Dragon #6253 Tiger I Late Production-Complete 12-20-13
    July 2004
Posted by wbill76 on Sunday, December 1, 2013 7:30 PM
Anthony
thanks buddy! Yes It's always interesting to see how things transform in the weathering process.
sounds like you've got too many leftovers in the fridge! Big Smile Thanks for dropping by.
Karl
Always funny what the auto-censor will flag, you've been warned! Wink Thanks for the comments as always.
Posted by IBuild148 on Sunday, December 1, 2013 10:57 PM
Always like your paint blending tips and visual applications of which ive used. Your Tiger is looking good as always..
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    July 2004
Posted by wbill76 on Monday, December 2, 2013 10:43 AM
Thanks IB! Glad to hear the painting/finishing tips have been helpful for you on your own projects. Beer
    July 2004
Posted by wbill76 on Sunday, December 15, 2013 7:24 PM
Made a lot of progress in the weathering process with the Tiger. This round of effort focused on the pigment weathering. First up were the tracks. I applied a wet mixture of Mig Productions Dry Mud pigment combined with tap water (adding a drop of dishwashing soap to break the surface tension) and applied with a brush.
This is allowed to air dry and looks a bit of a mess, but the next step corrects that. Using a round stiff-bristled brush, I adjusted the dried pigments working one link at a time.
This treatment is applied to both sides of the track run to get the overall effect.
Then it was the hull and suspension's turn. Same approach but the wet mix here is Dark Mud pigments and has a couple extra steps involved.
Excess pigment is removed with a larger brush vs. the one used on the tracks.
More pigment is removed/adjusted using Q-tips, dry for the most part but using wet ones were the pigment was more stubborn.
Until finally the end result is achieved, producing a nice layered result working off the earlier washes, scuffing/chipping, etc.
Then it was time to mount the tracks. The sprockets and idler were added and the tracks installed to both sides.
And that's where the Tiger sits for now, just a few small details to work on as the last elements to complete it.
    January 2007
Posted by the doog on Sunday, December 15, 2013 7:46 PM
Excellent job, Bill---that's lean and mean looking. Really nice job on those wheels, too. :)
Posted by Tojo72 on Monday, December 16, 2013 8:17 AM
nice work on the running gear Bill
    April 2005
Posted by JohanT on Monday, December 16, 2013 9:59 AM
Hi Bill,
In addition to everyone's positive comments I would like to add I find it quite interesting to see how close your build is to the Dragon box-art, always thought that was very convincing!
The effect you are getting with the pigments is xlnt - -and you make it look so easy Stick out tongue
Congratulations and thank you for sharing your blogs here Toast
Very Best Regards
Johan
    July 2004
Posted by wbill76 on Monday, December 16, 2013 11:32 AM
Karl
Thanks as always for stopping by, figured you would like the look of that suspension and wheels. Wink
Anthony
appreciate the comments as well! We seem to be in a parallel-Tiger universe with your Wittman project. Big Smile
Johan
thank you very much indeed. The box-art is what I was working off of, so I'm glad to have gotten pretty close to it. Key to working with pigments is patience (and wearing a dust mask! Pigment dust doesn't taste too good I can assure you!) and a willingness to experiment. It's my pleasure to share the blogs here, it's how I've learned (and continue to learn from other builders) many of my techniques/approaches, so it's a sort of 'pay it forward' approach that I'm happy to do. Beer
Posted by Bish on Monday, December 16, 2013 12:47 PM
Bill, lovely work as always. And love the little tut on pigments as well. I haven't tried any of those yet, but have them on the shopping list, and now I don't need to ask how to use them.
Lovely.
    October 2007
Posted by pordoi on Monday, December 16, 2013 3:42 PM
Bill,
Nice job!  I've been waiting for this weathering step because I couldn't remember whether you fix your pigments or overspray after application?  If not, do you just keep handling of the finished model to a minimum?  I seem to always end up smudging pigment weathering when photographing, and attempts to fix or spray with dullcote significantly lessens the effects.
Don
    July 2004
Posted by wbill76 on Tuesday, December 17, 2013 10:12 AM
Bish
I'm glad to have provided you with some timely info on the pigments! Smile They are a very nice tool to have in the weathering arsenal and a little bit goes a very long way.
Don
I don't use any kind of pigment fixer as the wet application pretty much does that for me, although it's not a true sealing coat, so some care in handling is necessary afterwards to avoid . Like you, I've found that applying a sealing coat, especially anything lacquer-based, tends to mute or even eliminate the pigment result depending. A little trick I use to move the model around when photographing is to shift it using a long-handled paint brush, I 'push' it around using the handle part to guide/shift it vs. using my hands/fingers to also reduce handling once the pigments are applied. HTH!
    April 2006
Posted by jgeratic on Tuesday, December 17, 2013 12:16 PM
Bill, looking sharp!
Interesting technique with the water applied pigments... I've used Florys wash in the same manner, wiping off after application.
regards,
Jack
    July 2004
Posted by wbill76 on Tuesday, December 17, 2013 8:18 PM
Thanks Jack! Pigments are a very versatile tool and their behavior changes depending on whether you use them wet, dry, or in combination. Lots of room to play with and have fun experimenting! Yes
    July 2004
Posted by wbill76 on Friday, December 20, 2013 1:58 PM
Managed to get the finishing touches in on the Tiger and get it across the finish line. First things first though, the remaining details included some additional pigment treatment for the running gear and fenders. I applied some dry Mig Light Dust pigments to further blend in the previous efforts and tone down the reddish effects a bit as well as tie things back in with the rest of the vehicle.
