Sturmgeschutz Sdkfz. 167 Dio *finished*
Posted by Bish on Sunday, January 20, 2013 2:04 PM
Eric, i was reading that today, i think it was on Panzer world. Sort of make sense given that the Soviets, as far as i know, didn't have bazooka's. But i am not sure if they had shaped charges or not.
Posted by tigerman on Sunday, January 20, 2013 1:55 PM
CapnMac82
The purpose of skirting (schurzen) was to cope with low-velocity shaped-charge weapons.
This is what I thought as well, but to my little knowledge, they were introduced on the Eastern Front in 1943 to combat anti-tank rifle rounds that could penetrate the thinner armor on the lower hull. Now if someone can prove me wrong, please do. Now they did affect bazooka rounds from the alllies as well, but this came later on.
 Eric
    January 2010
Posted by CallSignOWL on Sunday, January 20, 2013 7:07 AM
thanks guys!  :)
Now that I'm here, where am I??
    August 2005
Posted by Phil_H on Sunday, January 20, 2013 5:38 AM
Nice work Owl, she's looking good. Nice work on the thinner schurzen. I like the retaining brackets for the spare track on the glacis - good attention to details. Smile
Posted by Bish on Sunday, January 20, 2013 3:43 AM
Winetanker
What color should the inside of the schurzen be?
Would there be  camo underneath the schurzen?
The photos that do show the inside of Schurzen seem to show a light colour, so i would go for yellow. This is certainly the case on museum examples. And no, there wouldn't be any camo on there.
Great work OWL, you have really been biten by the armour bug.
Posted by CapnMac82 on Sunday, January 20, 2013 2:54 AM
So, the plates needed to be thick enough to set off the fuses on those weapons, but not so heavy as to bog the AFV down with additional weight.
So, the edges & bottoms of the skirts probably caught on all sorts of things.  As a guess, the Battalion or Regimental Trains probably did not have "spares" of the skirts in stock.  However, company/battalion level maintenance units would be able to weld/bolt the hanger brackets on whatever sheet steel was handy.  Which would get the paint available at that depot.
The paint availability and the crew sensitivity to hostile forces probably defined how good and complete a paint job that represented in the field.  I cannot recall if the Soviets had that sort of thing (my brain wants to remember RPG-4 being '46).  Now, the US forces would have 2.3" bazooka in later years; the Brits had the PIAT right through the war.  Either of those would leave a 1-2 cm hole in th eskirt, and a serious char mark behind that.
So, probably they ought to look much like a beat-up car fender, rather than anything shot-up  Although a near-miss would leave some scars--but modeling those in context could be tough.
And, it's a good model so far, and the replaced skirts are very light like they ought be.
That's my 2ยข; you'll need another $4 for a happy meal.
Posted by tigerman on Sunday, January 20, 2013 2:45 AM
the doog
iraqiwildman
Also if your going to use the side skirts, you might want just install the tracks before painting, since the majority of them will be hidden behind the skirts. On my last two soviet tanks, I have installed the tracks before painting, paint them black when pre-shading, tape off most of the tracks and then paint the road wheels. I saved a lot of time painting and weathering parts of the track that will never been seen.
Just something to consider---when you do that, you can't really properly weather the guide horns on the tracks, nor can you really do the path where the wheels themselves weather and shine up the track face inside. The guide horns should be silvered from wear, and the path where the wheels actually contact the inside of the track should be a metallic gray,
Look at how the inside of this Leopard 2 track is worn by the rubber wheels. This is something that a lot of modelers miss.
Dog-gone-it, never thought of that before. Bang Head
Owl, fine work on all the scratched schurzen and tow cables.
 Eric
    March 2004
Posted by Mikeym_us on Sunday, January 20, 2013 1:35 AM
Karl would the Schurzen panels  be a unlightend shade (basically out of the warehouse) of the basecoat being replacement panels?
 And would it be possible to model the Stug IV with weathered panels and unweathered panels? That is something I haven't really seen done before here but might be really plausible due to the frequent replacement of Schurzen panels.
the doog
That looks great, Owl. Looks like you got the track method down perfectly! The tape, the sag, all of it--I even think I see those return rollers done up right?
Good one on the springs, and the new schurzen look great.
Oh yeah, and that cable is rockin'!
Now, with paint---I admit this is a personal peeve of mine, but it really makes a difference; don't shoot your Dark Yellow straight out of the bottle. Lighten it by at LEAST 50%. It's too dark out of the bottle--it's much more realistic to lighten it up--especially as you start to add washes. which will only darken your base coat. Big Smile
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    July 2006
Posted by bufflehead on Saturday, January 19, 2013 10:54 PM
Great detail work Owl!  Good call on the tow cables....molded plastic just doesn't cut it in my book!  I see you used Karl's track method perfectly, even down to the tissue paper sag!!  Fender springs, unditching logs....you're really going to town with this Stug!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    January 2010
Posted by CallSignOWL on Saturday, January 19, 2013 10:14 PM
thanks doog! Means a lot coming from you! :)
I'm not going to be able to use my airbrush in this one, though. Im not to sure abut air compressors being allowed in dorm-rooms, you see. So it will be a hand-brushed affair using the little Testors enamel jars, and mixes there-of.
