line up properly to the holes on the gun mount. I added the support rods first and test fit them to insure they held at the right angle and let them set a bit before installing the shields to the gun mount. I left off the PE chalk boards for now and will add them later after painting.
I also did a test fit with all of the other hull interior components to make sure I had things aligned correctly.
Now everything is broken down and the interior is ready for painting which is the next step to come!