Using the same pigments and approach, I also added some dust tones to the spare tracks on the turret and the hull tools/equipment.
The turret was added back to the hull for the final time to allow the antenna to be added. Once that was installed, it was no longer possible to remove the turret due to the clearance issues with rotating the turret to the other side to line up the tab/notches in the hull...so that's why this was saved to the very end. An RB Models brass antenna filled the role here and was detailed with MM non-buffing Metalizer Gunmetal.
After a few minor tweaks here and there, it was off to the photo booth for the walk-arounds.
    March 2013
Posted by garzonh on Friday, December 20, 2013 2:27 PM
Me liked it so much!!
Those colors and cammo are amazing, light weathering and rusting gives it a perfect, out of a book look!
Great build and photo and explanations are worth of magazine report.
Cheers!
    February 2010
Posted by Stage_Left on Friday, December 20, 2013 2:28 PM
Another outstanding effort as usual Bill! Thanks for another WIP- more tools for my techniques toolbox Yes
Dave
Posted by Tojo72 on Friday, December 20, 2013 3:42 PM
You kept this one pretty clean,another great job,your website and logs are so helpful
PS,just getting to the camo tonite on Wiitmans,pics soon
    April 2006
Posted by jgeratic on Friday, December 20, 2013 4:52 PM
Bill, exquisite build and an uber job on that camou! Yes
regards,
Jack
    July 2004
Posted by wbill76 on Friday, December 20, 2013 7:48 PM
Garzon
thanks for the comments, glad you like how it turned out!
BeerDave
my pleasure and glad to have added something to your arsenal, can't ever have too many methods/approaches to things available. Wink
Anthony
look forward to seeing what you do with Wittman's Ride!
BeerJack
this particular scheme is one I've been wanting to tackle for a while and I finally got around to doing it. Glad you like the end result. Yes
    October 2007
Posted by pordoi on Friday, December 20, 2013 7:50 PM
Really nice, Bill.  The thin line camo is done perfectly.  You have a distinctive style; a very clear attention to detail and an approach to depict a weathered but not abused vehicle.  Just curious if you have considered modeling a wreck or severely weathered vehicle (ala DisasterMaster).  For me, it would be a very interesting build to follow.
wbill76
So this was an error in this kit or something that occurred with the 1:1 vehicles?
Don
    July 2004
Posted by wbill76 on Friday, December 20, 2013 9:57 PM
Thanks Don! I have thought about doing a wreck but in my mind that would require a base to show the context properly and that's not something I have the display space for, so haven't done it as a result.
I'm not sure I understand your question about an 'error in the kit', are you talking about the turret rotation? The radio antenna on the actual vehicles had a rubber base that allowed it to flex so that the turret could traverse but the gun barrel would prevent a full 360 degrees unless the antenna was dismounted. The rear turret bin clears the antenna just fine though regardless of direction. The clearance issue I have is a small one regarding the height of the shovel on the front and the mantlet, not one with the antenna. I found that if I started the turret with the gun pointed to the rear and rotated it counter-clockwise, I could get it to clear by lifting up on the turret after the tabs had engaged every so slightly but the clockwise rotation would snag on the shovel every time even with the lift attempt...no real explanation for why other than just a fractional mm difference in how the turret 'floats' in the ring I guess and interacts with the shovel from one direction vs. the other.
Posted by tigerman on Saturday, December 21, 2013 12:25 AM
Another beautiful build Bill. You nailed the camo and as others have stated, you have a unique style which is easily recognized.
 Eric
    December 2008
Posted by New Hampshire on Saturday, December 21, 2013 7:04 AM
One more fine effort to add to the collection Bill!  Two thumbs up.
Brian
    October 2007
Posted by pordoi on Saturday, December 21, 2013 8:13 AM
wbill76
Ah.  I misunderstood.  I thought the problem was that the turret bin didn't clear the antenna.
Don
    July 2004
Posted by wbill76 on Saturday, December 21, 2013 10:19 AM
Eric
thank you sir! I'm always trying to raise the bar with my builds and am glad to hear there's a recognizable quality to them, hopefully without them all appearing to be exactly the same too.
Brian
, much appreciated as always! Yes
Posted by IBuild148 on Saturday, December 21, 2013 4:18 PM
Puuuuuurfect!!! Another winner!
Will be using your track weathering techniques.
IBuildOne48
Scalefinishes.com
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Sunday, December 22, 2013 9:13 AM
            Super Job Bill!
                                                    http://www.killersklan.it/forum/smile/berlusca.gif
        A great way to finish out the year.
 https://i.imgur.com/LjRRaV1.png
Posted by Bish on Sunday, December 22, 2013 9:34 AM
Yep, its another beauty. Always a pleasure watching your builds, and always something to learn.
Have you ever thought about doing a base or even a diorama for your builds.
    July 2004
Posted by wbill76 on Sunday, December 22, 2013 10:40 AM
IB
thanks for the comments, glad the track weathering technique is helpful for you. Wink
DM
thanks as well! 2013 isn't quite over yet...even if the armor production is currently finished. As a little 'filler' project, I'm working on a Moebius Battlestar Galactica since I got the kit as an 'early' Xmas present. Wink
Bish
always glad to have you along for the ride! I have done bases and dioramas in the past but didn't really get into that aspect of modeling...combined with the display issues for the end result and I've developed a preference away from bases/dios as a result. Doesn't mean I don't appreciate the amount of work and talent that dio builders put in though of course. Smile
    January 2007
Posted by the doog on Sunday, December 22, 2013 3:04 PM
Beautful work, BIll, a real "classic" Tiger! Beer