    January 2007
Posted by the doog on Saturday, January 19, 2013 9:34 PM
    January 2010
Posted by CallSignOWL on Saturday, January 19, 2013 8:44 PM
wbill76
wbill76
recessed?! Gah! I just got done gluing on itty bitty circles on them! arg
    July 2004
Posted by wbill76 on Saturday, January 19, 2013 8:37 PM
Very nice work fabricating those schurzen plates and hangers! I wouldn't worry too much about the bolt heads...they are tiny in-scale and  recessed to boot...so once you paint and weather they would be virtually invisible. Wink
    January 2010
Posted by CallSignOWL on Saturday, January 19, 2013 4:13 PM
bolt heads...!
    March 2004
Posted by Mikeym_us on Saturday, January 19, 2013 3:34 PM
CallSignOWL
Thanks for all the suggestions and tips! Im moving right along with the Sturm
I added some scratch built springs
And have completed the tracks
(one of the wheels got glued to the track, oops)
I also fabricated new shield panels
much thinner than the kit pieces
NEXT IS PAINT!! Big Smile
Don't forget to add the bolt heads to the shurzen since the hangers would have been bolted on.
    January 2010
Posted by CallSignOWL on Saturday, January 19, 2013 2:11 PM
oh, yeah. I also used the kit pieces for my own link cable because I dindt like the kit supplied one
    January 2010
Posted by CallSignOWL on Saturday, January 19, 2013 2:09 PM
    August 2012
Posted by Winetanker on Saturday, January 19, 2013 11:49 AM
CallSignOWL
does this look like teh correct kind of damage these shields would get? Ive only done two panels as a test, and kinda like the way they turned out. Should every panel be beat up a bit?
I've got a StuG in my stash (the Dragon kit) that I was planing on doing the same sort of thing, so I'm glad someone asked this question.
and since we are on the subject a coupla questions Owl would probably get around to asking....
Looking good so far Owl!
....working my way up the airbrush learning curve......
    January 2007
Posted by the doog on Friday, January 18, 2013 6:54 AM
Joe, yeah, I do do that. I guess I'm a stickler for details! Honestly, I think that tracks are where a lot of modelers fall flat in their thoroughness and attention. Too many guys lump on the pigments or rust the tracks to death, not realizing that an operational tank has more steel showing than rust.
That green is made by several companies. I think Tamiya has a color close to it called "Sky"? But I know that someone else makes "Interior Green". If not, just mix it up yourself. It's not hard; I mix many of my own colors.
    July 2011
Posted by novembergray on Thursday, January 17, 2013 6:21 PM
That's a good point Karl. Do you normally do that? I'd think part of it would be lost relating to proximity. Looking at a AFV at 20 yards there are a lot of things you'd miss. I imagine this is one of those lines between artistry and realism that crop up from time to time, like nobody making that godawful ugly camo scheme from Panzer colors (take your pick). I wish I could go back to my army days for one last trip to the motor pool to have a look-see. I was much more interested in the relics on Kelly Hill than I was our 981. It seems to me the guides were pretty pourous but the insides of the tracks not nearly so much.
On that subject, does anyone make that putrid interior green the army uses? I've got an Academy 981 I have to do sometime.
Joe
It's not about how fast you get there or even where you're going. It's whether you enjoy the ride.
    January 2010
Posted by CallSignOWL on Thursday, January 17, 2013 4:50 PM
thanks for all the suggestions!
Ive started fabricating the shields out of thin plasticard I have and have made good progress on track assembly. I should have update pics soon!
    January 2007
Posted by the doog on Thursday, January 17, 2013 4:05 PM
iraqiwildman
    November 2008
Posted by iraqiwildman on Thursday, January 17, 2013 3:19 PM
Tim Wilding
    November 2008
Posted by iraqiwildman on Thursday, January 17, 2013 2:51 PM
There is a How To video on FSM website about assembling indy track links. It's under the "Video" link on top of this page.
Tim Wilding
    January 2010
Posted by CrashTestDummy on Thursday, January 17, 2013 1:42 PM
Phil_H
Just another point on the schurzen. What's provided in the kit is significantly thicker than what it should be. In real life, these plates were about 5mm thick. At your option, you could separate the panels and use them as patterns to cut new panels from some thin plastic card (0.01"?) . It would look much better, though then you would have to fabricate some retaining brackets to catch the hanger rails and hooks.
You could also cheat and sand/file the inside edges of the kit parts thinner, though this obviously doesn't look anywhere near as good.
OR, make your replacements out of thin aluminum or lead sheet.  Nick up the bottom and such, and paint and weather.  I have an old Tamiya kit that I stopped work on many years (decades) ago, and I keep thinking of trying that trick out on it.  Keep up the great work!
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    January 2010
Posted by CallSignOWL on Wednesday, January 16, 2013 9:25 PM
novembergray
For calling you a dude
haha, no problem . I think Im the only girl on here, sooo....
    July 2011
Posted by novembergray on Wednesday, January 16, 2013 8:58 PM
Joe
    January 2010
Posted by CallSignOWL on Wednesday, January 16, 2013 8:26 AM
Phil_H
Ah, good idea, I might have to do that.
    January 2010
novembergray
Sorry Owl
...sorry for what?
    August 2005
Posted by Phil_H on Wednesday, January 16, 2013 12:18 AM
