Zil 157 truck from Trumpeter kit 204 . Its 9-26 and Its finished ! Cutting edge pictures posted !
    March 2006
Posted by Shellback on Sunday, September 16, 2012 3:23 PM
William , hey glad to see you didnt misss much !
Rob , good to see your still out there ........... gettin some wash on it today ........late start though .
Marc , strange looking isnt it , all clean and purty .......gettin it dirty today though .
Andy ,The missile and trailer will be on some other solo build . I want to get to the Steel Cats G.B. next .
Bill , lol , Kermit green ........
Hey my friends , thanks to all of you for looking and and for your comments Yes........Toast
    March 2006
Posted by Shellback on Sunday, September 16, 2012 10:09 PM
I know its late back east but out here its still early and i just finished up for todays update . Whistling
Here's the cab with a wash of burnt umber oils ..
This is the rear window . I used a Sharpie to draw in the black rubber gasket . It was easy to do since there is a ridge around the perimeter on the inside . The black hides the Krystal Kleer glue on the inside .
And a look thru the rear window at the dash .A coat of mat finish has dulled the finish .
Same view with face against the glass ..................Stick out tongue
    September 2005
Posted by treadwell on Sunday, September 16, 2012 10:18 PM
Jayzus Shell  !Big Smile  I have a pretty good vocabulary but but I am starting to run out of adjectives !Stick out tongue
She looks so nice and the 'view ' through the rear glass is spectacular !.. looks really real.
Gonna be the best ride the NVA ever had !
treadCool
    March 2006
Posted by Shellback on Sunday, September 16, 2012 10:36 PM
Aye William ! I thought it'd be way to late back east there for you to still be up and replying tonight . Thanks for the great complement my friend Toast
    July 2006
Posted by constructor on Sunday, September 16, 2012 10:50 PM
What are you using for cables and spark plug wirings?
    July 2004
Posted by wbill76 on Monday, September 17, 2012 9:04 AM
Love the view! Yes Yes
    March 2006
Posted by Shellback on Monday, September 17, 2012 8:45 PM
constructor
    March 2006
Posted by Shellback on Monday, September 17, 2012 8:47 PM
wbill76
Bill , thanks Yes
    October 2009
Posted by PANZERWAFFE on Monday, September 17, 2012 8:52 PM
That is a NICE view ! Beer  Did you future the widow first, it is really clear?  Looks great.  The cab's paint job is very impressive....REALLY LIKE it Beer  Are you mixing MM flat white with the Armor Green?
Rob
    March 2006
Posted by Shellback on Monday, September 17, 2012 9:16 PM
PANZERWAFFE
Aye Rob .Yes
On the window i polished the clear plastic with Plastic Polish by Bare  - Metal . I did not Future it though . I want to show it dusty so i will be putting something over it to dull it . About the paint i'm probably complicating the process but hey , it works for me . First i'm spraying MM enamel Russian Armor . Then i go over that with MM Russian Armor cut with MM Flat White and spray that mixture for a faded paint look .  Then i seal that with Burnt Umber oils ....this cuts down the brightness of the green . Finally i over spray it all with a mix of Future / Tamiya Flat Base .
Hope that s'plains it my friend .
    October 2009
Posted by PANZERWAFFE on Monday, September 17, 2012 9:22 PM
That it does.  That's how I thought you were painting just wanted to ask to clarify because I really liked the result Yes  I have never used Plastic Polish before, sounds and looks like something worth having.
Thanks for the explanation my friend Yes
Rob
    March 2006
Posted by Shellback on Monday, September 17, 2012 9:29 PM
Rob, thanks for the interest . I dont know if Bare Metal makes that polish anymore . The stuff i have is reeeeeeal old .
    August 2007
Posted by DUSTER on Monday, September 17, 2012 10:25 PM
         Great shots through the back window and the paint fade is incredible
especially like  the rubber gasket.
--Uh did you notice the heater control knob is pulled out?  never mind  it must be because you havent finished the engine instal.
Steve
    March 2006
Posted by Shellback on Monday, September 17, 2012 10:58 PM
Steve , LOL !!! Thanks for your comments man   Toast
    March 2006
Posted by Shellback on Thursday, September 20, 2012 12:59 AM
Remember when i did some scratch work under the hood ? It looked like this ...................
After i looked at some pictures of the actual vehicle again .....................
I decided to remove everything and then glued the upper cab to the lower cab. NO ! I wasnt trying to keep the cab warm with the rag ..........Stick out tongue..........I wrapped it to protect the new paint job .Idea
This leaves a seam across the firewall and down the sides .
The seam across the firewall is ok ,  its on the the actual vehicle , but the seams down the sides of the firewall are not on the actual vehicle . I filled those with c.a, and sanded smooth .
Then i scribed the seam into the edges of the firewall to match the molded seam on the cab sides , just as it is on the actual vehicle .
Then i added some new under hood details .
Tonight i shot a coat of paint and Future . I left the under hood area a little darker green to differentiate the weathered color of the paint . I also removed the two  braces that run from the lower firewall sides to the lower radiator frame . i do not see them on the actual vehicle .
See you tomorrow .
    April 2005
Posted by wing_nut on Thursday, September 20, 2012 6:09 AM
That last pic is kinda creepy.  But the rest look great.
Marc
    September 2005
Posted by treadwell on Thursday, September 20, 2012 7:54 AM
He looks like a Christmas ZiL now !Big Smile.....nice surgery under the hood !
treadCool
    December 2004
Posted by vonryan on Thursday, September 20, 2012 10:41 AM
Carl i know i asked this. but are you sure your not trying to make this truck run. or turn it into a transformer?? "the Missile man"or "Minute missile"  Big Smile above and beyond on this build. really liking it.
Clay
    July 2004
Posted by wbill76 on Thursday, September 20, 2012 10:58 AM
Very nice attention to detail Carl...and that last pic will definitely have me hearing whispers from the bench and stash closet for many nights to come... Propeller
    March 2006
Posted by Shellback on Thursday, September 20, 2012 4:30 PM
Hey guys thanks for the looks and kind komments ! Glad you all liked the Zil guy .Toast
    May 2005
Posted by terry35 on Thursday, September 20, 2012 7:10 PM
Amazing work Carl, simply amazing, some photos I honestly had to double check to be sure it was a model I was looking at, the chassis in its weathered state is mind blowing realistic.
Terry.
    April 2009
Posted by deafpanzer on Thursday, September 20, 2012 8:18 PM
(Chuckling)  Loved the last picture!  You and your anal attention to the details... match made in heaven!  Keep it coming buddy!
Andy
    March 2006
Posted by Shellback on Thursday, September 20, 2012 8:43 PM
Terry , thank you for that . Yes
Andy , thanks again Beer .
The comments everyone leaves here are very much appreciated !!
    March 2006
Posted by Shellback on Thursday, September 20, 2012 10:30 PM
Almost there .
    January 2003
Posted by TomZ2 on Thursday, September 20, 2012 11:03 PM
Needs rust.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    August 2007
Posted by DUSTER on Thursday, September 20, 2012 11:30 PM
 Lew King Good!  Carl
your skill is, is, is, is.......Free king Awh some.
Steve
    March 2006
Posted by Shellback on Friday, September 21, 2012 12:03 AM
TomZ2
Needs rust.
Thats a nice clean truck , look at these .............................
    March 2006
Posted by Shellback on Friday, September 21, 2012 12:09 AM
Steve , many thanks my friend !
    March 2006
Posted by Shellback on Friday, September 21, 2012 11:28 PM
Been working on the Zil but i dont have any update pics for ya . After i looked at this picture i realized the left front wheel had the tire mounted backwards . On this truck the tread is directional . The pointy end of the "V" in the tread pattern should be down at the front of the tire .
So i turned her over and pried the the tire off of the rim ..............so how did that go you ask ? I only broke the steering tie rod and one of the air brake cylinders ...........Embarrassed I maintained my cool and fixed everthing and have the tire remouted correctly now .
But............i was looking at the paint job and decided to redo it ..........Whistling.............the weathering is to dark on some parts and i dont like it so i am in the process of repainting it now .Oh well , like Andy said i'm anal on details ( dont know if i like the sound of that ?) but heck , arent we all ?
Yes
    May 2003
Posted by rtvmodeler on Saturday, September 22, 2012 12:51 AM
Great work friend!
Regards!
Rodolfo
Current Project:
Figures from Dragon, "German 6th Army, Stalingrad 1942-1943", 1/35
